16 Pages <1234>»
Eaglemoss Delorean Options
spike
#21 Posted : 18 January 2017 18:16:31
Next we take the shorter trim and align it with the 2 holes on the outside of the wing. Press the trim firmly into place and add 1 AP screw. That completes the front wing for this stage.
spike attached the following image(s):
Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
#22 Posted : 18 January 2017 18:43:45
Great start to your diary spike Cool well done.
#23 Posted : 18 January 2017 18:59:15
Hi Spike,BigGrin
First, apologies as I missed the start of your diary.Blushing
Looks like your off to a good start though and I hope you enjoy the rest of your build.
I have now awarded your "Blue" medal for starting a diary.
Congratulations Cool
spike
#24 Posted : 18 January 2017 19:05:28
Next we do the same as in issue 1, take the 4 light parts and clip them into the corresponding spaces in the frame. Push the assembled frame into the left side socket on the rear section. Make sure the plastic lip of the frame goes in first, secure the frame in place with 1 BP screw.
Thanks for looking.
Duane
spike
#25 Posted : 18 January 2017 19:14:23
Last thing to do for this issue clip the assembled numberplate, holder and base into the space between the two light panels. The plate should fit neatly into the rear section. Use 2 AP screws to secure the plate in place.
Thanks for looking.
Duane
spike
#26 Posted : 25 January 2017 14:16:24
Issue 3
Parts -
Tyre
Hubcap
Rim
Hub
Washer
4x BP Screws
Thanks for looking.
Duane
spike
#27 Posted : 25 January 2017 14:18:50
Push the rim into the centre of the tyre. The part should fit snugly.
Thanks for looking.
Duane
stevegbr
#28 Posted : 25 January 2017 14:21:33
Looking good spike. I am still waiting for issue two. Did the trim line up ok on the wing . Some builders Have had problems.
spike
#29 Posted : 25 January 2017 14:23:32
Press the hubcap into the rim. Fit the hubcap in place with 3 BP screws.
Thanks for looking.
Duane
spike
#30 Posted : 25 January 2017 14:31:09
Push the washer into the hole in the rim making sure he washer is flat. Then push the hub into the hole it should click firmly into place. That completes the wheel.
Thanks for looking.
Duane
spike
#31 Posted : 25 January 2017 14:41:45
Thanks Stevegbr, I have been getting my issues from the news agents after the problems i had with the 3D printer and the Nissan. I had problems with the small trim it wouldn't fit flush (still doesn't) i had to sand in the fitting. The metal parts are not that good.
Thanks for looking.
Duane
spike
#32 Posted : 25 January 2017 14:51:20
Why the wheels fold down i may put some LEDs at the back of the rims. Is any 1 else thinking of doing the same?
Thanks for looking.
Duane
eebygum
#33 Posted : 25 January 2017 15:04:01
Hi Spike
Nice build looking good well done. I will follow this with interest
Rgds
Terry
#34 Posted : 25 January 2017 15:06:56
Great update spike BigGrin i`ve just received 4,5,6,7 Cool waiting for the first 3 they have sent themCrying ,like the idea of the led`s will watch with interestDrool Drool Cool regards Phil
spike
#35 Posted : 25 January 2017 15:17:18
eebygum wrote:
Hi Spike
Rgds
Terry
Thanks eebygum
Thanks for looking.
Duane
spike
#36 Posted : 25 January 2017 15:21:55
Thanks, Eaglemoss are good at messing about, hope you get your issues soon. I don't like the looks of the Mr Fusion looks just like it was on the test issue and it had loads of complaints about the screws showing on one side. Is that still the same?
Thanks for looking.
Duane
#37 Posted : 25 January 2017 15:27:27
ye thats the way in the instruction s Crying will have to fill those me thinks SpikeCursing Cursing i`ve not opened any parts as yet Cool so i can`t get a feel of the quality of the partsCrying Phil
spike
#38 Posted : 25 January 2017 15:37:15
Yes i think filling the holes is the way to go and put a decal on that side. The parts are not that bad but the metal parts could be better, the Nissan and Mustang parts are alot better.
Thanks for looking.
Duane
#39 Posted : 25 January 2017 15:58:56
Nice update spikeBigGrin will be following with interest.
greyhawk
#40 Posted : 25 January 2017 16:54:38
16 Pages <1234>»
This page was generated in 0.271 seconds.
