9 Pages «<23456>»
Micks aka Mogwai C57 build diary Options
#61 Posted : 17 December 2016 17:06:12
Pack 5
Stage 32
The smokebox door lock.
This stage sees you put the door lock in the smokebox door.it works well.then fit the curved handrails to the front.again all fits well.cheers mickBigGrin
#62 Posted : 17 December 2016 17:10:33
Pack 5
Stage 33
The boiler 1
Could not be easier this stage it just attach the 2 ally plates to the lower boiler half. Cheers mick. BigGrin
#63 Posted : 17 December 2016 17:24:55
That is all coming along really well.
I especially like the pre-painted finish on this particular one.
Hope it continues to go well for you.
#64 Posted : 17 December 2016 17:25:29
Pack 5
Stage 34
The boiler 2
The first job on this is to put the handrail brackets on the top boiler half.you really need the handrails for this that come in pack 6. As I needed to clean paint from holes to get them to slide on. And it is far easier to line them up with handrail in place, as slightest bit out is going to give you trouble fitting them later. This also sees you put the handrail brackets in the front half of boiler to.I lost count how many times I dropped the nut trying to get it on in front.Cursing then you remove the joint ring from front half to glue the superheater header into this ring. The grey plastic part.then it fix to half's of boiler together, attach it to front half. And fit the water supply pipe. BigGrin
#65 Posted : 17 December 2016 17:31:55
Pack 5
Stage 35
The boiler 3
This sees us build up the tapered part of the boiler. Then attach it to the rear of boiler. Simple screw together job this stage. Cheers mick. BigGrin
#66 Posted : 17 December 2016 17:38:06
Pack 5
Stage 36
The firebox 1
This sees us attach the control valve lever, glue in 4 fusible plugs. And again fit more handrails.again using handrail to keep it all in line. Then just simple matter of fixing to rear of boiler. Cheers mick. BigGrin
#67 Posted : 17 December 2016 17:48:50
Pack 5
Stage 37
The firebox 2
Much the same as the previous stage.just couple more parts added.the ATS system, whatever that is doh. And place the generator on top. All fitting together very well. And just couple shots of how looks now.as this concludes pack 5. The yellow tape is to hold the white walkway parts to the boiler.as these are rather fragile at the moment and could easily be broken off. Dave finally snapped the water pipe off the front. An it can stay off till the end now as it bin a pain there anyway.cheers mick.
#68 Posted : 17 December 2016 18:28:27
Looking good Mick ThumpUp
I have a few days off coming up so will be catching up then BigGrin
I believe an ATS is an automatic train stop, it is supposed to stop a train in certain circumstances
#69 Posted : 17 December 2016 18:36:33
Has i said previous love the detailBigGrin just looks like the engineered parts on the real engine looks superb qualityCool Phil
Shauncnh
#70 Posted : 17 December 2016 18:46:12
This is coming along very nice BigGrin Cool can't wait for your next update
Regards Shaun
Building-RC spitfire
#71 Posted : 17 December 2016 19:10:51
BigGrin Looking good MickCool
#72 Posted : 17 December 2016 19:13:09
Looking great Mick Cool well done.
#73 Posted : 17 December 2016 19:38:52
Looks fantastic Mick, nicely done. Might get around to starting mine one day!BigGrin
#74 Posted : 17 December 2016 20:00:49
Nicely done Mick. BigGrin
That`s growing fast for pack 5.Cool
#75 Posted : 17 December 2016 21:07:53
Turning into something special Mick, great work.....Drool Drool
#76 Posted : 18 December 2016 17:56:14
Hi thanks for looking in and your comments. Much appreciated. It's a great model to do .presently working on pack 6. Cheers mick. BigGrin
#77 Posted : 22 December 2016 17:30:44
Hi all onto pack 6.this can be completed apart from issue 43, as this needs to be remade to maintain quality. A letter was put in pack 6.saying this will arrive in pack 7 now.
Stage 38
The boiler bands.
Simply put the 7 bands around the boiler, fiddly Lil job.cheers mickBlink
#78 Posted : 22 December 2016 17:38:39
Pack 6
Sand spreader pipe main cocks.
Just simply glue the 6 main cocks into sand spreader domeBigGrincheers mick. BigGrin
#79 Posted : 22 December 2016 17:48:03
Pack 6
Stage 40
Building up the dome.
First job in this stage is glue the steps to the boiler seats, then screw and glue to boiler. Then it make up the sandbox lid, and glue this into dome. Then glue in the lock bar, control valve, and whistle into the dome. Then fix the dome to the boiler.then glue the control valve crank and rod into position.cheers mick. BigGrin
#80 Posted : 22 December 2016 18:03:11
BigGrin Looking great mick nice workCool
9 Pages «<23456>»
This page was generated in 0.991 seconds.
