8 Pages «<34567>»
USAF 70th Anniversary build 1947-2017 Options
#81 Posted : 14 February 2017 20:26:15
Some nice detail in the resin parts. Cool Cool
Hope there`s not too much work for you to get the resin to fit.Blink
Looking forward to next update.
#82 Posted : 14 February 2017 21:02:17
Really nice start Carl. Looks nice and clean with lots of nice detail Cool
I'm sure this will be another great build to follow
#83 Posted : 14 February 2017 21:03:30
That`s a great looking cockpit Carl cracking jobThumpUp look forward to your next update BigGrin regards Phil
#84 Posted : 14 February 2017 21:29:52
These are coming along well. Great work being shown.cheers mick. BigGrin
#85 Posted : 15 February 2017 20:13:11
Thanks everyone,
F84F
I glued in the front of the nose piece.This includes the landing gear bay for the front wheel.There is a steel ball in this piece which prevents the model being a tail sitter.The resin cockpit doesnt fit with the landing gear piece so I sawed off some of the rear of the landing ear piece.I also painted the sidewalls.The resin cockpit doesnt fit that well so it will need a bit of fiddling around to get it in the right spot and get the fuselage sides to mate up properly.
#86 Posted : 16 February 2017 16:36:19
F84F
The resin cockpit tub is fitted.As you can see it was a very tight fit.I spent an hour fiddling to get the instrument panel fitted and the fuselage sides glued together.next step is to deal with the fuselage seams and start spraying the metal .I will be using Tamiya lacquer for this plane with some metalizer for the exhaust.
#87 Posted : 16 February 2017 17:46:03
Good job Carl Cool cockpit looks great.
#88 Posted : 19 February 2017 19:01:34
F84-G
The f84f is now having its seams fixed and soon will go to paint so I started on the Taimya f84g.This will be an out of the box build.The cockpit is pretty nice.
This kit is already painted in silver paint.I plan on seeing how it looks without paint.The wingtip fuel tanks need to be painted so I built them and sanded off the paint.
#89 Posted : 19 February 2017 19:20:43
Looking forward to your Tamiya build as i have that metal finish kit in my collection so interested to see how you work with this one.
#90 Posted : 19 February 2017 19:58:14
#91 Posted : 19 February 2017 20:48:59
Very nice update Carl, look forward to seeing how it all turns out....Cool Cool
#92 Posted : 19 February 2017 20:56:29
Making good progress Carl, great job Cool
#93 Posted : 19 February 2017 22:03:45
I think your going to be fed up with spraying silver and white colours by the time this build project is over LOL LOL
Enjoying seeing it progress though.
#94 Posted : 20 February 2017 01:49:42
Looking good. BigGrin
Brave move to strip the paint and start from fresh, but I`m sure you`ll get it to the next level.
Cool Cool Cool Cool Cool
#95 Posted : 22 February 2017 16:05:58
Hi Carl.
Cool looking good BigGrin Ian.
#96 Posted : 27 February 2017 17:46:35
Thanks everyone,
So I got an F100C kit.It was Trumpys 1/48 kit.I compared it to the F100D kit.It is almost identical except for the tail.There are no F100c thunderbirds decals, but I think I can use the F100D set that warbirds decals sells and use a bit of red paint to make the tail decal work.here are the two fuselages.The F 100C is the lower one.
#97 Posted : 01 March 2017 16:12:58
F16
I am in the process of selling some of my plastic kits and I found I already had a 1/48 F-16 Thunderbird kit, so I now have 2 of these with eduard cockpit sets.So I figured I will build one plane in flight and one on the ground.There are typical Tamiya quality.Excellent detail and perfect fit so far.
#98 Posted : 15 March 2017 17:08:22
F100C
I started work on the F100C and D. I bought eduard cockpit sets for both.Unfortunately I bought a 1/72 set for the F100D which obviously doesnt fit the 1/48 cockpit.oops.
Anyway here is the f100C cockpit with the eduard detail set added.
#99 Posted : 15 March 2017 17:11:37
I love that upgrade kit, it looks very good.
Cool Cool Cool
Nice work.
#100 Posted : 15 March 2017 18:21:34
Great update CarlBigGrin is that the self adhesive Eduard set you`ve used ?regards PhilCool
8 Pages «<34567>»
This page was generated in 0.275 seconds.
