 Rank: Pro  Groups: Registered
Joined: 04/07/2016 Posts: 297 Points: 897 Location: UK
Welcome to my first ever build diary. I got my first issue of the Delorean today from my local news agents. I will not be subscribing after how the 3D printer and Nissan car was, So i am hoping if i order at my new agents i will get all the issues. I have never done a build diary before so i thought i would give it a shot. The car is planed for 130 issues. The Delorean 1:8 Scale Length - 52.7cm Width - 23.2cm Height - 14.3cm Exterior & InteriorWorking Headlights Bonnet opens Folding wing mirrors Cooling vents Gullwing doors open Working door lights Windows roll up and down Working Brake lights The wheels can be tilted Fully detailed Delorean engine Illuminated Reactor Illuminated flux capacitor Working interior light Illuminated speedometer Working steering wheel Illuminated time circuits You can opt to change the nuclear reactor out for the futuristic Mr Fusion version. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Congratulations on your first build diary! Looking forward to seeing your progress. Are you planning to build as it comes, or add some modifications?
Thank you Nemesis, I will be building how it comes as i am no good with adding modifications  . Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Looking forward to following your first build diary. Mark Regards Markwarren (Mark) Admin
spike wrote:Thank you Nemesis, I will be building how it comes as i am no good with adding modifications  . It does look like a well detailed kit, will be watching.
I`ll be building this too spike  so looking forward to your diary  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Look forward to seeing your progress
Lets Start - Issue 1 Parts - Rear Bumper Upper Rear Section Lower Rear Section Plate Base Number Plate 4x Stickers Right Light Frame 4x Right Lights (2x Red, 1 White, 1 Orange) Plate Holder 9x AP Screws 7x BP Screws Screwdriver spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Push the lower rear section into the 4 holes on the upper rear section. Take 4 BP screws and fasten them with a screwdriver in to the 4 holes. The bumper should be firmly joined together. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Nice start spike,will be following your progress on this Al
Next is fitting the right lights into the light frame and securing it to the upper rear section. Take the 4 light parts and clip them into the corresponding spaces in the frame. Then push the assembled frame into the right side of the upper rear section. Push the plastic lip in first before pressing the rest of the frame in place. Use a BP screw to secure the frame in place. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Next we move on to the number plate. The AUG sticker goes above the O and the CA-86 sticker goes above the E. Then clip the number plate into the plate base making sure they are both the correct way up, Then secure the number plate with 2 AP screws. Take the plate holder and clip it onto the lip on the top of the plate base. Add 2 AP screws to the holes on the back to secure the plate holder to the plate base. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Joined: 27/02/2016 Posts: 138 Points: 429 Location: milton keynes
Congratulations on your first build diary from another Delorean builder Current builds: Eaglemoss DeLorean, Deagostini R2 D2 Build
The last part of issues 1 build is to add the bumper. Making sure the delorean logo is the right way up, take the bumper and attach it to the lower rear section. Align the holes and push the 2 pieces together. Store the extra screws to keep them safe as they may be used in other issues. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Bobbaf3nn wrote:Congratulations on your first build diary from another Delorean builder Thank you i will be watching your build diary.  Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Spal wrote:Nice start spike,will be following your progress on this Al Thank you. Just hope Eaglemoss don't mess about with the issues. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
tigerace wrote:I`ll be building this too spike  so looking forward to your diary  regards Phil Thank you. Hope you enjoy building it. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
davetwin wrote:Look forward to seeing your progress Thank you. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Issue 2 Parts - 2x AM Screws (Not included with the parts) 5x AP Screws 2x BP Screws Left Light Frame 4x Left Lights (2x Red, 1 White, 1 Orange) Driver-Side Wing Long Black Trim Short Black Trim. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Align the long black trim with the 2 holes (Note in the book it says 3 holes) on the outside of the wing making sure the trim fits flush with the edge of the wing. Press the trim firmly into place and add 2 AP screws. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
