10 Pages <1234>»
Occre 1:24 Adler Locomotive Display Options
greyhawk
#21 Posted : 08 January 2017 19:27:41
#22 Posted: : 08 January 2017 20:21:22
SUNDAY 08th January 2017 – The Adler Locomotive Build Commences.
Well now that the New Year is underway I thought it time to make a start on my Adler build.
As anyone that has looked at the kit reviews you will see that my hope is to build the locomotive kit along with the coach kit and display base.
In theory I could have made a start on any of these 3 elements but as each stage of the build depends on the earlier stages being finished to my liking it makes sense to start with the locomotive kit itself.
This is the Version 2 of the kit that has recently been issued by Occre. The earlier kit had no end of fit issues so with that in mind I am taking the build slow, checking and double checking as there are a few parts that could be incorrectly installed and this will cause problems later in the build. As and when I come across these I will call them out so that anyone else contemplating the build will have a few pointers for their own builds.
Been thinking about how best to present the build and as I do not use any of the photo sites it means its text followed by a group of pictures so to keep it in some sort of order I will number the pictures in each post and add text in a similar format – hope it meets with everyone’s approval.
PICTURE 1.
Only the very minimum of tools are needed at this stage. A sharp blade is a must and as the laser cut lines around the parts in the fret are some of the finest I have seen; it also needs to be a thin blade.
My preference when model making has always been the number 11 scalpel blade made by Swan Morton.
PICTURE 2.
To ensure we work with the correct parts (some look very similar) you really do need to work from this parts plan and number the wooden fret parts so that you do not make any mistakes.
PICTURE 3.
Most of the parts for these early build steps come out of this fret. It’s an MDF board and I have to say I have never seen parts packed in so tightly by a manufacturer to ensure as much of the wood sheet is used and not wasted.
This MDF board is 3mm thick and as such it’s important that when cutting through the tabs holding the parts in the fret you cut from both sides rather than trying to cut through in one go as you risk breaking the knife blade.
PICTURE 4.
As you can see from this picture it’s important to number up the parts as the boiler parts come from quite a variety of places on the fret.
PICTURE 5.
Here are the first parts removed from the fret that will be used to make up the boiler.
PICTURE 6.
The parts from this fret do have some very heavy ash from the laser cutting. To ensure the best possible glue joints it is really important to remove as much of this as possible. That said it needs to be done very carefully so as not to alter the shape of any of the parts through overzealous sanding.
PICTURE 7.
This is a dry fit of the 5 boiler parts just to ensure everything lines up before being glued together. This stage of the build will see 2 axle supports being glued into place but these need painting first in my view to ensure a neat finish before we start adding the boiler planking.
PICTURE 8.
To seal wooden parts prior to priming and top coating I will be making use of this product called “Sand n Seal” by Deluxe products. I have used it before and find it very good especially like the fact that it is water based and odourless so brushes can be rinsed out in ordinary water.
If you have this product you will be aware that it has a tendency to settle out over time so to get the best from it, I have added two steel paint mixing balls that are made by AK Interactive. Very important to ensure that they are stainless steel to ensure that no rusting occurs which can happen with some of the ball bearings you can buy.
PICTURE 9.
These are the first parts that go together to make the front end of the locomotive. In the earlier version of this kit the curved top was covered by wood planks which then had to be filled and sanded down. In this new version of the kit there is an extensive photo-etch set and this area is covered by parts from that fret (more on that once I reach that stage of the build).
PICURE 10.
And at this stage this is as far as I have progressed. The fret is reducing in terms of parts still to be used. But that said there is still a lot of work in front of me.
#23 Posted : 08 January 2017 22:22:41
BigGrin Nice start TonyCool
#24 Posted : 08 January 2017 22:54:13
Great start TonyBigGrin really great looking kitDrool Drool regards Phil
#25 Posted : 08 January 2017 23:02:42
Good to see you up and running with this one. BigGrin
Kit looks good and those frets waste next to nothing.Blink
Good luck with this one.
#26 Posted : 08 January 2017 23:10:41
Andy/Phil/Derek
Many thanks for looking in and your comments.
#27 Posted : 09 January 2017 14:00:36
Great to see this underway, good luck with the build Cool
#28 Posted : 09 January 2017 17:49:28
Great start Tony.Best of luck
#29 Posted : 15 January 2017 18:50:09
SUNDAY 15th January 2017 – The Adler Locomotive Build
I hope that everyone has had a very good week. I still have the remnants of the cough left over from my “Christmas disease” but improving by the day and have been able to press on with some more updates to my build.
In the same vain as my earlier posting I have numbered up this week’s pictures and added some text below to explain what I have been doing.
PICTURE 1.
From the MDF fret we now cut out the parts that will make up the firebox end of the locomotive. This piece of the build is one of the more complex and uses a total 9 parts from the MDF fret (7 in this picture and the remaining 2 in Picture 4)
PICTURE 2.
“CALLOUT - PROCEED WITH CARE”
I did say that as and when known issues come along I would make a special note for anyone else that might be tempted with this kit.
Part 21 forms the back plate of the fire box and while it looks symmetrical it’s not. Occre do not mention this in the instructions so it would be easy to either try and force the part in and cause later fit issues or start sanding it down with similar results.
As you can see from the picture one side is 32mm long and the other 33mm. And this does match the slots this parts fit into so important to get it the right way around.
PICTURE 3.
Dry fitted at this stage but this is the end Part 21 mentioned above will be fitted.
PICTURE 4.
While a number of the side parts are identical you need to be careful with these 2 parts numbered as 24 and 24A. While the overall dimensions are exactly the same the holes pre-drilled into these parts differ so really important to ensure you fit these to the correct sides of the fire box component.
PICTURE 5.
Once glued in place we are asked to glue in a small fillet of wood that will act as a support for the brass overlay which covers this part of the build.
PICTURE 6.
The front end of the loco is now fully dry and the next stage is to fill in the gaps highlighted by the arrow using 4 pieces of 2x2 mm wood strip.
PICTURE 7.
To cut this 2x2mm wood strip I used my Amati cutter which was the first unit that came to hand. It’s not one of the better cutters I use and find that the blade tends to “bend” on its way through the cut leaving an angled cut end rather that a nice straight cut.
PICTURE 8.
While the instructions call for just 4 pieces of 2x2mm per side and then the use of filler I decided the gap left a little large for filler alone. The area will not be brass coated so on that basis I want to minimise filler as wood being what it is will expand and contract over time and that could affect this area of the build.
So in that basis I used a further piece of 2x2mm cut in half to give me a 1x2mm piece to fit this area.
PICTURE 9.
One of the very “best” and “cheapest” clamps being used here – the good old trusted elastic band.
PICTURE 10 & 11.
Having rubbed down these infills this is the end result. In the pictures the remaining gaps (that the instructions tell you to fill) are very minor indeed. At this stage they are still to be filled
PICTURE 12.
The next stage is the boiler cladding and this is where the Version 2 kit from Occre differs from the earlier release. I did mention at the outset of this project that I had started the earlier version of the kit last year but due to major fit issues it was consigned to the “scrap Bin”.
This picture though shows more or less how far I got (it was when I started the chassis the fit issues came about and the build was scrapped).
In the earlier build the boiler is clad with 2x5mm wood strips but in the revised version we are given and told to use 2x3mm wood strips.
PICTURE 13.
“RECOMMENDATION”
Because we are dealing with very similar wood strips in terms of size (2mm & 3mm for instance) you may find an ordinary ruler does not always provide the measuring accuracy required.
What I can highly recommend for your tool box is a Vernier Caliper as you can see in this picture. It’s a really useful measuring instrument for internal and external as well as depth. Once you have something like this it will last a lifetime if well looked after.
PICTURE 14.
NOT ADDED
PICTURE 15.
To get the planking on even I have loose fitted the axle supports to allow the first couple of planks to be fitted nice and symmetrical. Because these need to be removed and fully painted in the next instalment or so it does mean at this stage I cannot fully clad the boiler.
Again elastic bands act as a suitable clamp while the glue on these planks is left to fully dry.
PICTURE 16.
Overhangs on the plank ends need to be very carefully rubbed down. I have gone as far as I can with the “heavy duty” paper on this end and will switch to a much finer paper to finish off in my next build session.
It’s really important here that we do not deform the MDF end plate or you will end up with gaps when it comes to gluing on the firebox and smoke stack ends.
You are also instructed to rub down the boiler sides to knock of the sharp edges of the planks. This needs to be very carefully down to ensure you do not put any flat spots on what should be a rounded boiler.
PICTURE 17.
And just to give an overview once the boiler is fully clad and rubbed down this is how the smoke stack and firebox components will be glued on.
Looks a bit of a “strange beasty” at this point I must say.
PICTURE 18.
The cladding of the boiler parts to provide the multitude of bolt heads on this version of the kit will be done with brass etch. In the earlier kit this feature was added by using rounded headed nails glued into pre-drilled holes on the ply parts in that particular kit.
This brass is extremely hard and a pronounced curve on both sheet supplied.
PICTURE 19.
To cut through the etch tabs you could at a press use a sharp craft knife but as the etch is thick and hard my preference is a pair of photo etch scissors which in this case are made by Xuron of the USA.
Well that is as far as I have progressed this week. Lots more to do and I hope to be able to post a further update next Sunday.
#30 Posted : 15 January 2017 20:05:17
BigGrin Starting to look like an engine now, nice workCool
#31 Posted : 15 January 2017 20:10:33
Many thanks .
#32 Posted : 15 January 2017 20:38:24
BigGrin Well done Tony it looks a very complex build Cool . Looking forward to seeing your next update Cool
#33 Posted : 15 January 2017 22:16:35
Really nice work Tony, making good progress.
I'll have to have a look at those PE scissors, I've got a pair of the Xuron Pro side cutters, they aren't cheap but have to be the best pair of cutters I've owned Cool
#34 Posted : 15 January 2017 22:19:02
Martyn/Dave
Many thanks for the kind comments.
Hopefully next installment might see the first of the colour being added.
#35 Posted : 15 January 2017 23:52:52
Looking great Tony,
these kits look deceptively simple on paper, but once you start building them they are quite tricky.You are doing an excellent job.
#36 Posted : 16 January 2017 08:34:07
Hi Tony,BigGrin
Progressing well Cool
This diary is well set out and a pleasure to follow.
Some nice tips along the way and I can also highly recommend a vernier gauge as an addition to a tool kit. They are readily available on the web and come in varying quality so don`t just go for the cheapest. I went for a digital LCD readout version to aid the old eyes.Blink
Keep up the good work, I`m looking forward to the next update.
#37 Posted : 16 January 2017 09:15:38
Carl/Derek
Many thanks for looking in.
#38 Posted : 17 January 2017 13:09:15
Excellent work so far Tony, looking really good, well done. Drool Cool ThumpUp
I keep meaning to get myself a pair of those Xuron etch scissors, they look very good, how have you found them, useful or not? Cool
#39 Posted : 17 January 2017 13:53:15
ModelMania wrote:
Excellent work so far Tony, looking really good, well done. [tasty] Cool ThumpUp
Kev
At first i held off buying xuron as they are slightly expensive but in the end other things i was using either packed up on me or were useless. I purchased a set if these and they perform really well. The blades get into some of the odd sngles you find on etch frets as well. The only thing to watch out for is that you cut were you need to cut because these things will slice through very easily.
Been so impressed with the range i added in the xuron side cutters great for plastic model kits, the needle nose pliers and a set that holds model ship pins.
Been a while collecting these as i have to save my pennies but will say they out perform many of the cheaper cutters so will pay for themselves in the long run.
I will try and remember to post some pictures in my next update.
#40 Posted : 17 January 2017 14:36:13
Looks a very interesting build and watching what is a pile of wood take shape into a famous loco, well done so far Cool
Guest (29)
10 Pages <1234>»
This page was generated in 0.371 seconds.
