Cannon Supports Options
Glen
#1 Posted : 21 February 2011 15:04:25
Good afternoon everyone,
I have not posted anything for a while iam watching everyone else
But now i have a problem with the cannon supports.
I have done all that it say's in the mag, but when i drilled through the gun ports it's come out into the support beams, everything lines up the drill was square going in, but it's the same in every gunport, will this realy matter so much, i don't know, (i hope not). Can anyone help or suggestions?Crying
Can i just say i love this forum just by reading some of the posts you can get yourself out of many a scrape.
Glen
Roger the Cabin Boy
bripfc
#2 Posted : 21 February 2011 15:16:05
is it possable for you post a picture
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
PLAY UP POMPEY!!!no wise cracks
#3 Posted : 21 February 2011 15:22:52
When drilling in thru the ports you should in fact be drilling into the dummy gun support beams, are you saying this is/is not the case on your model, like bripfc say's can you post a photo of your problem?
z8000783
#4 Posted : 21 February 2011 15:31:49
Groups: Unapproved
Glen
Mine do too but the holes are near to the top of the beam unlike the lower deck. I understand the extra supports were simply to provide reinforcement.
If the holes had been in these supports I would have thought the cannons would be far too high from the deck.
Read on from here also - gun support
John
Glen
#5 Posted : 21 February 2011 15:46:12
Hi again all,
Sorry i can't supply photo's, one of the kids has taken the camera away on holiday to the States (more than likley get lost or stolen) .
Like i said drill into the center of the cannon gun ports and it comes out in the lower part of the support beam 10mm below the cannon supports.
Thanks Glen
Roger the Cabin Boy
willie
#6 Posted : 21 February 2011 16:02:25
Glen wrote:
Hi again all,
Thanks Glen
you have probelly have bored square to the hull instead off squared to the keel if you puta a spare plank accross port and stbd and follow that line or same line to deck
Glen
#7 Posted : 21 February 2011 16:13:13
Hi all,
Thanks for that Willie, i have tried both ways now sqare to the keel and square to the deck and the drill still comes out in the deck support beam and not the cannon supportsCrying
Thanks Glen
Roger the Cabin Boy
z8000783
#8 Posted : 21 February 2011 16:16:32
Groups: Unapproved
Here's mine.
John
Glen
#9 Posted : 21 February 2011 16:26:18
Thanks John, i think i might have got things rightBlushing looking at yours, i thought the 2mm drill had to come out of the cannon supports not the support beams.
If, by going with your picture the hole comes out of the support beam then everything is OK thank you you have put my mind at rest.
What is the purpose of the cannon supports?, you have to paint them black and you can't see them anyway.
Thanks again Glen
Roger the Cabin Boy
#10 Posted : 21 February 2011 16:32:07
Glen, the additional piece to the main gun support beam is there as a just in case the drill hole sits too close the beam edge, and therfore would need support above if that makes sense.
Glen
#11 Posted : 21 February 2011 16:38:26
Thanks Tomick,
All is becoming clear
Roger the Cabin Boy
#12 Posted : 21 February 2011 16:47:05
by the way, the supports are painted black so as to create an illusion of darkness when looking into a port which does not have a full gun kit within.
This page was generated in 0.167 seconds.
