4 Pages <1234>
Queen Elizabeth-class battleship HMS Barham 1/700 scale Options
#21 Posted : 05 February 2017 23:45:18
BigGrin
Due to the delicate photo etch gallery at the stern, I was not conferable masking the upper hull to paint the lower hull, thus I have painted the lower hull by hand.
Two coats were required to get a nice even finish. the boot line was added using fine line tape. Happy with the result so far. I will come back to the hull later in the buildSmile
Thats it for Now, Thanks for all the comments so far
Jason
#22 Posted : 12 February 2017 11:47:51
With the hull complete I have turned my attention to the upper works.
The forward lower superstructure is first, just some etch doors and railings to add, a bit fiddly but no issues. I found my wax etch positioning pencil essential for these small parts.
Next is the rear superstructure is next this mounts the main loading crane and main mast. The crane took nearly an hour to form and glue together but the finished look is considerably improved on the kit part.
Building the main mast starfish was up next, I am sure I went crosseyed making this even with my magnifying glasses but again the effort is worth it.
The mast assembly was relatively straight forward but a lot of care was needed as the starfish adds weight that the mast mounting point was not designed for.
the finished sub assembly have been put aside for priming at a later date
Jason
#23 Posted : 12 February 2017 15:21:51
Very nice job with all that tiny etch, the main mast looks awesome Drool
I have one of those wax pencils myself, they're fantastic for tiny etch parts Cool
#24 Posted : 12 February 2017 15:27:35
Great update JasonBigGrin Drool love your etch workLove regards PhilCool
#25 Posted : 14 February 2017 06:50:38
Thanks both forcyour comments, as always the etch can be fiddley but it makes such a differance to the finished model
Jason
#26 Posted : 17 February 2017 22:01:15
next up is the funnel. forward walkway is added as well as the funnel cap. a lot quicker to type than to make Blink
with the funnel in the bag I moved to the forward superstructure. base section first with etch doors replacing the moulded on lumps. railings add to the look, they wee a bit fiddly.
The forward superstructure is built up using the kit etch, it all goes together easily.
Jason
#27 Posted : 17 February 2017 22:14:45
Hi Jase.
Looking really good. some nice etch.
Ian Cool BigGrin
#28 Posted : 26 February 2017 11:22:07
Thank you Ian.
#29 Posted : 26 February 2017 11:39:37
Nice work Jase, she's really coming along....Cool Cool
#30 Posted : 26 February 2017 11:41:00
Main Guns are up next They all have a slightly different arrangement with additional gun platforms and one with an aircraft catapult. The kit comes with etch for all of these but the WEM sets add better detail and a better scale and shape.
All the etch on the guns was held in place with PVA.
All the built up sub assemblies have now been primed with Halfords grey. The ships boats have also been primed 'hull up' prior to having the tops built up and primed.
I will be pausing the sub assembly build now to move back to the hull. Before the first level of superstructure can be added the ships hull will need to be weathered. Some weathering videos coming up nextBigGrin
Thanks fore looking in.
Jason
#31 Posted : 10 March 2017 18:30:49
I have now focused on the weathering of the hull.
My process starts with highlighting the hull detail.
you can see how I have takled this in the video on this link
https://youtu.be/zSKKquezEkA
Jason
#32 Posted : 26 March 2017 13:27:38
Continuing the weathering of the hull Below the waterline.
The Hull below the waterline is often ignored by model builders when weathering a ship, but this part of the ship gets less regular maintenance then any other
I started my process by adding chipping and scratching to the lower hull. Using a lighter shade of red to the anti-fowling red to give subtle effects.
See my video link below
https://youtu.be/RDFGSl4adhA
With the chipping done I have moved on to salt streaks next followed by adding algae.
Using AK enamels and white spirit we start by adding white streaks from the waterline down the hull.
Using a stiff brush dampened with white spirit and dried the streaking is thinned and blended using downward strokes to maintain the streaking effect. Any excessive streaking or pooling of thinned wash can be removed using a cotton bud dampened with white spirit.
The end effect should dull the hull overall but maintain some streaking effect.
Next is the addition of the Algae. I have used AK slimy green dark for this. I am mainly interested in showing this along the waterline, however occasional splurges on the rest of the hull help break up the eveness of the salt streaking, The paint is applied liberally.
Using a piece of tissue repeatedly dapple the paint to get an uneven finish.
Any green paint that strays over the waterline can be cleaned up using a fine brush with white spirit.
I can now paint the screws brass. I have used AK True Metal Brass thinned with a little white spirit.
I will continue the weathering in the next post.
#33 Posted : 30 March 2017 13:55:34
That works and looks amazing Drool great update JasonBigGrin looking forward to your next updateDrool Love regards PhilCool
#34 Posted : 30 March 2017 14:07:11
Thanks Tiger
The camra flash makes it appear less subtle than it really is
#35 Posted : 30 March 2017 14:15:24
Just one thing, the prop blades would look a weathered dull brass almost bronze look to them and verdigris
#36 Posted : 30 March 2017 14:52:37
Hi Tom thanks for that, good shout.
I am by no means done with weathering the hullBigGrin
#37 Posted : 30 March 2017 22:22:17
Coming along nicely Jase, she's certainly looking well weathered.....Cool Cool
#38 Posted : 31 March 2017 06:12:01
Thanks Alan,
Always a risk of overdoing it but I am quite happy so far. More this weekend hopefully
Sticky Wickett
#39 Posted : 31 March 2017 09:37:03
Nice weathering so far Jase.
Phil W
#40 Posted : 31 March 2017 17:33:21
Great job so far Jase Cool
Your poor eyes with all that tiny PE Blink
4 Pages <1234>
This page was generated in 0.508 seconds.
