21 Pages <12345>»
maurizio67-mp4/4 build diary Options
maurizio67
#41 Posted : 03 February 2017 10:30:11
frah2o wrote:
The detals are faboulous! Love
Speaking with Maurizio last night we are looking for a solution for create the purple collar on the hose under the wastgate airbox.
I've seen that details on RM1 building, but i don't underdtand if is a transkit ready or a self made item.
Anybody knows about it?
I'm trying various solutions to solve the problem, I hope someone can indicate suggestions
maurizio67
#42 Posted : 03 February 2017 10:36:09
I saw that no one was coated with carbon the caissons of the radiators, in reality, are coated with a textured carbon fiber end, I checked the model of the McLaren MP4 / 4 scale 1/12 Model Factory Hiro, and the black parts of the radiators are carbon fiber
RM1
#43 Posted : 03 February 2017 10:46:08
Hi Maurizio,
I made those clamps from 50 micron thick steel shim stock. I cut a strip 4.5mm wide and drilled 3 or 4 holes ( I think it was 3mm diameter ). The drilling is tricky in thin sheet so I clamped the piece between thin wood pieces, marked it out and drilled. I then rolled it around a rod to get the size and when satisfied with that I sprayed with Tamiya metallic red, lightly to get the effect I wanted.BigGrin
I hope that this info helps. Looks like your build is coming along nicely.
Malc.
maurizio67
#44 Posted : 03 February 2017 10:53:22
Hi Maurizio,
Malc.
thank you so much, really useful your information :-)))
frah2o
#45 Posted : 03 February 2017 11:59:19
Hi Maurizio,
Malc.
Clear decription Malc. Very useful help!
I saw on NsxKidd' topic (i hope is a right think) that he painted to simulate this clamps.
To make the 3 holes is possible to use this tools?
frah2o attached the following image(s):
RM1
#46 Posted : 03 February 2017 13:27:52
@ frah2o, yes that's an idea to use a hole punch like the one you show. Put the piece to be punched on a hard wood ( or Aluminium ) surface and you should get a clean cut. With such a thin plate there may be some distortion. I suggest that you experiment. Maybe try a strong adhesive tape over the part and punch through the two. BigGrin Malc.
RM1
#47 Posted : 05 February 2017 06:40:45
Nice extra details BigGrin
#48 Posted : 05 February 2017 15:02:15
Nice work maurizio67 ThumpUp
maurizio67
#49 Posted : 06 February 2017 21:47:11
thank you all, the control unit do not like, I'll try to make some improvements that make me happy, if anyone is interested can see my Gallery of modellismo.net, section album fotografico- nick name striker54º .
maurizio67
#50 Posted : 14 February 2017 15:23:03
improving control units and battery
maurizio67 attached the following image(s):
#51 Posted : 14 February 2017 17:54:53
Nice work on those ThumpUp they look great.
RM1
#52 Posted : 15 February 2017 06:41:31
Great attention to the little extra's BigGrin Looks really good.
#53 Posted : 15 February 2017 09:49:35
Superb atention to detail, well done Cool
maurizio67
#54 Posted : 16 February 2017 07:39:36
the question, which tool you used to make the hole to the inside mesh radiator?
RM1
#55 Posted : 17 February 2017 06:30:26
I used a hole punch like you've shown in post #45 above. Choose the same size as the hole in the plastic part. This is illustrated in post #65 in my build diary. Use a wooden block to support the mesh.
I hope that's of help.BigGrin
Malc.
maurizio67
#56 Posted : 17 February 2017 08:46:26
thank you, you've been a real help malc
maurizio67
#57 Posted : 18 February 2017 12:05:57
Some advances until the next exit, evidence of the mounting box cooler with micro screws, and holes for inserting bolts photo engraved, the box will be coated with carbon.
RM1
#58 Posted : 19 February 2017 05:57:08
Those are good looking fittings.Cool
#59 Posted : 02 March 2017 19:40:44
Some nice touches being added, looking good....Cool Cool
#60 Posted : 02 March 2017 21:21:48
Great extra details your adding to an already great kit Cool
21 Pages <12345>»
This page was generated in 0.102 seconds.
