 Rank: Pro  Groups: Registered
Joined: 04/07/2016 Posts: 297 Points: 897 Location: UK
greyhawk wrote:Shame the lettering on the tyres is damaged already. I no and its a print  so it can't be sorted out. I will just have the good side showing. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Joined: 19/05/2015 Posts: 1,419 Points: 4,272 Location: Darmstadt, Germany
spike wrote:greyhawk wrote:Shame the lettering on the tyres is damaged already. I no and its a print  so it can't be sorted out. I will just have the good side showing. Have you contacted EM about a replacement? That at least works correctly in my experience.
greyhawk wrote:spike wrote:greyhawk wrote:Shame the lettering on the tyres is damaged already. I no and its a print  so it can't be sorted out. I will just have the good side showing. Have you contacted EM about a replacement? That at least works correctly in my experience. I don't like the idea of contacting EM for a replacement as i will get the same old story off them we will send you one out and it takes a few months before i get it, or sorry none in stock we will send one out soon as they come back in. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
i would contact them, now matter how long it takes, you will have some spares.
Update on adding LEDs to the wheel, i had a blue flashing LED bulb laying around so i did abit of testing. I have ordered some warm white LED strips to see how they turn out. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
I also rang EM about the wheel they are sending me a new one out. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Joined: 30/01/2017 Posts: 21 Points: 58 Location: wiltshire
Hi I see that Japan will getting the yellow plutonium case in there build. i am not happy UK will not be getting it in ours. https://youtu.be/oQu8Rz9cnv4 grumpy1 attached the following image(s):
Issue 4 Parts - Mr Fusion Chamber (Large Clear Part) Mr Fusion Chamber (Small Clear Part) Mr Fusion Side (Left) Mr Fusion Side (Right) Mr Fusion Lid Mr Fusion Hatch Mr Fusion Chamber (Bottom) Hinge (Red) Hinge (With Hole) Hinge (Small) Reactor Disk 1 (Bottom) Reactor Disk 2 (Top) Reactor Disk 3 (Lid) Reactor Disk 4 ( Clear Part) Bodywork 2x Springs 6x DP Screws 3x CP Screws 18x AP Screws spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Fit the Lid of the reactor into the centre of the top reactor part so that it clicks lightly into place. Turn the lid clockwise in its position so that it locks. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Lay the reactor bottom on top of the assembled part, taking care to line up the corresponding holes, then fix in place with 2 AP screws. Fix the reactor clear part to the centre and fix in place with 2 AP screws. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Push the 2 Mr Fusion sides together and fix in place with 3 AP screws. Attach the small clear part to the larger one and slot the assembled part into the gap in the Mr Fusion shell, then click the clear lid in place on top. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Take the hinge with the hole in and attach it to the Mr Fusion hatch using 2 AP screws. Fit the Mr Fusion bottom to the hatch and fix in place with a AP screw. Then attach the Mr Fusion shell to the hatch using a AP screw. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
It's good to see how you're getting on and thanks for the careful build guide.
I've signed up now but I'm hearing that there are a good few complaints about quality both here (UK) and in Japan. Also, we aren't getting all the extra's that Japan are.
Hopefully it will improve and be ok or I might be jumping ship.
Clip the short hinge into the red hinge and add 2 CP screws. Click the hinge into place on the Mr Fusion bottom part, fix with a AP screw. Take the 2 springs and place them onto the 2 red shafts on the red hinge, fix the springs into place with 2 CP screws. Align the assembled Mr Fusion with the corresponding holes on the bodywork and fix in place with 3 AP screws. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
roymattblack wrote:It's good to see how you're getting on and thanks for the careful build guide.
Hopefully it will improve and be ok or I might be jumping ship. Hi roymattblack thanks for looking. The parts are not that bad but they could have been improved alot. I did see some extras that were added to the Japans model, they may add some extras for the UK model but would probably be in special issues. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
I really don't understand WHY the UK misses out on various extra's that Japan gets. Even with the DeAg McLaren, Japan were offered different tyres. Not the UK.
Joined: 27/02/2016 Posts: 138 Points: 429 Location: milton keynes
a member of the facebook page (Thanks Ben) has been in contact with eaglemoss the last few days and has posted back a reply conforming that uk subscriber WILL now be getting the Plutonium case in our build and it will be at the end of the subscription issue not confirmed yet. So that great news for uk builders Current builds: Eaglemoss DeLorean, Deagostini R2 D2 Build
Bobbaf3nn wrote:a member of the facebook page (Thanks Ben) has been in contact with eaglemoss the last few days and has posted back a reply conforming that uk subscriber WILL now be getting the Plutonium case in our build and it will be at the end of the subscription issue not confirmed yet. So that great news for uk builders Thanks Bobbaf3nn for the update. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
LED lights came today i went with yellow instead of warm white. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Looking good, coming along nicely.... Regards Alan
Guest (7)
