33 Pages «<2526272829>»
Sticky Wickett
#521 Posted : 23 January 2017 15:26:14
Brilliant build so far Mo. This will turn out to be a super model.
Regards, Phil W.
#522 Posted : 23 January 2017 20:41:25
Lovely work Mo.
You could get one of those cans of compressed air and spray the dust away with that, or if you have an airbrush just ramp the pressure up and blow away BigGrin
Mo
#523 Posted : 23 January 2017 23:08:33
Didn't know you got compressed air cleaners, Just been on e bay and bought a couple of cans, Will report back on the results.
Thanks for your comments.
Mo
davetwin wrote:
Lovely work Mo.
Mo
Mo
#524 Posted : 23 January 2017 23:15:07
I keep finding things I have made, The launch has turned up ! ! ! another thing thats not finished, Will have to get all the loose ends up to date, and read the manual to see whats next.
A broken capstan need repairing
[/URL]
The Launch and other bits
[/URL]
Mo
Mo
Mo
Mo
#525 Posted : 26 January 2017 15:57:59
Doing the last 3 cannons on the deck, I cannot believe I did not do them when I did the rest, Its a nightmare trying to do it with the masts fitted, But getting there.
[/URL]
[/URL]
Mo
Mo
Mo
#526 Posted : 26 January 2017 21:30:01
Front of the deck nearly complete.
[/URL]
[/URL]
[/URL]
Mo
Mo
Mo
#527 Posted : 26 January 2017 21:36:07
At the back of the chimney for the stove, I have to make a handrail / Balustrade. to match the one at the other end.
Next Job.
[/URL]
Mo
Mo
#528 Posted : 26 January 2017 21:37:21
Looking good Mo, nice progress....Cool Cool .. These ships do get very dusty during construction and I simply use my airbrush for a clean up, works a treat....Cool Cool .. Look forward to seeing your next update.....Cool Cool
Mo
#529 Posted : 27 January 2017 11:11:58
Here.
[/URL]
Using two bit for the handrail, one glued on top of each other.
[/URL]
[/URL]
Cut little blocks and glued the base rail in place after staining
[/URL]
[/URL]
[/URL]
I am making the bell tower out of turned columns
[/URL]
[/URL]
And putting the bell on a rope.
[/URL]
Mo
Mo
Mo
#530 Posted : 27 January 2017 23:07:11
The decks are almost complete, still waiting on material to do a couple of jobs, Like complete the handrail, and I have 6 Posts to make and fit on the foredeck. But the captain is now repaired.
All in All very happy with the progress.
Mo
[/URL]
[/URL]
[/URL]
[/URL]
Mo
#531 Posted : 27 January 2017 23:40:21
I'd be happy with the progress too Mo, she's looking fab....Cool Cool .. Great work....
#532 Posted : 27 January 2017 23:49:54
Awesome update mate. She looks stunning.
Chris Cool
#533 Posted : 28 January 2017 01:34:07
Great update and some very nice work.
WTG Cool Cool Cool Cool
Mo
#534 Posted : 28 January 2017 07:17:18
Thanks Magpie, Gandale & Delboy for your comments, I would like to start on the rigging, but have to get all the work on the hull done first, Quite a bit still to do,
However " slowly slowly catchy monkey " as they say
Mo
Mo
#535 Posted : 28 January 2017 09:51:39
Mo
What a wnderful job you have done with this build it really does look fantastic.
Hope it all continues well for you.
Mo
#536 Posted : 28 January 2017 17:30:01
Thanks for your comments tony,
Mo
birdaj2 wrote:
Mo
Mo
#537 Posted : 28 January 2017 17:37:27
BigGrin Looking good Mo lovely work Cool
Mo
#538 Posted : 28 January 2017 17:39:00
Bit more of an update.
Started to do the chains to the " chainwales " is that the term ?
Not happy at all with the result. Going to have to think up something better than this, Will keep you posted, While I think I am going to get the gunport lids made up.
The height of the boat is to low for me, so I have blocked it up to get a more comfortable position, I think the chainwales are going to take sometime
[/URL]
[/URL]
Cut out the lids, sanded them all round, and gave them a coat of light oak to both sides.
[/URL]
I stuck the hinges on with superglue, before I bored the holes through the lids to accommodate the pins
[/URL]
[/URL]
Again I glued the pins in, then later snipped them of and filed down, Bored the hole for the rope, a small knot and done.
[/URL]
[/URL]
Mo
Mo
Mo
#539 Posted : 28 January 2017 22:56:08
I have worked out what to do with the chains.
[/URL]
[/URL]
Think is is going to be a long job.
Mo 🔜🔚
Mo
#540 Posted : 28 January 2017 23:13:01
Your attention to detail is making all the difference.... very nice work....Drool Drool
Guest (18)
This page was generated in 0.303 seconds.
