Hi benny! You are getting on well with your double planking mate, look's very nice!  If you do get any splinter's on the plank edge that leave a gap between the planks, after fitting the planks add a little glue into any gap's then sand with 120 or 240 grit sand paper, the fine sawdust will fill the gap's. I've had to do this in a couple of places on my hull.
Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
 cheers benny
cheers darron..i have found that too.. after a couple of oils and some sanding it will look fine..benny cheers benny
now for the entry port side panels..i used a dremel engraving tool and a steel rule to get the lines as you can see the one on the left was the one i used x4..the one on the right wasnt any good because the lines didnt line up so they were discarded..i have tried to take a pic of them fitted but i couldnt get a decent snap as you can see  this pic is of them dry fitted  cheers benny
hi i have now completed the veneer on the bottom of the hull except a couple of layers near the keel which i will finish when the keel is fitted ,when it turns up..i have stained what i have done but took the pics of it still wet ,when it dries it will be a dull finish until i decide on the finish  cheers benny
 cheers benny
i have started the second planking on the upper hull,i have hopefully achieve the desired gunport recess affect..in these pics i have only got to the middle gunports..is hard to see but i have only got to the 8th layer from the bottom,i have got some sanding to do and i will paint the upper hull yellow ochra before i tape around the ports to finally paint the ports red ochra  cheers benny
some pictures of my finished hull i am not going the copper plate route because to be honest the only people who know the vic is copper plated is us and not our family or friends who will be the ones who will be looking at it,i am happy with them seeing stained planking,anyway the finish is sadolin walnut exterior woodstain,also i think it looks better  cheers benny
 cheers benny
 cheers benny
 cheers benny
 cheers benny
 Rank: Pro  Groups: Registered
Joined: 07/10/2010 Posts: 148 Points: 430 Location: At the back of my sinking boat
Looking Good Benny Present Build: H.M.S. Victory H.M. Bark EndeavourPhotobox build albumIt cant be that bad, what do you mean it's sinking
Looking pretty damned good mate....keep the pictures coming...  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
She is really coming on a treet now Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Hi Benny, Your wright we are the only one's who no about copper plates,i am very impressed by your work. tf64 Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Joined: 25/03/2010 Posts: 472 Points: 1,357 Location: Hyde
She's looking great Benny, well done. I'm copper plating mine :) Tom
i appreciate your comments ,cheers benny cheers benny
That's a hell of a sheen you have there!!!
yeah it does look like that but its just the light/flash cheers benny
Guest (15)
