16 Pages «<34567>»
Eaglemoss Delorean Options
#81 Posted : 10 February 2017 14:46:50
Another great update Spike Cool
#82 Posted : 10 February 2017 15:57:10
Nice update Spike
It's really good to see that the parts appear to be coming through without any missing Cool
spike
#83 Posted : 10 February 2017 19:33:05
Thanks guys for looking and your comments. I am getting my issues from the local shop after the problems i have had in the past when subscribing with eaglemoss. The parts are good quality, not as good as the Nissan parts but should be a good model when its finished. Would be nice to see a partwork for the ghostbusters ecto 1 to go next to the Delorean. I am hoping the partwork for the Subaru impreza comes to the UK that looks like a really nice model.
Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Bobbaf3nn
#84 Posted : 10 February 2017 23:47:18
Ecto 1 has the potential to be a great model but personally i'm hoping they go ahead with the 66 Batmobile that had a trial run last year
spike
#85 Posted : 16 February 2017 14:37:46
Issue 7
Parts -
Pinion
Pull Rod
Front Plate
2x Boots
Steering Rack
2x FM Screws
spike attached the following image(s):
Thanks for looking.
Duane
spike
#86 Posted : 16 February 2017 14:49:53
Fix the pinion onto the steering rack and secure with a FM screw, then fix the pull rod in the same way. Push 1 of the boots over the end of the steering rack and push it all the way down until it stops, do the same for the other side.
Thanks for looking.
Duane
#87 Posted : 16 February 2017 15:02:20
Progressing well Spike Cool
spike
#88 Posted : 24 February 2017 14:04:36
Issue 8
Parts -
Bottom Plate
Left Anti-roll Bar Base
Right Anti-roll Bar Base
Anti-roll Bar
4x AP Screws
Thanks for looking.
Duane
spike
#89 Posted : 24 February 2017 14:13:02
Push the left anti-roll bar base into the two holes on the bottom plate, turn the bottom plate over and add 2 AP screws. Do the same for the Right side.
Thanks for looking.
Duane
Coser
#90 Posted : 27 February 2017 13:03:31
A quick post on something I found out last night. Make sure both the steering rods are the correct way up.
The one that attaches to the rest of the steering is fairly obvious, but the smaller one isn't so obvious. Both of them should have a slight slope DOWN to the steering rack. The short one of mine is upside-down and slopes up. This is pulling the steering up on that side and putting stress on the other components.
Current Builds
Hachette: T800 Endoskeleton
Finished Builds
spike
#91 Posted : 27 February 2017 13:19:55
Thanks for the tip i will have check i think the small one slopes down the pics are not that good.
Thanks for looking.
Duane
spike
#92 Posted : 05 March 2017 16:57:46
Issue 9
Parts -
Tyre
Hubcap
Rim
Hub
Washer
4x BP Screws
Thanks for looking.
Duane
spike
#93 Posted : 05 March 2017 17:10:41
The wheel is put together in the same way as issue 3. I have showed how i am installing the LEDs to the wheels If any one is wanting to do the same. At the min the wheels will not be able to spin as the wires are in the way but i am trying to sort a better way so if i wanted the car to roll it can do.
Thanks for looking.
Duane
#94 Posted : 05 March 2017 18:53:20
Spike that looks the buisnessBigGrin i`v`e never done small electronics beforeConfused but i might give it a go now i`ve seen yoursBigGrin awesome Drool Drool regards PhilCool
spike
#95 Posted : 05 March 2017 19:05:51
Thanks tigerace this is the first time i have worked with LED strip lights and soldering. I don't think i did a bad job BigGrin I am thinking about adding a micro 2 pin connector in the wheel so i can have the car roll.
Thanks for looking.
Duane
#96 Posted : 05 March 2017 20:47:20
Looks very nice and neat work on such small electronic parts.
#97 Posted : 05 March 2017 23:04:48
Nice update Spike Cool the lighting looks great.
Eagle
#98 Posted : 06 March 2017 14:00:28
Red Medal: Red Medal
Great idea to add lightening to the wheels; how does it look with the wheel on, is the lighting uniform through the wheel?
A circular light 'tube' like a fluorescent lamp bulb would be ideal for this, i don't think there are any that small though Bored
spike
#99 Posted : 06 March 2017 16:40:20
Thanks birdaj2 not alot of room inside the wheel to work with.
Thanks for looking.
Duane
spike
#100 Posted : 06 March 2017 16:42:11
Thanks Spal should look good when the wheels get put on and see how the lights look.
Thanks for looking.
Duane
16 Pages «<34567>»
This page was generated in 0.419 seconds.
