Copper mesh Options
haggisKiller
#1 Posted : 13 February 2011 23:27:18
Anyone know where i could buy some of the copper mesh used in the yamato radar installation?
#2 Posted : 14 February 2011 09:13:27
Its actually brass and its not an off the shelf item other than you might find something similar
Mike Turpin
#3 Posted : 14 February 2011 10:03:16
Brass Mesh
Would this link be of any use?
Mike T
willie
#4 Posted : 14 February 2011 10:18:06
also from cornwall models
#5 Posted : 14 February 2011 10:19:23
Its similar but is a woven type, whereas the type being sought is a brass photo-etch flat mesh, though there should be something on that site which should suffice, might be a case of getting similar rather than identical because it also needs to be in scale.
haggisKiller
#6 Posted : 14 February 2011 11:16:07
Thanks for the replies, will check out cornwall models first for the mesh
dazarooney
#7 Posted : 25 June 2012 11:28:52
Rank: Newbie
You might find what you're after from here:
http://www.perforated-wire-mesh.com/
#8 Posted : 25 June 2012 23:16:04
BigGrin Why not just reorder the part you needCool
This page was generated in 0.100 seconds.
