8 Pages «<23456>»
USAF 70th Anniversary build 1947-2017 Options
#61 Posted : 25 January 2017 23:08:59
Nice work, that cockpit looks great.
#62 Posted : 26 January 2017 09:34:38
Looking great and nearing the end of the first, should lok an amazing display Cool
#63 Posted : 30 January 2017 13:28:36
Hi Carl.
Looking very nice. really great work on the cockpit.
Ian Cool BigGrin
#64 Posted : 31 January 2017 17:08:04
Coming along nicely CarlThumpUp
#65 Posted : 01 February 2017 16:21:06
OK the canopy has been added and the landing gear.The cockpit glass fit was not that great so I used some filler the blend it into the fuselage.
I started priming with Tamiya white surface primer.Once I have got a good covering and made sure all the seams are gone and panel lines are back I will be using testors gloss white for the top coat.
#66 Posted : 01 February 2017 16:43:24
Looking great CarlBigGrin Cool Phil
#67 Posted : 01 February 2017 17:47:24
Nice looking model.
Going to be a wonderful diplay full of colour when complete.
#68 Posted : 01 February 2017 19:20:53
I do like the stage where you add primer and its all one colour, the build starts coming to life. Nice work!BigGrin
#69 Posted : 01 February 2017 21:58:23
Another great update, coming along really nicely...Cool Cool
#70 Posted : 01 February 2017 23:00:14
Real nice paint job carl.
Looks Great.
Chris Cool
#71 Posted : 02 February 2017 15:03:58
Coming along nicely Carl Cool
#72 Posted : 13 February 2017 00:37:01
Now the T38 is going to be in the spray booth for a while getting a gloss coat I am moving on with the next kit
F84F Thunderstreak
This is a kinetic kit.I added in an Aires resin cockpit set and a correct nose piece.The kit is pretty simple.The panels lines are a bit heavy , but I will be using Tamiya spray lacquer for this one so I think once the paint is applied the lines will look less noticeable. Fit seems pretty good so far, but the parts are quite thick with pretty big sprue attachment points.
#73 Posted : 13 February 2017 08:21:29
Looks a nice kit CarlBigGrin and those resin updates will make a differenceDrool Cool it`s going to be a jet assembly lineBlink LOL regards PhilCool
#74 Posted : 13 February 2017 09:39:00
Its like watching an aircraft production line, keep up the good work, should be a fantastic end result Cool
#75 Posted : 13 February 2017 15:03:00
Nice work on the Talon, look forward to seeing more on the thunderstreak.
#76 Posted : 13 February 2017 19:09:10
BigGrin Looks a nice kit and the extra's will bring her to lifeCool
#77 Posted : 13 February 2017 19:22:23
Model 2 is a nice looking aircraft.
Hope it all goes together well for you.
#78 Posted : 13 February 2017 21:33:22
Boeing factory eat your heart out, we got a Carl!LOL Coming along nicely!BigGrin
#79 Posted : 13 February 2017 22:34:27
Nice to see everything in full flow Carl, looking great....Cool Cool .. Look forward to your next of many updates.....Cool Cool
#80 Posted : 14 February 2017 19:40:19
The resin cockpit is painted now.The instrument panel needs to be fitted and then you need to do some surgery to the fuselage sides to fit the resin cockpit.
Guest (11)
8 Pages «<23456>»
This page was generated in 1.316 seconds.
