 Rank: Pro Groups: Registered
I am about to put the last 2 planks on at the top at bow end and wondered if they are supposed to be level with the bow bulkhead, tried to see in the mag but the view is obscured by a ruler. Thanks for any help.
The planking at the bow needs to be level with higher than the tops of the bow frames. Later on a bow deck is added, where if the bow planking falls short of the tops of the frames you will end up with a planking gap.
