7 Pages «<567
Shaun's RC Spitfire Build Options
#121 Posted : 30 January 2017 22:11:42
#122 Posted : 31 January 2017 16:40:39
Great update Shaun ThumpUp
I really love how you are posting the step by step on how you make the rudder and elevators. It's always good to see how different people tackle things and I'm sure others will find is useful. BigGrin
Shauncnh
#123 Posted : 31 January 2017 22:14:09
BigGrin Thank you Alan, Andy and Dave for your kind words it means a lot to meBigGrin
For this update I am including issue 23 and 24.
Parts Supplied with issue 23 Cockpit canopy and screws.
The first step with this issue is to part a line 7mm from the top of the fuselage and then sand down to this line rounding over the corners.
Next two off cuts of 6mm balsa sheet are glued into the gap below the fin and then sanded back flush with the fuselage.
Next in this issue the canopy is to be cut to shape and painted but I made the decision to leave this to later in the build.
Now for issue 24
Part supplied are main wing spar, Rib 3, 8x400mm dowel, two threaded rods, unthreaded rod and two heat shrink sleeves.
First the main spar and rib are sanded. The spar is then fitted into the wing jig and rib 3 glued into place.
It is always important to check the instructions to insure the correct alignment. Luckily I noticed my mistake before the glue had set and was able to correct the mistake easily.
After this a 2mm hole is drill 30mm from the end of the dowel.
Next a 1.5mm deep groove is made in from the hole to the end of the dowel
Then a 8mm piece of the threaded rod is bent 90
The rod is then inserted into the hole in the dowel and glued into place. The heat shrink is then fitted over the end of the dowel.
These steps are then repeated on the other end of the dowel.
That completes the work on these to issues.Cool
Regards Shaun
Building-RC spitfire
#124 Posted : 31 January 2017 23:19:46
You might want to consider swopping-out the push rods and use Bowden cables instead. Another good idea for upgrade would be to put an aileron servo into each wing half rather than use a central servo to control both, this way it avoids the potential for aileron flutter.
Shauncnh
#125 Posted : 06 February 2017 22:43:55
Due to work commitments over the next couple of months I will not have much time to continue with my build.
With have sold a tractor to sharpness lifeboat station and I have be put in charge of carrying out the modifications to get it ready for its life as a lifeboat launch vehicle.
Regards Shaun
#126 Posted : 07 February 2017 08:05:03
Hi Shaun,
Great update,coming together nicely, and looking like a Spit.
Trev.
#127 Posted : 09 February 2017 12:24:26
Hi Shaun.
great update. look forward to seeing your progress when you get back to your build.
Ian Cool BigGrin
Shauncnh
#128 Posted : 14 February 2017 20:31:59
Thanks Trev and Ian for your kind wordsCool
Today hasn't been a very good, spent 2 hours in A and E having my hand stitched up after I cut it open at work Crying making a new battery tray for a tractor
Now unable to work for 10 to 14 days while it heals and can't do anything to the models because it is my right hand, going to be a boring couple of weeks
Regards Shaun
#129 Posted : 14 February 2017 21:29:16
Blink Blink Sorry to hear about your accident and ouch Blink Blink Blink Blink
Hope heal up quickly Cool
#130 Posted : 14 February 2017 22:10:51
Here's hoping for a speedy recovery Shaun.....Blink Blink
#131 Posted : 15 February 2017 09:53:10
Oh dear, expect your also peeved this has taken you off the RNLI tractor build Crying
#132 Posted : 15 February 2017 15:38:39
Ouch Shaun,
i hope you feel better soon.
Shauncnh
#133 Posted : 09 September 2017 19:09:43
So the Sara lifeboat tractor is complete and it's also the end of the silly season at work so I hope to beanie to get back to this build in the next few weeks.
I have managed to complete the one wing and have started building the second unfortunately I lost my USB stick with all build instructions on and all the pics for all stages I completed finishing the first wing and the start of the second.
I just need to copy the instructions from the cd onto a USB stick and I'll be able to continue with this build and keep you all updated.
Regards Shaun
#134 Posted : 09 September 2017 19:48:40
Glad to hear that you'll be continuing with this build very shortly Shaun, I'll be watching with interest! Cool ThumpUp
#135 Posted : 09 September 2017 21:48:02
Sure good to have you back working on this one.
Cool Cool Cool Cool
#136 Posted : 10 September 2017 11:10:33
Nice to have you back ShaunBigGrin can`t wait to see your progressBigGrin regards PhilCool
7 Pages «<567
