An attempt at the stern emblem at 1/72 in boxwood, only half way there but had to have a rest. (ran out of plasters). The photo has been perspective corrected on a paint program to give a better idea of the shape. willz attached the following image(s):
 Rank: Pro  Groups: Registered
Joined: 20/03/2010 Posts: 278 Points: 833 Location: Nottingham
Great work matey!  I follow ur build as always with great interest. Pam's shipyard is closed for now no more room!
these cuts are only small but if blood gets on the carving it would be very hard to get off willz attached the following image(s):
Joined: 07/10/2010 Posts: 148 Points: 430 Location: At the back of my sinking boat
Wow!!! Present Build: H.M.S. Victory H.M. Bark EndeavourPhotobox build albumIt cant be that bad, what do you mean it's sinking
Nice work Willz, though the Prince of Wales plume of feather's did not adorn the stern of Victory in 1805, in actual fact the plume did not appear on Victory until 1837 after being salvaged from HMS Prince (also at Trafalgar). What was actually in place of the plume is still subject to ongoing research, though has been narrowed to two possibilities, either King George III's coat of arms or a medallion featuring the bust of the king, the latter is believed to be the most likely. Apparently once what was is confirmed the plume will be removed and replaced, though it is also possible that what was may never be confirmed.
I might add that the guns and flag either side of the plume is correct for the 1805 Victory.
14 plasters 3 bandages 2 stitches and a tetanus injection later, here we are. Broke the right hand side axe off as we look at it (glued it back on) so decided to leave it at that before I did more damage. lol willz attached the following image(s):
Joined: 25/03/2010 Posts: 472 Points: 1,357 Location: Hyde
WOW Simply amazing!!! I am speachless
Joined: 20/04/2010 Posts: 141 Points: 426 Location: Worthing, United Kingdom
That is just... amazing. Speechless. Great work!
Joined: 02/05/2010 Posts: 67 Points: 201 Location: Staffordshire
That is a work of art. Brilliant.
Superb work ,amazing detail, Thanks for sharing it with us .
thank for the comments lads
Back in the garage, done the first row of gun ports found it a bit tedious. Also I left out the supports where the rear gun ports are, just to give me the choice to leave them open. Done a bit on the scratch, I used a different design to shape the bows, again this will allow me to have the front gun ports open. I had to temporally pin on the top deck to give the ribs more stability for fairing. with the top deck being 5 mm I had to put grooves in the underside to allow for the camber Willz willz attached the following image(s):
W.I.P. scratch launch at 1/72 willz attached the following image(s):
Looks really good!
Hi Willz! That scratch build launch is a first class job,  how is your ship doing mate?
Realy nice build Will  z MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Son of Bulwark wrote:Hi Willz! That scratch build launch is a first class job,  how is your ship doing mate? almost sank SOB no space only garage wich is choca at the mo, keep doing the small projects to give me a push. thankyou all for the comments Willz
very nicely done wiltz,like to see a lot more of it. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Ok SOB this is where I am with the scratch, just dug it out of the garage, not much progress but you can see the stern has a different structure than the AL. The last photo shows where I build my small projects in the computer room, almost impossible to build the ship Willz willz attached the following image(s):
Guest (12)
