17 Pages «<56789>»
benny's build Options
Son of Bulwark
#121 Posted : 29 January 2011 17:13:41
Hi benny! Cool
You are getting on well with your double planking mate, look's very nice! ThumpUp If you do get any splinter's on the plank edge that leave a gap between the planks, after fitting the planks add a little glue into any gap's then sand with 120 or 240 grit sand paper, the fine sawdust will fill the gap's. I've had to do this in a couple of places on my hull.
benny
#122 Posted : 29 January 2011 17:17:37
cheers benny
benny
#123 Posted : 29 January 2011 17:19:56
cheers darron..i have found that too.. after a couple of oils and some sanding it will look fine..benny
cheers benny
benny
#124 Posted : 29 January 2011 17:47:58
now for the entry port side panels..i used a dremel engraving tool and a steel rule to get the lines as you can see the one on the left was the one i used x4..the one on the right wasnt any good because the lines didnt line up so they were discarded..i have tried to take a pic of them fitted but i couldnt get a decent snap as you can see this pic is of them dry fitted
cheers benny
benny
#125 Posted : 06 February 2011 18:58:15
hi i have now completed the veneer on the bottom of the hull except a couple of layers near the keel which i will finish when the keel is fitted ,when it turns up..i have stained what i have done but took the pics of it still wet ,when it dries it will be a dull finish until i decide on the finish
cheers benny
benny
#126 Posted : 06 February 2011 18:59:15
cheers benny
benny
#127 Posted : 06 February 2011 19:09:41
i have started the second planking on the upper hull,i have hopefully achieve the desired gunport recess affect..in these pics i have only got to the middle gunports..is hard to see but i have only got to the 8th layer from the bottom,i have got some sanding to do and i will paint the upper hull yellow ochra before i tape around the ports to finally paint the ports red ochra
cheers benny
benny
#128 Posted : 19 February 2011 18:41:35
some pictures of my finished hull i am not going the copper plate route because to be honest the only people who know the vic is copper plated is us and not our family or friends who will be the ones who will be looking at it,i am happy with them seeing stained planking,anyway the finish is sadolin walnut exterior woodstain,also i think it looks better
cheers benny
benny
#129 Posted : 19 February 2011 18:42:43
cheers benny
benny
#130 Posted : 19 February 2011 18:43:47
cheers benny
benny
#131 Posted : 19 February 2011 18:44:54
cheers benny
benny
#132 Posted : 19 February 2011 18:45:58
cheers benny
Venice
#133 Posted : 19 February 2011 18:47:45
Looking Good Benny
Present Build:
H.M.S. Victory
H.M. Bark Endeavour
Photobox build album
It cant be that bad, what do you mean it's sinking
#134 Posted : 19 February 2011 19:58:39
Looking pretty damned good mate....keep the pictures coming...ThumpUp
petpole
#135 Posted : 19 February 2011 20:11:23
She is really coming on a treet now BigGrin
#136 Posted : 19 February 2011 23:54:48
Hi Benny,
Your wright we are the only one's who no about copper plates,i am very impressed by your work.
tom.ganc
#137 Posted : 20 February 2011 01:28:51
She's looking great Benny, well done. I'm copper plating mine :)
Tom
benny
#138 Posted : 20 February 2011 02:29:25
i appreciate your comments ,cheers benny
cheers benny
farrabass
#139 Posted : 20 February 2011 15:42:34
That's a hell of a sheen you have there!!!
benny
#140 Posted : 20 February 2011 15:46:53
yeah it does look like that but its just the light/flash
cheers benny
Guest (16)
17 Pages «<56789>»
This page was generated in 0.154 seconds.
