Looking good Al, nice and neat, very well done. Enjoy your DVD, I have a copy of that and it's brilliant viewing, watched it many times!!
Kev
Well its time for pack 7. Here are all the parts. Added the intercooler and radiator and built up a front suspension unit. Then built the other unit and added a support to the tub. Now added the shift lever and balance lever assembly to the cockpit and mounting it onto the floor. Thanks for looking. Al Spal attached the following image(s):
Nice progress and great pictures.
great job, clean and precise, I'm still looking forward to building number five😞😞
Thanks maurizio67 Al
Pack 8 This pack mainly deals with fitting the front suspension components and test fitting the assembly into the monocoque. Also panels were fitted to the front, rear and on the inside of the assembly together with the master cylinders for clutch and brakes followed by the pedal assembly to the cockpit floor. Thanks for looking. Al Spal attached the following image(s):
Pack 9 With this pack the cockpit floor is fitted together with the brake/clutch reservoirs. The other front wheel and tyre is also put together but the majority of the work involves the front brakes and suspension/steering components being attached to the monocoque. Thanks for looking. Al Spal attached the following image(s):
Really neat work. coming on nicely. Malc.
Thanks Malc Al
 Looking good Al, by the way were you one of lucky ones that got the Senna figure aswell Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,343 Points: 22,336 Location: Northamptonshire, England
Coming on very nice Al. It looks a really good kit. Mark Regards Markwarren (Mark) Admin
Thanks Mark, it is a great kit.
arpurchase wrote: Looking good Al, by the way were you one of lucky ones that got the Senna figure aswell Thanks Andy, not too sure whether I am getting the Senna figure as I was a late subscriber. Al
Pack 10 Not too much to do this month. First the brake calipers were assembled together with the brake disc. Once done I added the pipework to the radiator ducting, this was made easier by having the thin wire inside the pipework keeping the correct shape once bent. Once the hub was built the disc and calipers were added then the shock absorbers were built and tubing added to the t piece. That's all for now, thanks for looking. Al Spal attached the following image(s):
Great Spal work, simple and clean
Looks great Al, lovely progress.... Regards Alan
Thanks for looking in guys Al
 Nice start Al Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looks like a fun build. DeAgostini kit builds:
