16 Pages «<56789>»
MFH 1/12 Shelby AC Cobra 'C' Caravan Multimedia Dio Options
#121 Posted : 29 January 2017 22:08:15
Another great update.
Its coming along at a pace and is so nicely detailed.
#122 Posted : 29 January 2017 23:46:45
BigGrin Thanks for looking in and your comments both very much apreciatedCool
eebygum
#123 Posted : 29 January 2017 23:49:14
this build is looking superb good job!!!
Rgds
Terry
RM1
#124 Posted : 30 January 2017 06:42:24
Hi Andy, The build is looking fantastic. How did you get the Aluminium look on the boot panels? is it a polishing of the die cast part?
Malc.
#125 Posted : 30 January 2017 22:29:56
BigGrin Thanks for looking in both of you and your commentsCool
@ Malc, Here's how I achieved the mottled effect on the panels also the rear parts that are have the aluminium finish are resin parts.
A while ago now I bought some of Vallejo's Chipping Medium and noticed if applied straight from the bottle even on washed parts you would get the effect of pooling/ patches uncovered parts as if there was oil on the parts surface. I then experimented and after several tries I could get the overall effect effect that's on the panels.
Because the chipping solution is water based you need to let it dry out completely then use a car undercoat that's oil based to seal it. Once the undercoat is fully cured just paint as normal with water based paints.
By the way if you dilute the Chipping Medium it covers as it should without pooling. Hope this helps.
#126 Posted : 30 January 2017 23:09:34
Powering ahead beautifully Andy, she's certainly coming to life.... great work...Drool Drool
#127 Posted : 30 January 2017 23:10:39
That looks fantastic Andy.I think the aluminum parts look really good.Aluminum is such a hard finish to get right and you have nailed it.
looking forward to seeing that iconic body shell and color although it seems like a shame to cover up the masterpiece of a chassis
#128 Posted : 31 January 2017 08:37:44
Awesome work Andy. Nice detail. Your doing a great job of reproducing the look of her.
Chris Cool
#129 Posted : 31 January 2017 21:38:33
BigGrin Thanks every one for looking in and your kind wordsBlushing
#130 Posted : 05 February 2017 20:09:10
On with the build, the central floorpan/cockpit area was first painted then the faux suede carpet added this was then fixed to the chassis. next the pedal box was fixed and the cover added along with the throttle pedal and linkage to the carburetta.
The steering shaft was added next along with the gear stick, brake, extinguisher and battery. The brake handle and gear leaver top material is heat shrink tube simple slide over heat and trim off the excess. The decal was then added to the top of the gear lever along with the Cobra body decal. MFH do provide an etch plate for the body decal but its half the size it should be so I didnt use it.
Made up the radiator assembly,placed some engine cooling/oil pipework and added it along with the body pipe work and fire wall. Next its adding the inner front wheel wells and the assembly of the dash and steering wheel.
More soon
#131 Posted : 05 February 2017 20:20:12
awesome Andy.
Really like the carpet effect on this one. Looks totally in scale. Was this part of the kit or is it something you have added as an extra to your build?
#132 Posted : 05 February 2017 20:25:08
Hi andy this just gets better and better,such great detail in this kit.an going at fair pace.do you ever sleep.Blink cheers mick.BigGrin
#133 Posted : 05 February 2017 20:30:50
Drool Drool Drool Drool
Stunning stuff, WTG.
Cool Cool Cool Cool
#134 Posted : 05 February 2017 21:03:51
She's looking amazing Andy, fabulous work....Drool Drool
#135 Posted : 05 February 2017 21:48:37
Awesome update Andy, this is really coming along nicely. The detail in it is fantastic Drool
#136 Posted : 05 February 2017 22:29:38
Looking fabulous Andy Cool awesome detail.
#137 Posted : 06 February 2017 08:57:43
Looks Brilliant AndyDrool Drool love itLove Love regards PhilCool
#138 Posted : 06 February 2017 15:29:28
Fantastic update, it really is starting to take shape now.Drool BigGrin The detail in this kit is superb. Carpet could do with a hoover though!LOL Flapper BigGrin
#139 Posted : 06 February 2017 21:40:39
BigGrin Thanks for looking in and your comments everyone.
@ Tony the kits comes with 2 sheets of the cloth but it can be bought as a separate item.
http://www.hiroboy.com/A...P912--product--647.html
@ Nem its like all carpets every bit you dont want on them is drawn like a magnet to itLOL
Coser
#140 Posted : 06 February 2017 21:47:47
Great build, I've been watching along.
Aren't there small vacuums for cleaning keyboards? Wouldn't one oif them be of use here to clean the carpets? I'd do it regularly to prevent anything sticking, but particularly before you close off any bodywork.
Keep up the great work, I'll be interested to see how it continues.
Current Builds
Hachette: T800 Endoskeleton
Finished Builds
Guest (24)
16 Pages «<56789>»
This page was generated in 0.199 seconds.
