Build diary from Ian Options
IAN
#1 Posted : 26 January 2011 09:42:10
To Tomick and Admin…
A couple of questions please…?
This as you can see from the attached pictures is my first build, and I am enjoying the hobby very much.
All the help from your selves and the forum boys and girls is much appreciated.
I am trying to stick to the natural wood look but have got to the stage of staining the wales, but decided to stain the gun ports first, which seems to have been a big mistake, as you can see.
I days issue 43 it shows the wales being painted, but no mention of the gun ports.
In one of the issues, it shows a close up of the gun ports, which looks like they have used the correct wood type.
If I had realised what a mess the staining would look like, I should have colour stained the wood before, lining the gun ports.
Finally, I would like to bring your attention to the first issue, page 9; stating different woods will be used in this build.
Ian
IAN attached the following image(s):
Ian
Wish list: Bentley Blower
#2 Posted : 26 January 2011 09:45:44
hi Ian,sorry but can't see pic?
IAN
#3 Posted : 26 January 2011 12:33:51
Hi Karl,
Are you still unable to see the pics ?
Ian
Ian
jeff
#4 Posted : 26 January 2011 13:14:30
Rank: Beginner Level 1
hi ian
This is my first build as well i am used to working with much bigger pieces
of timber.
so am learning a lot from this forum and the more experienced members
had a look at pictures of unpainted version not very clear but port linings
appear to be same wood as the hull.
regards jeff
CMB
#5 Posted : 26 January 2011 14:02:01
Looking pretty good so far.
You are ahead of me by a long chalk.
Keep up the good work.
CMBBigGrin
#6 Posted : 26 January 2011 20:45:35
hi Ian,yep large and clear,regards the staining of the gunports,they look fine to me,a bit orangy if you don't like redo them in a more reddy stain,suggest teak stain,which is a dark red/brown colour.as for the different wood in the build,well.....................................deag have moved the goal posts on several occations and that was one of them,a few of us have bought our own wood for different applications,deag say they have the right to alter specifications and is in the small print somewhere,this is solely designed for the novice,and the more experianced can do there mods and sods to there hearts content,and some of us stay on to help out where we can.now this is my opinion only and not speaking on behalf of anyone else.
This page was generated in 0.547 seconds.
