9 Pages «<6789>
going to have a go Options
jinks8
#141 Posted : 21 December 2010 17:07:21
thanks MrT have a good holl
#142 Posted : 21 December 2010 17:34:45
You too jinks Cool
jinks8
#143 Posted : 26 December 2010 14:56:53
Christmas over for 1 more year spring is on the way and the lakes may un freeze around march at this temp so just stick to the work shop, shed or if her in doors lets you the table. Fixing the guns on the deck fixing them on to a static is not much of a prob but on a working model well they need to be reinforced I have drilled holes in the bottom and put in a bit of brass rod .This is then fixt in to a hole drilled in to deck so if knocked hope fully they stay on and not go to the bottom of the lake The pins will be cut down to just over deck thickness
budgie
#144 Posted : 26 December 2010 18:17:17
BigGrin just catching up with ure build diary as been working away past couple of weeks coming along in leaps & bounds since i last looked
Drool she's certainly lookin' good
Thanks for the little tips for building it as r/c
Crying will need to put my chrissy pressies back in the Crying SOCK drawer & get on with my build Bah Humbug maybe next year
haggisKiller
#145 Posted : 01 January 2011 18:10:31
Amazing looking, just hope i can do anything close to your's ( making mine a static - no clue about R/C )
Just 1 question, i see theres a lot of brass ladders on your Build, do they come with the kit, or an extra purchase?
#146 Posted : 01 January 2011 21:33:49
Photo-etched brass ladders are part of the kit, along with the forward and aft decks and lots of other items
jinks8
#147 Posted : 03 January 2011 00:35:25
Soz did not get back to you sooner haggiskiler but had family over for New Year and was band from sites for a couple of days as Mr.T says you get them in the kit along with other parts radar is one of them as with the guns on the deck this part is best reinforced with pins as they are very vulnerable to damage Once the paint work is touched up all will be well
jinks8
#148 Posted : 03 January 2011 00:59:23
As the Yamato is a kit one has to have sumthing to do in bitween i have a long term projeget it is the USS MissouriOver the past few days i have started to work on the railings
#149 Posted : 03 January 2011 11:31:17
My those railing's look good, do you plan to do the same with the Yam?
jinks8
#150 Posted : 04 January 2011 14:25:51
Don’t know yet Mr.T all depends on the railings sent may do as they have turned out bet than expected. Take a long time to do but well worth it in the end so it is a possibility
jinks8
#151 Posted : 12 January 2011 23:07:56
HI all parts 19/20 turned upon my doorstep this morning and this is the contents
jinks8
#152 Posted : 18 January 2011 02:57:52
USTON we have a problem the vents on the forward secondary gun mounts do not fit they are to big Mr T has dune this bit was just wondering if he had a problem and if so a way to fix it The stern gun mount no problems a bit of filling in the gaps but that is all The 2 Maine guns are a copy of the first so no probs there will have photos of rest later see you soon
#153 Posted : 18 January 2011 10:08:15
Mine was also on the high side, so I filed the bottom edge of the vent to lower its height, which eats into the mesh, but once painted and in place is hardly noticeable levels out nicely at its the top, the height of my vent is now 6.5mm.
jinks8
#154 Posted : 19 January 2011 01:05:17
Thanks mrT will do that as you say will not be out of place
jinks8
#155 Posted : 27 January 2011 04:09:04
Hi fixed the bow fairlead that is part of the kit is a good bit of casting but is a devil of a bit to fix on a working model as super glue is to brittle by it self to withstand a collision with out support I have tested it and it fell off every time so if you are building a working ship it will have to be strengthened. My self I have made one out of brass and soldered it on not as good as the kit but it will not end up in the pond Mr Ts fix on the vents worked well thanks again This is what I have bin working on in-between the Yamato
#156 Posted : 27 January 2011 17:28:48
Just to let you know that the guns at the deck sides have cast metal circular bases which have a deck edge lip on the underside which makes each gun slightly overhang the deck edge as seen in the overhead plan, the bases are supplied towards the end of the series.
jinks8
#157 Posted : 28 January 2011 01:39:26
Thanks Mr T. thought something was missing good job they are not fixed yet just stuck with tape and will come of easily
jinks8
#158 Posted : 07 February 2011 14:50:56
Got the last build E.M to day so will not be long now to finish over the next few days will get the port hols and scuppers water tight and if the wind stops it is to the lake and hope she doesn't go under 14 days and the parts should be on my door step looking at the build down load a lot of fiddly bits just the job ha, ha the safety rail will be the biggest challenge finding wire thin enough to make them as thread glued to the small pins provided Would not stand the test of time on the water
it would have bin better with etched brass but still will sort sum thing out . Well that is it for now be back soon
jinks8
#159 Posted : 21 February 2011 00:19:29
Last parts arived Sat pic,s to folow but think i have gon mad just singed up for the Hood 1/200 to mach my Bissy ho what have i dunConfused Huh Crying
jinks8
#160 Posted : 22 February 2011 02:24:50
last bits the very last 2 issues the last pieces and a lot of them as you can see 081/082 are the same now for pack 0022
9 Pages «<6789>
This page was generated in 0.379 seconds.
