10 Pages «<34567>»
Occre 1:24 Adler Locomotive Display Options
#81 Posted : 16 February 2017 15:49:15
Hi Tony.
really enjoying this build. look forward to seeing your progress Ian Cool BigGrin
#82 Posted : 16 February 2017 18:38:25
Ian
Thanks for the comments - much appreciated
#83 Posted : 19 February 2017 18:10:24
SUNDAY 19th February 2017 – The Adler Locomotive Build
A very good afternoon to everyone. I hope that everyone has had a good week whatever you may have been up to.
As in previous weeks I thought I would start this week’s update by way of a little “On this Day” entry.
On This Day 19th February
1674 England and the Netherlands signed the Treaty of Westminster, ending the Third Anglo-Dutch War. A provision of the agreement transferred the Dutch colony of New Amsterdam to England and it was renamed New York
This week I have been concentrating on getting the etch parts onto the side rails and it’s during this part of the build that I have spotted the first error in the kit – more on that later.
PICTURE 1
This is the rear buffer rail for the locomotive. This part requires an etched overlay to be glued in place. Again with some of the other etch parts this has a real strong “spring” to it. To ensure it glues into place with no problems in the future it was annealed as I have described in earlier entries. This removes “spring” from the part ensuring when glued in place that is where it will stay.
PICTURE 2
I have used “Timebond” again for these etch to wood joins. Joining 2 dissimilar surfaces means applying the glue to the least porous surface so in this case the back of the brass piece.
To get the best even pressure when clamping up the parts it’s an idea to use some folded paper towelling as this allows the clamping pressure to press onto the whole part. Without the paper towel padding you would just be applying the pressure to the raised rivet detail and that could mean some of the brass does not get glued down firmly enough.
PICTURE 3
“CALLOUT - PROCEED WITH CARE”
The next part of the build is to glue into place on each cast spring the 2 pre-cut wood sections you can see in this picture. Make sure that you glue in the larger of the wood pieces shown here at the BACK of the cast leaf spring. The front of the spring will receive an etched overlay.
PICTURE 4
These are the etched overlays that will be fitted to the “front” of the side rails. To save yourself a little time try and remove the parts from the etched fret as close as possible to the part.
A quick rub over with a small file removes any remaining traces of the connecting burrs.
PICTURE 5
When gluing on these etched parts it makes sense to clamp them in place until the glue sets.
Be careful here because as you can see from the arrowed section in the picture the wood at this point is extremely thin due to the pre-cut mounting slot at this point. When you start adding clamps (pegs in my case) it adds weight to the forward section and the last thing you want is this section breaking off at this point.
PICTURE 6
And once these 5 etched parts (3 per side) this is how the side rails look.
PICTURES 7, 8
“OBSERVATION: KIT FAULT”
It’s at this point of the build that something just did not look correct to me. You can see from PICTURE 7 that one of the etched parts covers more of the pre-cut slot on one of the rails than it does on the other rail.
Putting the 2 rails together reveals the issue here and it’s a case that the 2 pre-cut slots are not aligned and this has somewhat annoyed me because this was one of the issues with the earlier version of this model.
The brackets that hold these side rails are symmetrical and that is exactly how these slots should have been cut.
It’s not the “end of the world” but it is annoying that a mistake such has this has still not been picked up by the manufacturer and corrected.
And as they have changed the layout of the wood parts on the fret there is no excuse to have overlooked this (MOAN OVER).
At this stage is probable best to press on with this part of the build and then make the required correction once the side rail framework is glued together.
PICTURE 9
Here we can see the rest of the etched sections that complete each of the side rails.
What is interesting to note here is that in the early kit each of these etched elements was supplied as a white metal casting and once in place would have made the side rails far too heavy to remain glued to the locomotive for very long.
PICTURE 10
“CALLOUT -PROCEED WITH CARE”
If you are using a “slippery” glue as I am for these parts, it’s really important to ensure that the parts do not misalign when you clamp them up.
Even a thin layer of the glue sets up “slippery” surface between the 2 parts and as you see from this picture some slight movement has occurred between the etch and the wood side rail. Easily moved back into alignment but make sure you look for this before the glue sets up.
What you are looking for is a nice straight edge across the etch parts with no dips or rises between the sections.
PICTURE 11
And once all of the etched parts have been glued in place and allowed sufficient time to dry this is what the side rails now look like.
There are 2 small etch sections still to be added to the ends of the rails and for these 2 parts I will use a cyno based adhesive. Something like a “SLOW ZAP” adhesive will allow sufficient time to align the parts before they bond tight.
PICTURE 12
At this point none of the sections are glued together as I still need to work on the valve gear that fits under the Loco. I have primed these parts and next weekend will be breaking out the airbrush to get them painted and installed.
From this picture though you can see what the side rails are supposed to look like when in place and hopefully from this image you can see why having those side rail slots correctly cut is important.
PICTURE 13
And the very last task I tried out this week was to have a go at dry brushing the footplate to try and highlight the tread plate pattern.
The footplate was painted with Satin Black and I thought possible the Metal Black from one of my Caldercraft paint sets might provide enough of a contrast between the parts but it does not appear to have done so.
Do not really want to add any strong contrast between the colours so will have a look at this section as the build progresses.
“OBSERVATION”
If you are using a battery powered paint stirrer always make sure you turn it off before removing it from the paint jar LOL . I had one of these years ago (and it’s probable still hiding some place. That had a press and hold switch were as this one has a slide on/stay on switch. I will leave you to guess what happened Blushing
And that completes my update for this week. Hope everyone has a good week next week and will catch up again with you all very soon.
#84 Posted : 19 February 2017 20:01:57
BigGrin Nicely done and nice workCool
#85 Posted : 19 February 2017 20:50:25
Many thanks
#86 Posted : 19 February 2017 21:18:24
Really nice work Tony.
I love your right up and the way you are using the call outs, great job Cool
#87 Posted : 19 February 2017 21:26:47
Some nice progress Tony Cool and its colourful too.
#88 Posted : 19 February 2017 21:39:31
Dave/Al
Many thanks.
It certainly is bright with colours you have to use.BigGrin
#89 Posted : 19 February 2017 21:54:09
Hi coming along very nicely. Very neat work. Cheers mick. BigGrin
#90 Posted : 19 February 2017 22:25:00
Gets better and better with every post Tony, lovely work.....Drool Drool
kpnuts
#91 Posted : 19 February 2017 22:34:33
I love the way you're doing this build mate, it's so helpful to others, great job, looking great
#92 Posted : 19 February 2017 22:42:19
Mick/Allan/Ken
Many thanks for the kind comments.
Its coming together now but does have a few areas to watch out for.
#93 Posted : 20 February 2017 01:55:56
looking great Tony
#94 Posted : 26 February 2017 18:05:33
SUNDAY 26th February 2017 – The Adler Locomotive Build
A very good afternoon to everyone. I hope that everyone has had a good week whatever you may have been up to, and that wherever you have been you have been safe in the windy conditions we have been having.
On This Day 26th February
1914 The launch of HMHS (Her Majesty's Hospital Ship) Britannic, sister to the RMS Titanic, at Harland & Wolff shipyard in Belfast. She was the third and largest Olympic-class ocean liner of the White Star Line and was intended to enter service as a transatlantic passenger liner. However, she was launched just before the start of the First World War and was laid up at her builders in Belfast for many months before being put to use as a hospital ship in 1915. She struck a mine off the Greek island of Keain in November 1916, and sank with the loss of 30 lives.
This week I have been working on some of the fiddly details and while overall its looks like little has been achieved they are time consuming parts to work with. I have a day’s leave this coming Friday so looking forward to a full day of build time.
PICTURE 1
There are a few parts this week that I felt were better being spray painted rather than hand brushing.
For the Steel colour I have used Vallejo “71065 Steel” from their Model Air range with comes already pre-thinned for spraying. It’s a water based paint so clean up is nice and easy with no need for “whiffy” chemical smells. The only slight downside is that it takes longer to dry in this damp weather.
My choice of airbrush for this one was my Sotar 20/20 and for no other reason that this one has a nice small paint cup which was ideal for this limited amount of painting.
PICTURE 2
These parts will form part of the engines valve gear and are laser cut from a sheet of fairly thick metal. The parts are only held in place by one tab so I decided it was easier to paint these parts while still on the fret.
The picture you see here is after the coat of steel colour has been applied.
PICTURE 3
Here we can see some of the parts that will be fitted to the back plate on the driver’s footplate.
I mentioned in an earlier post that this kit (like so many) comes with the 1.5mm brass rod “nicely” coiled up and twisted so in my book that makes it totally unusable.
What gets me is that kit manufacturers carefully pack all the wood strips neatly in the box but when it comes to the wire it all gets coiled up.
“RECOMMENDATION”
To make things easier for yourself consider replacing your coiled wire for straight lengths. In my case I am using stock supplied by Albion Alloys.
PICTURE 4
There are a number of parts that the builder has to shape using the brass wire and this full size plan can be used to overlay the brass rod to ensure you get the bends/folds just right.
PICTURE 5 & 6
While the etched overlays have the majority of the holes pre-made the same does not apply to the base MDF parts. Therefore, you will need to deepen the holes ready for the shaped brass parts you are making.
A small pack of the drill bits you can see in Picture 5 are ideal and cheaply available from a whole host of retailers. That along with a pin vice makes the task nice and easy.
PICTURE 7
Very carefully drill through the guide holes in the etched overlays and through the MDF surfaces underneath.
PICTURE 8
Here we can see the firebox door, a control lever base as well as one of the shaped brass parts fitted in place.
As with earlier brass work were the part remains un-painted I have cleaned the brass using Rustin’s brand metal polish and then coated in Rustin’s Metal Lacquer to ensure the part remains nice and shiny without tarnishing over time.
PICTURE 9 & 10
Moving onto the front of the smokebox we have to glue in place the 2 cylinder ends. You need to ensure these are correctly aligned. So what I have done here is to use a couple of scrap lengths of brass rod to ensure they are glued correctly in place.
Later on these brass parts will be removed and some shaped brass parts will be fitted in place.
PICTURE 11, 12, 13
This is the time that we finally glue the firebox and smokebox end to the boiler itself. As well as joining these sections we also need to fit in place the 4 “steel” bar sections that will support the valve gear itself.
This is one of those occasions that an extra set of hands would help because you need to joggle the 4 bars into the preformed slots in both the front and back ends of the loco.
Elastic bands provide clamping pressure to ensure its all held nice and tight until dry.
“RECOMMENDATION”
Its probable worth mentioning at this point that in my kit there is some very slight movement in the joints between boiler and firebox end and boiler and smokebox end. This will allow for minor twisting of the parts and if not spotted and corrected you will find that the wheels do not all touch the surface.
Therefore, I would suggest you put the wheels back in place and just ensure everything touches the ground before these glued parts fully dry.
PICTURE 14
Here we can see another of the brass parts that you are asked to make form the brass rod in the kit. Again I have used the brass rod I purchased.
“OBSERVATION”
The kit would have you use 1mm dia rod for this pipe but both the hole in the ferrule that goes onto the boiler top and well as the cast part on the firebox top are pre-drilled to 1.5mm so in this case I went with 1.5mm brass rod rather than the recommended 1mm rod.
PICTURE 15
At this point its time to start gluing up the “skirt” that fits around the loco. I am gluing up each corner in turn and clamping the parts against a square to ensure they dry at a nice right angle.
PICTURE 16
The gluing surfaces on these corners are not that big so on the basis this part will undergo a lot of handling, both for paint preparation and fitting I have decided to reinforce the corners with some 1.5mm brass rod.
Here we can see the hole being started off using one of the smaller drill bits from which we will work up to the 1.5mm drill bit. It pays to take very special care when drilling these corners as there is not a great deal of wood to work with. Also being MDF if you go straight in with the largest drill bit there is a chance of splitting open the part and if you do that it’s going to cause you some major problems.
PICTURE 17 & 18
Having enlarged the hole to 1.5mm I have superglued in the brass rod. This in turn gets cut off and finally filed down to give a nice even surface.
These reinforcements should allow the framework to be handled without the risk of it all falling apart.
And that completes my update for this week. Hope everyone has a good week next week and I will catch up again with you all very soon.
#95 Posted : 26 February 2017 18:28:58
Fantastic work Tony, a nicely detailed update. I also use Albion for my rods and tubes, it certainly looks better that the kit supplies. BigGrin
#96 Posted : 26 February 2017 18:47:28
Great update. Cool Cool Cool
More hints, tips and info. Love
Keep up this excellent diary I`m loving it.BigGrin BigGrin
#97 Posted : 26 February 2017 19:11:08
BigGrin Looking good TonyCool
#98 Posted : 26 February 2017 19:28:22
Daran/Derek/Andy
Many thanks for the kind comments. BigGrin
#99 Posted : 26 February 2017 21:28:40
Good work TonyCool another informative build update.
#100 Posted : 26 February 2017 22:15:03
Many thanks BigGrin
Guest (24)
10 Pages «<34567>»
This page was generated in 0.372 seconds.
