Occre Lisboa Tram and Dio Options
#1 Posted : 16 January 2017 11:54:43
Hi All,BigGrin
Purchased this kit and dio some while ago, which is currently residing in the stash. Decided to open up the very heavy boxes to see the content and share my thoughts with you. Also sorted the numerous bits of strip wood and frets whilst open.
On first inspection there are some bits I may change materials on/alter.
The tram decals being the first. As they are two dimensional, I will look into detailing the sides of the tram and just use the decal signage.
On the dio, the black plastic tubing for pipes etc, will most probably be exchanged for dowl or maybe even brass tube if I can get the correct size to fit the rest of the parts. I`m also looking at changing the paper cut out clothes on the washing line for some real material ones,we`ll see.
On first inspection this kit looks to have plenty of detail and the metal parts look pretty clean too. For now it`s back to the stash.Blink Blink
So, some pics:
The tram kit
1:Tram Artwork
2:Open box
3:Detail box
4:Wooden frets
5:Strip wood
6:Wood blocks (some pre-shaped)
7:Seat covering,Decals and glazing
The Dio
8:Dio Artwork
9:Wooden frets
10:Strip wood and plastic tubes
11:Brass wire, etch and twine
12:Paper decoration sheets
bugsec
#2 Posted : 16 January 2017 16:17:19
Was on one of these last summer in Lisbon and been thinking about getting one. Saw the tram online for £49.99 just after Xmas but took too long to do anything about it and it's back up to £79.99. Cursing
It looks a cool kit.
Graham
#3 Posted : 16 January 2017 16:28:21
Nice looking kit, will be interesting to see the build.BigGrin
#4 Posted : 16 January 2017 17:42:08
Interesting lookimg kit, should build into a cool diorama Cool
#5 Posted : 16 January 2017 21:35:50
Brilliant to see another occre fan Derek.
I have most of the tram kits in the stash as the pricing and unusual subject matter is almost a must.
What is interesting to see is that in some of the new versions they are switching to self adhesive decoration rather than the paper versions.
I have the london tram and i think the difficult bit will ge trying to match the maroon colour on the paper decorations to a paint that is the same.
The diorama kits look brilliant i must say and provide the builder with such a scope to expand on.
Hope when you get to building this you have some great fun.
One small suggestion i would make before storing them is just check all the parts are in the kit. Occre are good at replacing missing or damaged parts though i must admit.
#6 Posted : 16 January 2017 23:01:00
Now this will be worth watching, looks a very detailed kit Derek..... Good luck with it.....Cool Cool
#7 Posted : 17 January 2017 03:32:54
Nice looking diorama there DerekCool look forward to seeing it progress.
#8 Posted : 17 January 2017 12:35:47
Looks a comprehensive kit and a 'builders' model that in the right hands should turn out a beautiful end result.
#9 Posted : 17 January 2017 21:31:58
Hi looks a great kit,and with the coaches.and display.will make up into a fantastic model when complete.hope it fits together well.after doing the london tram with all its fit issues.look forward to the build on this.cheers mick .BigGrin
#10 Posted : 18 January 2017 06:38:46
Thanks All for looking in and comments.Cool
Looks like this may start a bit earlier than I had anticipated.Blink
Reason: The parts I need to get the Vic carronade somewhere near where it should be, have been ordered and some bits are on back order and/or not available elsewhere.Crying
Still, shouldn`t take long to finish when the bits do finally arrive.
Hopefully this kit is "in the right hands", but only time will tell.
Mick, I remember the issues you had with the London tram and will be carefully looking for any pitfalls before I fall in them. Thanks for the reminder though.
So, watch this space and we`ll see what happens.
#11 Posted : 21 January 2017 15:09:06
This way to the build.BigGrin
Lisboa Tram Dio
This page was generated in 0.195 seconds.
