16 Pages «<23456>»
Eaglemoss Delorean Options
#61 Posted : 02 February 2017 22:20:19
The wheels look soooo cool!!BigGrin
#62 Posted : 02 February 2017 23:32:27
Like the lighting,I think I prefer the yellow BigGrin
spike
#63 Posted : 03 February 2017 13:14:50
Thanks for your comments BigGrin the yellow does look alot better. I will also be putting yellow LEDs in the vents and I need try get some pics of the under side of the Delorean so i can see the lighting.
Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
spike
#64 Posted : 03 February 2017 16:20:09
Issue 5
Parts -
Left Front Suspension
Lower Link
Control Arm
Shock Absorber
Coilspring
Brake Caliper
Positioning Column
Left Front Tie Head
Brake Disk
Spring
2x AM Screws
2x BM Screws
2x CM Screws
3x DM Screws
1x EM Screw
1x AP Screw
1x DP Screw
spike attached the following image(s):
Thanks for looking.
Duane
#65 Posted : 03 February 2017 16:23:00
Nice job with the wheels they look wesome with the yellow LED Cool
Such a shame that you won't be getting the plutonium case as it looks really nice
spike
#66 Posted : 03 February 2017 16:34:57
Fit the lower link into the gap at the bottom of the suspension and secure in place with 2 AM screws. Pass the shock absorber up through the large hole in the lower link and add 2 BM screws. Place the coilspring on the shock absorber and lower the suspension over the coilspring and secure in place with an EM screw.
Thanks for looking.
Duane
spike
#67 Posted : 03 February 2017 17:06:54
Place the control arm either side on top of the suspension, aligning the holes and fix with 2 CM screws. Position the tie head between the control arm and lower link. Align the holes and secure with 2 DM screws.
Thanks for looking.
Duane
spike
#68 Posted : 03 February 2017 17:33:24
Place the spring onto the positioning column, then insert the assembly into the hole at the end of the arm on the brake disk and add a DP screw. Align the holes on the brake caliper with the holes on the brake disk and secure in place with an AP screw.
Thanks for looking.
Duane
spike
#69 Posted : 03 February 2017 17:37:52
Hold the brake and suspension assemblies together and secure in place with a DM screw. Don't overtighten the screw as the brake assembly can drop down.
Thanks for looking.
Duane
#70 Posted : 03 February 2017 19:17:46
Great update SpikeBigGrin like the ledsDrool can`t wait to start mineCool BigGrin regards PhilCool
#71 Posted : 03 February 2017 20:16:54
Spike
Great update.
Really like the look of the parts in this kit and am tempted i must admit.
Hope it all continues to go well for you.
#72 Posted : 03 February 2017 21:29:33
Looking good spike Cool still undecided whether to get this myself.
spike
#73 Posted : 05 February 2017 18:14:51
Thanks for looking you should go for this model the parts are good the only problem i have is with the Mr Fusion they could of added some caps for the screw holes or just made it one part.
Thanks for looking.
Duane
#74 Posted : 05 February 2017 18:31:03
Brilliant update - as always.
I'm collecting this one and won't start until I've got all the parts, so quite a way off yet.
With Mr Fusion - I'll very probably make resin castings of the parts with NO holes, and then add my own decals.
Other than that, I'm hoping for a pretty much out-of-the-box build although I just know I'll go nuts on the time machine engine and interior.
There are LOADS of images on the web, so extra's will be added.
A great car that I hoped would become a partwork - and now, here it is.
A shame that the TV Batmobile partwork was/is 1/10 scale.
It seems to have died already. In 1/8, I would have been there!
Keep the updates coming: Loving it.
spike
#75 Posted : 09 February 2017 19:20:14
Issue 6
Parts -
Right Front Suspension
Lower Link
Control Arm
Shock Absorber
Coilspring
Brake Caliper
Positioning Column
Right Front Tie Head
Brake Disk
Spring
2x AM Screws
2x BM Screws
2x CM Screws
3x DM Screws
1x EM Screw
1x AP Screw
1x DP Screw
Thanks for looking.
Duane
spike
#76 Posted : 09 February 2017 19:22:03
The parts just go together in the same way as issue 5.
Thanks for looking.
Duane
#77 Posted : 09 February 2017 20:58:39
Great update Spike, looking good....Cool Cool
#78 Posted : 09 February 2017 21:06:36
Spike
Coming along very nicely.
Impressive finish from what i can see on the parts being supplied.
eebygum
#79 Posted : 10 February 2017 00:01:18
Hi Spike
Looking good
Rgds
Terry
Bobbaf3nn
#80 Posted : 10 February 2017 11:05:13
well detailed diary spike .. Keep up the great work
16 Pages «<23456>»
This page was generated in 0.266 seconds.
