The wheels look soooo cool!!
Like the lighting,I think I prefer the yellow Al
 Rank: Pro  Groups: Registered
Joined: 04/07/2016 Posts: 297 Points: 897 Location: UK
Thanks for your comments  the yellow does look alot better. I will also be putting yellow LEDs in the vents and I need try get some pics of the under side of the Delorean so i can see the lighting. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Issue 5 Parts - Left Front Suspension Lower Link Control Arm Shock Absorber Coilspring Brake Caliper Positioning Column Left Front Tie Head Brake Disk Spring 2x AM Screws 2x BM Screws 2x CM Screws 3x DM Screws 1x EM Screw 1x AP Screw 1x DP Screw spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Nice job with the wheels they look wesome with the yellow LED Such a shame that you won't be getting the plutonium case as it looks really nice
Fit the lower link into the gap at the bottom of the suspension and secure in place with 2 AM screws. Pass the shock absorber up through the large hole in the lower link and add 2 BM screws. Place the coilspring on the shock absorber and lower the suspension over the coilspring and secure in place with an EM screw. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Place the control arm either side on top of the suspension, aligning the holes and fix with 2 CM screws. Position the tie head between the control arm and lower link. Align the holes and secure with 2 DM screws. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Place the spring onto the positioning column, then insert the assembly into the hole at the end of the arm on the brake disk and add a DP screw. Align the holes on the brake caliper with the holes on the brake disk and secure in place with an AP screw. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Hold the brake and suspension assemblies together and secure in place with a DM screw. Don't overtighten the screw as the brake assembly can drop down. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Great update Spike  like the leds  can`t wait to start mine  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Spike Great update. Really like the look of the parts in this kit and am tempted i must admit. Hope it all continues to go well for you. Happy Modelling
Looking good spike  still undecided whether to get this myself. Al
Thanks for looking you should go for this model the parts are good the only problem i have is with the Mr Fusion they could of added some caps for the screw holes or just made it one part. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Brilliant update - as always.
I'm collecting this one and won't start until I've got all the parts, so quite a way off yet. With Mr Fusion - I'll very probably make resin castings of the parts with NO holes, and then add my own decals. Other than that, I'm hoping for a pretty much out-of-the-box build although I just know I'll go nuts on the time machine engine and interior. There are LOADS of images on the web, so extra's will be added. A great car that I hoped would become a partwork - and now, here it is.
A shame that the TV Batmobile partwork was/is 1/10 scale. It seems to have died already. In 1/8, I would have been there!
Keep the updates coming: Loving it.
Issue 6 Parts - Right Front Suspension Lower Link Control Arm Shock Absorber Coilspring Brake Caliper Positioning Column Right Front Tie Head Brake Disk Spring 2x AM Screws 2x BM Screws 2x CM Screws 3x DM Screws 1x EM Screw 1x AP Screw 1x DP Screw spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
The parts just go together in the same way as issue 5. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Great update Spike, looking good.... Regards Alan
Spike Coming along very nicely. Impressive finish from what i can see on the parts being supplied. Happy Modelling
Joined: 18/08/2015 Posts: 294 Points: 897 Location: Amesbury, Wiltshire
Hi Spike Looking good Rgds Terry FINISHED BUILDS---- HMS Victory--Bismarck--Battleship Yamato-D51 Steam Train--Pocher Ferrari Testarossa--Soleil Royal--Schnellboot S-100--StageCoach 1848--HMS HOOD-- Delorean (Back to the Future)
Joined: 27/02/2016 Posts: 138 Points: 429 Location: milton keynes
well detailed diary spike .. Keep up the great work Current builds: Eaglemoss DeLorean, Deagostini R2 D2 Build
