6 Pages «<3456>
The King Wanted Bling ---Sovereign Build Log Options
#81 Posted : 09 January 2017 23:15:56
Hi Nige, she's coming along nicely and great to hear you are happy with the results...Cool Cool .. My only concern would be with it looking as if all your plank ends are joining on the same rib rather than being staggered, this can result in a weak point in the hull structure....Cool Cool .. I do like the way you have the planks flowing, very effective....Cool Cool
Nige
#82 Posted : 10 January 2017 03:31:11
Hi Alan and thanks for looking in. Having increased each bulkheads width to around 10/12mm and gluing each plank to it's neighbour I have no worries about any weakness. It should be more than capable of withstanding the rigours of a display stand. Cool
When I reach the second planking stage joints will be staggered and plank lengths cut to scale to achieve the desired affect. BigGrin BigGrin
Building: Sovereign Of The Seas Reading About Everyone Elses Builds[/b]
Enjoy Making
Nige
scraperjawa
#83 Posted : 10 January 2017 06:41:58
Hi Nige,
Looking good so far. Should move along rather quickly once the bow and stern are done. I'm at about the same place as you are with this build. I will post some pictures when I complete the bottom of the hull. The planking can be a bit dull, but should look nice once complete.
Keep up the good work,
Stephen
Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
#84 Posted : 10 January 2017 09:17:08
Hi Nige, great to hear you have to covered..... Would hate to see you encounter any mishaps at this stage of your build.... Look forward to seeing your next update...Cool Cool
Nige
#85 Posted : 11 January 2017 17:12:26
Hi All And Thanks For Looking In
Planking Update
Having now spent some time studying the flow of planks so far fitted to the stern I believe I've identified my error resulting in an over-wide garboard. With no instructions to follow and finding it hard to visualise the flow of planks before they where fitted I prepared for just this outcome by beefing up all the bulkheads and adding extra bulsa both bow and stern with the intention of planking one side only.
At least I only have to remove half the planks on one side at the stern and not all Crying still wrong is wrong.
Looking at the stern photo's on page four of this log a general bending in the flow of planks toward the keel can be seen. My plan is to taper down the planks that terminate at the rear where the angle changes from vertical to horizontal. This should have the effect of smoothing out the plank flow, less curve in the problem area and a cleaner change of direction adjacent to the stern post.
Will post photo's once this has been completed to show how I get on.
Keeping Eyes Firmly Fixed On The Prize
English Ship - Planked English Style
No Dropers No Steelers Flapper Flapper Flapper
Rgds Nige
Enjoy Making
Nige
Nige
#86 Posted : 14 January 2017 21:57:38
Planking Update
As mentioned before, I first removed all the rear planks from keel up to their limit on the sternpost. 13 in total and to be clear that's the same number that will need to be fitted midships to fully enclose the hull.
With the hull inverted I measured the smallest gap between the remaining planks and keel. Then using a planking fan I was able to determine how much to taper the planks at this point.
Next I just have to allow the planks to taper back to their full 5mm depth in their run forward and so fully enclose the hull with it's first layer.
Ultimately I want to paint the lower hull and I'm not sure any of this will even show. LOL LOL LOL
Nige attached the following image(s):
Enjoy Making
Nige
Nige
#87 Posted : 14 January 2017 22:08:03
Forgotten Bit
Forgot to mention this has also corrected the oversized garboard plank.
Enjoy Making
Nige
#88 Posted : 15 January 2017 00:33:45
Coming along nicely Nige, am following your progress with a great deal of interest... Cool Cool .. Looks like you're achieving a good base for the second layer of planking.....Cool Cool .. Look forward to your next update....
Nige
#89 Posted : 15 January 2017 08:33:15
Thanks Alan for your kind comments. As to your following along and support I'm rather counting on it. BigGrin
I am still following everyone's builds, learning as much as I can and love what everyone is doing.
I realise my workmanship isn't anything like that of you guys here but needed to try this in order to understand the problem. No better time to try than on the first layer.Blink
I wont get build pack 3 until the end of Feb so it will be March sometime before the lower hull is fully planked and I can post pictures of my results.
Just wish sometimes the guys who built the real ships where around so I could ask "How the heck did you do that"
Perhaps on completion of the first layer I should do a round up of what I've learned in case another fool wishes to try.LOL LOL
Kindest regards always
Nige
Enjoy Making
Nige
#90 Posted : 15 January 2017 09:38:22
BigGrin Very nicely done Nige I never get over the satisfaction of finishing the first layer of planking Cool looking forward to your next update Cool
Nige
#91 Posted : 15 January 2017 11:42:47
BigGrin Thanks Martyn.
Don't know I would ever have it in me to do another or the time left LOL
Perhaps that will excuse the numerous times I redo, all my learning is being done on this ship.
Enjoy Making
Nige
#92 Posted : 24 January 2017 14:11:36
Hi Nige.
your planking is looking very good. like to see people trying different methods of building. you are doing a great job. look forward to seeing your progress Ian. Cool Cool BigGrin
scraperjawa
#93 Posted : 24 January 2017 14:38:30
Hi Nige,
Looking good so far on the planking. Sounds like you are backtracking a bit to fix some issues. I know how frustrating that can be but the result is almost always better. The main thing is that you are happy with the result. I've done the same thing on other models when things were not going the way I wanted it to and learned so much because of it. Keep up the good work and I will continue to watch with interest. We are both learning a lot on this build.
Stephen
Nige
#94 Posted : 29 January 2017 09:45:12
scraperjawa wrote:
Hi Nige,
Stephen
Hi Stephen and thanks for looking in.
Yeah that stern planking and garboard just wasnt right but got the answer now BigGrin just waiting for the next installment (3/12).
This is only my second model, the first was a terrible mistake and a sorry thing to behold Blushing but it has made me determined to get this one right. Following everyones builds fills me with inspiration and I learn so much.
Rgds Nige
Enjoy Making
Nige
Nige
#95 Posted : 31 January 2017 13:45:24
Have now completed the last remaining tasks from build pack 2. If things get any smaller I'm going to need a bigger magnifierLOL
Enjoy Making
Nige
#96 Posted : 31 January 2017 14:24:57
I think you are doing a great job so far Nige BigGrin keep it upCool regards PhilCool
scraperjawa
#97 Posted : 31 January 2017 14:47:24
Hey Nige,
Your skiff and cannons look great. Some very nice work on the small bits. I know what you mean about needing a bigger magnifying glass. The pictures on the forum never really give you a good idea of how small everything really is.
Stephen
Nige
#98 Posted : 27 March 2017 16:40:41
Hi Everyone / Update Time
Progress has been slow but I have steadily continued planking the hull and build pack 3 is now complete. Had a couple of problems along the way that needed sorting.
1) Managed to break off three of the pointed rib tops during the planking just from generally moving the hull about. And thought that area a bit flexible when planked so added a layer of 1mm x 5mm Limewood strip.
2) As I started the upper planking it became apparent that rib 26 on the left was out at the top by 5mm. Now I know it wasn't like that when I glued it in so can't explain why.
Spent a whole 2 weeks just considering my options on that one and in the end just cut the rib off at deck level and re glued.
As to my attempt not to have any droppers or stealers, managed it at the bow but not quite at the stern, still I'm glad I tried it and I can tell you its one heck of a lot of tapering. As this build will have a painted white hull the second layer will follow the build instructions.
So now I start sanding and filling the work so far until pack 4 arrives but in the mean time if anyone spots errors I would be grateful for a shout.
Rgds Nige
Enjoy Making
Nige
#99 Posted : 27 March 2017 19:31:38
BigGrin Looking good, getting this stage of the planking nice and flat will make the second planking so much easyerCool
#100 Posted : 27 March 2017 20:09:26
Great progress. hull should look great once sanding finished, top job
6 Pages «<3456>
This page was generated in 2.282 seconds.
