106 Pages «<910111213>»
Sticky Wickett
#201 Posted : 14 February 2017 20:30:04
I also fashioned a vertical support from 1mm plastic sheet so I could fix the plastic profiled piece to the conning tower.
Sticky Wickett
#202 Posted : 14 February 2017 20:33:11
Using a similar technique for drawing curves and cross-referencing photos of U995 I made a profiled piece to represent the upper deck of the lower conning tower platform. It was when I got to this stage I felt that I was relying to heavily on guess work so I came to the conclusion that more research was required.
Sticky Wickett
#203 Posted : 14 February 2017 20:34:23
This picture shows the smaller of the two profile pieces fitted with the 1mm support I mentioned before.
Sticky Wickett
#204 Posted : 14 February 2017 20:35:52
This image shows the profile piece and support located against the conning tower. Dry fit only at this stage.
Sticky Wickett
#205 Posted : 14 February 2017 20:39:13
This view shows the larger piece that makes up the floor of the lower platform in place. Alas, it is too wide. After studying the U995 photos for ages I realised, as I've mentioned before, that a measured drawing or a donor model is the only way to absolutely get this part correct.
Sticky Wickett
#206 Posted : 14 February 2017 20:41:33
This photo shows the lower profile and support fixed to the conning tower and the whole assembly posed on my temporary laminate stand.
Sticky Wickett
#207 Posted : 14 February 2017 20:45:06
This picture shows the conning tower sub-assembly mounted on the laminate stand with a slightly wider 0.5mm sheet fixed underneath the tower and profile piece. This sheet acts as a support and ties the tower and profile together preventing warping and disfigurement. It protrudes about 1mm around the border of the tower and rear profile.
#208 Posted : 14 February 2017 20:45:18
Awesome update Phil BigGrin what about the 3d super drawings book from KageroCool Phil
Sticky Wickett
#209 Posted : 14 February 2017 20:49:01
Hi Phil, nice thought, but I already have this book and it doesn't feature U-boats with the type 4 conning tower. Nevermind.
Sticky Wickett
#210 Posted : 14 February 2017 20:50:58
This picture shows a rear view of the conning tower with modified profile and support. You can also see the border around the edge as mentioned previously, tying the two sections together.
Sticky Wickett
#211 Posted : 14 February 2017 20:54:24
The attached photo shows the conning tower on it's side, clearly showing the 0.5mm plastic sheet, cut to shape, holding the tower and profile piece and support together.
Sticky Wickett
#212 Posted : 14 February 2017 20:55:58
The whole sub-assembly, dowel located, on the top deck.
Sticky Wickett
#213 Posted : 14 February 2017 20:57:13
A starboard side view of the conning tower sub-assembly.
Sticky Wickett
#214 Posted : 14 February 2017 20:58:39
A 3/4 rear view of the conning tower sub-assembly.
Sticky Wickett
#215 Posted : 14 February 2017 20:59:48
Rear view of the conning tower, profile and support.
#216 Posted : 14 February 2017 21:00:10
Ah its a pityConfused just looked at the photos in the haynes manual there`s lot`s of photos in that Confused ? any how your build is just awesome BigGrin regards PhilCool
Sticky Wickett
#217 Posted : 14 February 2017 21:10:21
BigGrin Thanks for your kind words Phil. You've been extremely helpful with your suggestions. BigGrin
To be perfectly honest, I won't actually mind buying a donor model once i'm satisfied that every other avenue has been checked and it's getting to that point.
I've got to get it right after all the effort I've put in so far. Cutting a few corners for the sake of saving a bit of cash by 'making do' won't cut it in the end.
It is what it is.
It will be a challenge too; forcing me to try things I wouldn't of thought of before. It's all good! BigGrin
Sticky Wickett
#218 Posted : 14 February 2017 21:12:13
Well that concludes this part of the build.
I hope you enjoy it and thanks for looking in. More posts to follow shortly.
Kind Regards,
Phil W.
#219 Posted : 14 February 2017 21:22:15
Great update Phil, I love seeing all the work you are putting into this Drool
Have you identified a donor model yet for your measurements?
#220 Posted : 14 February 2017 21:22:44
Nice work, another great update.
This page was generated in 0.744 seconds.
