Planking Question Options
Gan_Javi
#1 Posted : 23 January 2011 09:44:31
Hiya, me again BigGrin
I have 2 planking questions. First off, I am building the launch so long, as a test run. It doesn't look TOO bad, especially considering this is my first build.
How is the best way to bend the planking? I leave it in hot water and slowly work a bend through it. I saw some guy has a big wooden board and he adds nails in pre-made holes that cover the plank in roughly the shape he wants it bent, then leaves it over night to cool and set. That seems quite brilliant actually.
Is the plank bender in the tool kit worth it for bending, and how the heck does it work lol?
Secondly, I occasionally flip over to the Build Diary (which is on issue 45 just by the way). Currently the guy's (Tomick) build is almost completely planked already. He even made holes for the gun ports, and he has the floors set in as well. Is there a way to get all the cannons in? Can the flooring just be lifted off? Because it looks like that issue 45 has about 4 or 5 cannons so far, of the 100 or so from Victory.
I'll be sure to annoy all you experienced builders as I start my build someday Laugh
Francois
#2 Posted : 23 January 2011 10:14:09
hi,and welcome,whoooooh slow down,bending the planks first,the launch planks will not need any treatment except running them over your fingers to set a bend,the victory planks well,that a different kettle of fish,no pun intended,their are many ways to this,and many explainations on here,so just trawl through the thread and have a look.as for the decks,you fix them as you go,the lower decks have dummy canons,which are fixed from outside,the upper decks have full canons 'bout 24 in all,some of us are saving them to do all together(assembly line like)just read the instructions carefully,then read them again,then any questions just ask away.hope you understand what you are getting yourself into Drool and good luck.hope to see some pics on here soonCool
#3 Posted : 23 January 2011 10:58:20
Hi Gan_Javi, and can I say welcome to the forum...I can only echo what Karl said, but I used nails placed in a board in a specific way to bend my planks (leaving them to cool off and dry naturally over night) but they were for the bow section of the main build only, you can't go wrong with following tips and advice posted by other fellow shipmates on this forum, but do follow Tomick's posts for help...enjoy your build Gan_Javi...
BigGrin
This page was generated in 0.036 seconds.
