Joined: 02/01/2017 Posts: 92 Points: 290 Location: Kintbury, West Berkshire
01/02/2017 - Issues #4 and #5 have arrived
Just completed the build for issues #4 and #5 - will post photos tomorrow.
Can somebody remind me what the max size photo I can post is please? Resolution and file size? Ta!
I resize mine to 800 x 600 pixels which gives a file size of 80-150 KB. Look forward to seeing your progress. Graeme
pemberg wrote:I resize mine to 800 x 600 pixels which gives a file size of 80-150 KB. Look forward to seeing your progress. Graeme Thanks - will try those dimensions!
Issues #4 & #5 So - in the week issues 4 & 5 arrived. First - no printing issues here! :-) Issue 4 was mainly covering the LED test – no issues here and test fit the ankle part and the shoulder joint – will save those for later as they are not screwed in place yet. Issue 5 starts with making R2’s head – the top metal plate and a bracket. 5 mins work completed until next month when we start receiving 4 issues and the fun starts to ramp up! Here are some photos of Issue #5 build - hopefully these will display correctly! File Attachment(s): LSainsbury attached the following image(s):
Looking good Lee. Only one picture showing, if you tick the attach file box then point the browser to the location of your pictures, it should display the all when posting. Keep up the good work. Regards Markwarren (Mark) Admin
Looking good Lee. I think your image loading issue is the file size. Resize your pics to 660 pixels width and all should show. At present you have a pixel width of 800 - 1000, hence they show as downloads. Hope this helps Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Pictures test / repost pictures....lets see if these work! File Attachment(s): LSainsbury attached the following image(s):
Man that does look fun. One of my favorite parts of the Falcon build is the frame. This one isn't for me for while though. So many other things to build and no budget for them all. Keep up the good work DeAgostini kit builds:
Issues 6,7,,8 and 9 + binder arrived....build photos to follow - tomorrow! LSainsbury attached the following image(s):
 Nicely done and plenty to do tomorrow Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice work. Looking forward to seeing more photos tomorrow. Graeme
Looking good, look forward to seeing more.... Regards Alan
So - Sunday afternoon building issues 6,7,8 and 9 - lots of small screws and nuts involved with this one but I now have a completed first ring - the head is taking shape and the LCD status display works. Does everyone else's ankle joint look like mine? It look slightly raised due to the two round plastic tabs. it's seated correctly, just looks a bit odd! File Attachment(s): LSainsbury attached the following image(s):
Hi Lee, Looks like you have the ankle detail 180 degrees out. Unsrew it, turn it through 180 degrees and refit, should then be Ok. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Here`s a pic to help. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:Hi Lee, Looks like you have the ankle detail 180 degrees out. Unsrew it, turn it through 180 degrees and refit, should then be Ok. Regards delboy271155 (Derek) Hahahaha! F***** I'm so kicking myself right now - how the .....did I not notice that!!
LSainsbury wrote:delboy271155 wrote:Hi Lee, Looks like you have the ankle detail 180 degrees out. Unsrew it, turn it through 180 degrees and refit, should then be Ok. Regards delboy271155 (Derek) Hahahaha! F***** I'm so kicking myself right now - how the .....did I not notice that!! It happens. Don`t kick yourself too hard, it hurts. Chin up and happy building. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice work. We all make the odd mistake - at least it's not a glued joint and was easily rectified. Graeme
Nice work, what mistake, really you were just testing us to see if we would notice. Hahaha. Mark Regards Markwarren (Mark) Admin
