8 Pages 123>»
Bobs Victory Masterpiece (ha ha) Options
saintsman123
#1 Posted : 31 January 2011 12:18:18
I have only recently come across the forum, so as this is my first post I thought I would say hello to everyone and give you a bit of info on my build, which I hope will develop with pictures etc.
As I struggle with arthritis and osteoperosis in my hands I decided to give this a go as exercise for my fingers. I have built a couple of Billings kits in the past (Lilla Dan, Mary Ann). Both these builds were done while I was young and single (believe it or not the only tools used were a Swiss army knife and a Toffee hammer, as being young and single the odd beer was more important than tools), The Victory is the first I have attempted since.
I have chosen to go for a "natural" finish as painting would be almost impossible with my hands. Having looked at other builds, and from the front covers of the magazines I felt that there was no distinct "This is how you must stain the ship",
so as the ship was made of Oak, I have decided on a dark oak colour below the waterline, and a lighter Oak shade above, and a walnut colour for the Wales.
Unfortunately as I have only discovered the forum recently, I cannot show any earlier construction, so pictures will only be from around the gallery fitting stage.
So far I have found the build quite straightforward, I have only used the instructions in the magazine, but wish I had found all the help here earlier, as it would have made some things easier.........for example using curling tongs as a cheap plank bender!! To get my planks into the right shape, I would soak them in hot water then using thread I would make a kind of Bow (as in bows and arrows)and leave them overnight to dry out in this shape.I would make 10 or so "bows" the planks would always twist slightly which helped make the stern and bow easier to plank. Doing it ths way meant I had to start a different frames to those suggested in the magazines, as each bent plank had a bend in different places, so I would choose the closest shaped plank for each stage.
The only deviations to the magazine so far have been the gun port linings, and a bit of planking on the cuataway, and centre deck area. (I was in a local model shop and saw some mahogany strips of wood tucked away in a corner, the strips were just the right size for the port linings, so I went for them, and I feel they do look better than the wood supplied).
Ok thats the lot for now, pictures will follow once I figure out how to post them using Admins advice.
Come on you Jimmies
z8000783
#2 Posted : 31 January 2011 12:44:51
Groups: Unapproved
Are you building a ship of any sort?
John
saintsman123
#3 Posted : 31 January 2011 12:54:42
sorry z8ooo783, I assume you have just replied to my trial post which has now been edtited
Come on you Jimmies
longsider
#4 Posted : 31 January 2011 13:50:54
welcome Bob! are you a southampton fan by anychance? good luck with the build, looking forward to some pics
#5 Posted : 31 January 2011 14:00:51
Welcome aboard saintsman123, There are a few of us on here with a disability of some kind, this build is an ideal therapy. Look forward to your postings and build pictures, they are a great bunch on here, willing to help should you need it? Good luck with your build and hope that you enjoy it...
ThumpUp
bripfc
#6 Posted : 31 January 2011 14:49:35
Welcome aboard matey
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
PLAY UP POMPEY!!!no wise cracks
saintsman123
#7 Posted : 31 January 2011 15:18:07
Thanks for the welcome folks, I've now put up an Avatar pic, so sorry to disappoint all you football fans, as its Northampton Saints BigGrin
Come on you Jimmies
saintsman123
#8 Posted : 31 January 2011 17:00:41
saintsman123 attached the following image(s):
Come on you Jimmies
#9 Posted : 31 January 2011 18:06:04
Welcome to the forum saintsman123, I'm sure you'll find lots of useful and interesting info all around the forum.
#10 Posted : 31 January 2011 20:20:22
BigGrin hi saintsman123 welcome to the madhouse,tell you what,wish I could build a boat like that with only a swiss army knife,hope I never meet a swissman,wHAT A GREAT BUILD,LOVE THE LIGHT OAK COLOUR.whoops cap lock worked on it's own.BigGrin
saintsman123
#11 Posted : 01 February 2011 16:10:48
I'm now glad I took some pictures, because I now see that I've not sanded the model back enough in lots of places, the room I work in does not have the best lighting so I had not noticed things like the gun port linings standing proud,glue residue or some of the planking gaps, so I am now in the process of more sanding, and a few plank repairs where I can.
Come on you Jimmies
saintsman123
#12 Posted : 02 February 2011 17:17:38
This is how it looks after a bit more sanding, I don't think the gunport linings stand proud as much
Come on you Jimmies
saintsman123
#13 Posted : 07 February 2011 16:47:11
As I'm getting fed up waiting for issues 39-42 suposedly despatched on the 4th, I thought I would upload a picture of my amazingConfused plank bending technique. The one good tging about it is it gives each plank a small twist which helped reduce clinkering.
Come on you Jimmies
Venice
#14 Posted : 07 February 2011 21:59:27
Hi saintsman123
Think I may Try That Idea As My Plank Bender Broke After About A Week Of Use And Have Been Using The Kettle And A Soldering Iron Ever Since!
Present Build:
H.M.S. Victory
H.M. Bark Endeavour
Photobox build album
It cant be that bad, what do you mean it's sinking
saintsman123
#15 Posted : 13 February 2011 15:29:25
Finally got some new issues, so put on the keel bits, now I do not like the look of how they fit. I realise now that puting on the stain was a mistake, I misread Mr T's official diary, and not having the magazines, I now realise I stained too early, this was due to having finished planking I got a bit fed up waiting for neww issues and went on an did something, just to do something.
So now after more sanding I have started double planking, mainly because the prow?? does not fit too well, and I can bring the veneer up close to the edges, hope that makes sense.
Ive just gone for a basswood veneer,at the bottom, so I can still go for an oak stain, but have gone for maple up top, as I like the grain better, and I still want to have a light finish.
I did have a few problems fitting the rear keel post, mainly because I did not sand the rear stern part flush with the false keel, I did not realise that it had to be done that way, I've read and re-read the magazine, but although there was no definite statement to say it should be flush the images did imply it, (although I've noticed that there seem to be more than one boat shown in the mag, and some images seem slightly different to others)so iv'e fitted the post but am not doing much with it (sanding) as I'm going to wait and see what I'll need to do later to make it look OK.
I'll post some pics later, but the build will be slowing down a bit due to a new puppy, who seems to like chewing the wood
Come on you Jimmies
#16 Posted : 13 February 2011 16:34:03
Hate to point it out, but step 3 on page 12 of issue 20 says to sand the transom so that frame 34 follows the line of the false keel, and the photo at step 4 on the same page shows frame 34 flush with the false keel, also final photo in my build diary for issue 20 clearly shows frame 34 having been sanded so it is flush with the false keel.
saintsman123
#17 Posted : 13 February 2011 18:39:54
Sorry MrT at the time I was at that stage I didn't know what the transom was, and was not on the forum to see yours,it was only when I joined the forum and saw your build that I found out I had made the mistake.Now I make sure I read both mag and your build
Come on you Jimmies
willie
#18 Posted : 13 February 2011 19:09:38
there a lot of nautical terms used dont be shy if in dout ask some one will tell you
saintsman123
#19 Posted : 21 February 2011 14:03:58
Willie you wouldn't happen to be in the RAF by any chance?, since I see lossie as you location
Come on you Jimmies
saintsman123
#20 Posted : 21 February 2011 14:13:15
Can't post pictures as this computer does not have a card reader, but so far I've done the gallery, which I found a bit tricky, it seems the old adage measure twice cut once does not apply to my build, as it was measure 3,4,5,6,7,times cut and sand a bit, then a bit more. It's on now though but I'm not completely happy with it, I hope I can get it better when the mouldings are fitted (I assume mouldings or some decoration will be fitted)
I've started the wales, and they do a good job of hiding some planking errors, hopefully I can get some pictures up once I get onto the other computer and grab the camera off the kids who are constantly taking pics of the new pup, who by the way like to TRY!! and nibble the boat.
On a side note I see HMS Hood in the shops here, so if it is a trial then they are trying it out in quite a varied area of the country, Its not a model I want to build, as I'm not too keen on "modern" warships, but I hope all the others who wish to do it can get all the issues.
Come on you Jimmies
8 Pages 123>»
This page was generated in 0.511 seconds.
