29 Pages «<1011121314>»
karls new victory build Options
tom.ganc
#221 Posted : 30 January 2011 13:08:53
It's looking really good karl :)
Can't wait to see more.
How manu ships do you build at the same time ?
Foz
#222 Posted : 30 January 2011 14:07:37
Karl
Thats looking really impresive, i really like the venear you have put on, really makes the build stand out.
Another question, how much venear did you get to cover the whole hull?
Keep the pics comming
foz
benny
#223 Posted : 30 January 2011 19:51:07
hi karl looks good..are you goning to fill in the gaps with filler or varnish.and the lipstick looks good same as my build..remember?isnt sarcasm greatLOL BigGrin .cheers benny
cheers benny
#224 Posted : 31 January 2011 10:38:49
tom,I'm building 4 ships at the mo.
foz,73 lengths of mahogany 5mm. x .06mm.x 1000mm.
benny,that was not sarcasm,that was me being funny,when I master the englasy languige,and learn to speel,you will realise that,I try to be witty,but get mistaken
for sarcasm.hope I hav'nt offended you.
the gaps will be dealt with by the old tried and tested method,run a slither of glue along the gap,then gently sand over it,leaving the saw dust to fill the gaps.
benny
#225 Posted : 31 January 2011 15:13:49
not at all karl thats what i meant too..i thought it did look like lipstick...ahh ok i thought you would do that with the gaps..i also had some gaps and your right it does work..when i said varnish i meant stain wasnt sure what route you were going to take..cheers benny
cheers benny
#226 Posted : 10 February 2011 21:34:58
just completed the wales,middle and bottom one,and the keel is now in place.
#227 Posted : 10 February 2011 21:36:17
#228 Posted : 10 February 2011 21:37:42
and the gallery is now in place.as you can see,I had an accident with it,the old vic slipped of me lap and broke the gallery on two sides,repairs on going.
#229 Posted : 14 March 2011 10:15:25
starting on the decking.
#230 Posted : 14 March 2011 10:16:35
the front bits are nearly finished.
#231 Posted : 14 March 2011 10:17:53
starting to take shape.
#232 Posted : 14 March 2011 10:19:26
#233 Posted : 14 March 2011 10:20:46
deck almost finished.
#234 Posted : 14 March 2011 10:24:02
Very nice in deed Karl, I am really impressed mate...keep the pictures coming...ThumpUp
Venice
#235 Posted : 14 March 2011 10:43:00
That looks really good Karl
Present Build:
H.M.S. Victory
H.M. Bark Endeavour
Photobox build album
It cant be that bad, what do you mean it's sinking
#236 Posted : 14 March 2011 11:00:43
Karl, you need to put an infil of deck planking to the rear of the main mast, which should stop half way across the first deck beam it reaches.
Issue 45 contained a magazine typo error which I highlighted in my build diary, which is at step 19 on page 13, the text should read to plank to frame 25 not 24.
Which is why you have a shortfall in deck planking in this area, which is likely to be visible when the next deck is installed as there will be a cut-out in this area.
Venice
#237 Posted : 14 March 2011 11:16:45
All hail God Tomick, what on earth would we do without you!!!
Present Build:
H.M.S. Victory
H.M. Bark Endeavour
#238 Posted : 14 March 2011 13:05:55
thanks mr.t I did read that ages ago but forgot,(old ager again)Blushing
#239 Posted : 14 March 2011 15:59:53
planked to the correct place (I hope)
#240 Posted : 14 March 2011 16:01:21
that the dolphins done.
Guest (13)
This page was generated in 1.488 seconds.
