put the two strips on and secured by three screws. stevegbr attached the following image(s):
this is issue 3, which contains a complete wheel. stevegbr attached the following image(s):
here are the parts. stevegbr attached the following image(s):
we have to insert the hub in to the tyre. stevegbr attached the following image(s):
we have the wheel and the cover. stevegbr attached the following image(s):
it is held in by three screws. stevegbr attached the following image(s):
Message was deleted by User.
here are the parts for issue 4. stevegbr attached the following image(s):
the two parts for the top of the reactor. stevegbr attached the following image(s):
turned the part over to connect the next part. stevegbr attached the following image(s):
now to build up mr fusion. stevegbr attached the following image(s):
put the glass in to the recess. stevegbr attached the following image(s):
now to build the chamber. stevegbr attached the following image(s):
the clamp is now fitted. stevegbr attached the following image(s):
this is issue five, and the parts. stevegbr attached the following image(s):
now to assemble the suspension strut. stevegbr attached the following image(s):
add the spring to the suspension. stevegbr attached the following image(s):
adding the spring and switch to the disc arm. stevegbr attached the following image(s):
applying the caliper to the disc. stevegbr attached the following image(s):
Guest (17)
