Cheers guys. I haven't glued the tyres in yet Steve, I noticed after I did the pic lol. Will get them all same way when I glue them. Saying that I got tyres at work and have done rotation wrong before.  corrected straight away though. Did any of you guys have a lroem with the rear suspension. The instructions give a size for the tie rod to be set but at that setting the hub wont move up or down. I have set the lower pivot balls to show 4 threads. I have. now ordered my next upgrades. Hopefully will work. I checked out the length of them to mine which they are around the same. They are orange ones that are coming. Hopefully same shade as the others. Chris magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Small update. Had one tank of fuel through the Huracan today at work. Had a small leak of oil from the exhaust. I stripped it down and found a small hole in the alloy. I used a small amount of Chemical metal and some high temp sealant on it. Now no leaks. On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 The suspension on mine is very stiff but she has run fine like this when set up and that engines a screamer when she gets going Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Cheers Andy, Well guys here is the finished product. I have done a few tweaks , setup the steering and suspension. I also drilled out all the air intakes for better airflow. I am waiting on the alloy steering rods and tie rods, also I have ordered one piece drive shafts for the rear. Then the next upgrade is a fast servo for the steering, possibly a Savox servo.
Wow, love what you've done to it, looks a real beasty, very well, done
That looks fantastic Chris, love the little touches that you have added.
 Now thats a great result and she looks a treat and have fun with her Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Very nice Chris
That's one impressive build, looks superb....  Well done... Regards Alan
Nicely done Chris  and your adding even more to it. Al
Nice one Chris. With all the additions there`s only one thing missing and that`s the personalised number plates. Would love to see a video of it in action if poss. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Cheers guys Now that's an idea Derek. Yeah will post video soon. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
A really nice build you have there! Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Guest (10)
