106 Pages «<1112131415>»
Sticky Wickett
#241 Posted : 16 February 2017 21:14:30
That's this post complete for the free flood holes [vents].
More posts from the 'Dockyard' to follow soon. BigGrin
Thanks for looking in, have a great weekend and happy modelling.
Kind Regards,
Phil W.
#242 Posted : 16 February 2017 21:35:13
Phil
Your doing a great job. As a partwork its coming close to an end but hope all your updates continue to go well.
Have you thought about any sound effects for the build? I have found a company that sells a sounds effect for the u boat while tracking down something for my occre build.
Haveca look at the following if youvare interested. You have to scan to the end ofvthe list for the u boat. Rather like the galleon sound effects with canon fire BigGrin ms50 is the sound module.
http://www.modelsounds.co.uk/sounds.html#trains
Sticky Wickett
#243 Posted : 16 February 2017 21:44:42
Hi Tony,
I'm glad you enjoy my posts!
Yes i'm aware the part-works finishes soon; collect issue 129 tomorrow. Issue 150 will take me through to mid-July. What I have planned though will see me through until Sept 2018. No problem. I estimated this would be a 4 year build starting from Sept 2014 and with all the tiny internal details i'm going to add [can't wait], my build diary will run for sometime yet.
Ah! You've sussed my ace up the sleeve regarding sound!BigGrin
Everyone recognises submarines by the sound of the sonar, so I'm going to install a small mobile phone speaker in the Control Room with a soundchip of a sonar bleeping away and a speaker in the Engine Room to convey the sounds of those diesels thumping away.
I will have a look at that link. Thank you very much for that piece of info. It's much appreciated. Have you installed sound to any of your models Tony?
All the best,
Phil.
Sticky Wickett
#244 Posted : 16 February 2017 21:48:50
Hi Tony,
I've just been on link you posted. Fantastic! Woop woop!BigGrin
I will definitely be contacting those guys at some point in the near future.
Phil
#245 Posted : 16 February 2017 22:24:05
Really nice job with your latest modifications Phil Cool
The sound is a really interesting and will really add everything you have done so far. I'm also really enjoying following your build ThumpUp
Sticky Wickett
#246 Posted : 16 February 2017 22:59:56
Thanks Dave for your encouraging comments.BigGrin
The sound will come later in the build, but hopefully it will add that little bit of atmosphere and make the boat come alive.
It's amazing what these companies do nowadays with sound.
More posts to follow soon.
Phil.
#247 Posted : 17 February 2017 00:09:21
The more I see this the more I like it, looking great....Cool Cool
Sticky Wickett
#248 Posted : 17 February 2017 10:42:07
Thank you for the kind comments Alan. It's not everyone's cup of tea; building a U-Boat, but I'm glad you're enjoying the build.
Phil W.
Sticky Wickett
#249 Posted : 17 February 2017 12:06:06
Have a great weekend everyone and happy modelling! Cool
Sticky Wickett
#250 Posted : 22 February 2017 19:45:45
On this part of the build I will be focusing on the midships free flood holes.
See attached photo of these on U995.
As can be seen, these vents /holes are arranged with equal spacing on the U995. This was not the case on all Type VIIC U-boats. The model i'm building, U230, had it's vents arranged in pairs with a singular vent hole at the aft end of the pattern.
My initial plan was to blank off the last 3 vents on the supplied plastic part and drill through the rest to open them out, similar to what I've done before, to give that feeling of depth.
My drilling didn't go to well if i'm honest. The drill veered off many times resulting in a very uneven and 'scruffy' look. Some vents looked larger than others, while some appeared shorter or longer and in one case I had two that were nearly joined to make a very large vent. Not what I was after at all!
So it remained in this 'state' for many months while I continued with the rest of the superstructure, but it was always an eye sore whenever I stood back to admire the other work I had completed.
As the build progressed I found myself back at these vents with decisions to make! My idea was to fill all the vents with clay. Which is what I did and let it harden overnight. With this in mind I then proceeded to re-drill out all of the vents. This didn't go to well either as the clay wasn't as robust as the plastic and so the drill kept veering off into the clay when I came to widen a couple of the vents. Then the clay broke off in clumps. Confused
Sticky Wickett
#251 Posted : 22 February 2017 19:49:20
This photo shows the vents drilled out, or tried to, after I had applied the clay.
Sticky Wickett
#252 Posted : 22 February 2017 19:50:29
Another shot of this disaster.
As a side note, we're looking at the starboard side, bow to the right of the photo.
Sticky Wickett
#253 Posted : 22 February 2017 19:52:15
Another attached photo showing the mess I was left with leaving me mentally scrabbling around to figure out how I could resolve this.
Sticky Wickett
#254 Posted : 22 February 2017 19:54:28
One more photo of what I was left with following 'claygate'. LOL
Sticky Wickett
#255 Posted : 22 February 2017 20:04:22
The plan I envisaged was to make templates from 0.25mm thick plastic sheet with the correct pattern, fix to the hull over the originals and file smooth the edges.
Sounds easy right? Yeah right!LOL It took me 5 attempts at marking out the sheet until I had a satisfactory result. This was down to a variety of factors slowing the process which resulted in an uneven pattern and misaligned markings. These factors included; pencil thickness, craft knife veering slightly off, incorrect marking out [I won't bore you with the maths], the drill moving off centre and generally just not looking the part.
Finally, after two evenings I ended up with two 0.25mm plastic templates with the correct pattern.
The attached photo shows the pattern marked out on the sheet and centre dotted with a sharp scribe prior to drilling out.
Sticky Wickett
#256 Posted : 22 February 2017 20:05:45
The attached photo shows the pattern drilled out.
Sticky Wickett
#257 Posted : 22 February 2017 20:07:49
This photo shows one of my earlier attempts; the spacing was wrong. For some reason I didn't photograph the final pattern that I used.
Sticky Wickett
#258 Posted : 22 February 2017 20:09:04
Another photo showing my earlier attempts.
Sticky Wickett
#259 Posted : 22 February 2017 20:18:59
Suffice to say that after I had completed this time consuming and maddening 'little' job that my thoughts came back to attaching these templates. As I mentioned before, my initial plan was to just glue them to the top of the hull over the existing 'claygate' and viola! I then realised that this would not give the correct appearance as no matter how much I smoothed over the edges, the templates would still sit proud; by 0.25mm to be exact!
It then dawned on me that if I recessed the area where I was going to glue these templates by the aforementioned 0.25mm then they would sit flush! Hahaha I hear you cry!
So that is what I did. With a dremel. Which was a bit hardcore and took off a little more than I initially anticipated leaving me with the feeling that I had bitten off more than I could chew.
See attached photo of this continuing drama. LOL
Sticky Wickett
#260 Posted : 22 February 2017 20:26:25
I'm thankful I have plenty of patience and sometimes modelling definitely tests this 'virtue' as i'm sure anyone would agree reading this.
With a sigh and a deep breath I took to it with a needle file and painstakingly clawed back my errors and produced something reasonably satisfactory.
Now for the next part of the 'drama' LOL, I noticed that to fit my templates correctly I would have to open out my 'claygate' a little wider so that it 'hid' behind my new version. In doing so I realised that for this to work properly I would be better off grinding out all of the original vents to make one massive hole.
See attached photo.
Guest (12)
This page was generated in 0.406 seconds.
