16 Pages «<1011121314>»
Malc's Mclaren MP4/4 Options
RM1
#221 Posted : 13 January 2017 14:19:21
ModelMania wrote:
That instrument panel looks superb with the aftermarket decals and the electronic boxes look nicely detailed too?
Nice work as always Malc, keep it up. Drool Cool ThumpUp
Thanks Kev.
Actually there is no extra detailing on the electronic boxes, that's how it comes. I have since added some gold paint to the connectors for a bit of visual interest on the final model as I intend to display it with the bodywork raised.BigGrin
Malc.
RM1
#222 Posted : 15 January 2017 15:24:16
Wiring up the electronics was an interesting process. The instructions are confused with references to wires "A,B,C & D " but with the wires identified in an earlier stage as 1,2 & 3.Confused Fortunately the official build diary clarifies what goes where.BigGrin
The images in the issue 20 manual are also too small and not that clear wrt the runs of the cables.
I've not used the "cable tie tape" but opted for PE cable bands on the throttle cable and ties around the bundles on the telemetry side.
RM1
#223 Posted : 15 January 2017 15:26:36
The cockpit also coming on nicely.
#224 Posted : 15 January 2017 15:51:05
Great work Malc, certainly a stunning looking build Cool
#225 Posted : 15 January 2017 16:47:55
Great work Malc, it looks fantastic!BigGrin
RM1
#226 Posted : 16 January 2017 15:18:19
Thanks guys. getting near the end of this build now.
Malc.
#227 Posted : 17 January 2017 13:19:50
Lovely work as always Malc, nice looking cockpit with the carbon decals and the electronic boxes and associated cabling look very well modelled.
Good stuff mate, keep up the good work. Cool ThumpUp
DaveSea
#228 Posted : 21 January 2017 06:06:58
Absolutely superb build, Malc, one of the best on this site! Love all the extra details, time and creativity you put into it.
I signed up for this kit a couple of years back but got carried away with the three bikes and my Lambo Countach build so suspended the subscription. As I am now 1-2 months away from completion of three of my builds, I am seriously thinking about reinstating this subscription. Your build has really inspired me!
BTW, I noticed a fingerprint smudge on one of the radiators, looks like from superglue vapor. I found out while building the Lambo kit that an easy way to get rid of superglue vapor smudges is to dip a cotton swab into acetone (e.g. nail polish remover) and lightly go over it. Removes the smudge right away without damaging the underlying paint layer. Forgive me if I am being presumptuous, maybe you've already cleaned it up BigGrin
Completed Building Walter Wolf's Lamborghini Countach LP 500S, Harley Davidson Fat Boy, Suzuki GSX 1300R Hayabusa, Honda CB750.
Planning to Build Easy Rider Bike, Valentino Rossi's Yamaha YZR-M1
RM1
#229 Posted : 21 January 2017 06:16:35
Hi Dave and thanks for the kind comments.
Good spot with the fingerprint. ! I only noticed it when I put the picture up. It's amazing how these things sometimes don't get noticed until a close up is taken.
Luckily .... it's only dust that's revealed the print and it wiped off easily. BigGrin
Great tip on removing vapour smudges, I didn't know that. Many thanks and please don't feel presumptuous about mentioning a snag. I'm always keen to learn.
Cheers Malc.
RM1
#230 Posted : 21 January 2017 12:39:55
Time to have a look at the body shell.BigGrin Nice large moulded pieces which go together quite well.
RM1
#231 Posted : 21 January 2017 12:43:47
I decided not to use the "sticker" as supplied for the black stripe along the base edge of the shell. After a bit of masking I sprayed it with Semi-Gloss black.
RM1
#232 Posted : 21 January 2017 12:46:35
RM1
#233 Posted : 22 January 2017 15:15:25
Most of the sub assemblies are now done and everything's ready for the final fitting togetherBigGrin
RM1
#234 Posted : 22 January 2017 15:19:46
First step is the engine and gearbox.
The connecting up of hoses is a bit of a challenge but seemed to work out ok.BigGrin
#235 Posted : 22 January 2017 19:54:42
Looking stunning Malc ThumpUp well done.
RM1
#236 Posted : 29 January 2017 12:17:06
The engine/gearbox assembly is now attached to the monocoque. There is a socket head screw (screw "f") which provides quite a good connection between the two parts. The supplied Allen key works ok to tighten this but I recommend a "ball" ended one make the process a little easier.
RM1
#237 Posted : 29 January 2017 12:20:37
The underpan is now in place. Really starting to look goodCool
I haven't attached the Plenum yet which I find makes working with the wiring a bit easier.
RM1
#238 Posted : 03 February 2017 15:25:31
I've got most of the cabling under control now. The twin antennas looked a little plain so I've added cables and some colour.BigGrin
RM1
#239 Posted : 03 February 2017 15:34:25
There are a couple of details that I'm going to add to the completed chassis.
Firstly locking wires on the brake disc bolts ( wire cut to length and glued in place ). paint stripes and temperature indicators.
RM1
#240 Posted : 03 February 2017 15:40:31
The battery has one of it's connections standing vertically with no cable so I've added a cable and connector more or less as it appears in photos of the real thing.
This page was generated in 0.970 seconds.
