24 Pages 123>»
L'Hermione Build Options
#1 Posted : 28 February 2017 21:03:47
This build will be a straight out of the box build and will follow the instructions closely, as found on the MS Website:
http://www.model-space.c...yette-complete-kit.html
A review of the kit has been done separately and can be found here:
http://forum.model-space...spx?g=posts&t=22587
It should also be noted that should you wish to create the mouldings on the various strips of wood on this build then you will need both the sets of Artesania Microshapers. This is an optional extra and is recommended in Stage 17 of the build instructions.  (Artesania Ref 27300 and 27301).
http://forum.model-space...spx?g=posts&t=22529
When these become available from the tools webpage then members will be advised however, they are available via other online sources such as Tower Hobbies...
http://www3.towerhobbies.../wti0001p?&I=LXGEGH
http://www3.towerhobbies.../wti0001p?&I=LNGEGJ
Stage 1
Removed the two parts of the keel, 10 ribs, stiffeners and 3 mast sockets from the fret. Cleaned all edges and slots of any ash deposits. Glued the two parts of the keel together and clamped to a flat surface to ensure the keel remained flat. Once the glue had dried, glued and clamped two stiffeners over the joint, ensuring the slots on the keel were kept free. Allowed to dry fully before continuing.
Set the keel into a jig to keep it straight. Starting at the bow, glued the frames into position ensuring they were set to 90 degrees to the keel and perfectly upright and level. To do this I used the set squares included in Artesania’s Micro Drawing Set which can be purchased separately from the Model-space Shop in the very near future. Once all the frames were set these were left to dry fully before continuing.
The three mast sockets have two different sizes for the mast bases. The two with the larger sockets were glued in place for the Foremast and Mainmast, the smaller for the Mizzen mast. Finally, glued the two supporting pieces into the slots (facing the bow), ensuring they were placed the right way round.
This completes Stage 1.
#2 Posted : 28 February 2017 21:35:07
BigGrin Nice start Alan Cool looking forward to this one Drool
#3 Posted : 28 February 2017 22:45:05
Thanks Martyn, I think she's a lovely ship and so far everything is fitting very nicely.... Cool Cool .. Early days of course but so far am impressed with this kit....Cool Cool
#4 Posted : 28 February 2017 22:47:39
BigGrin yeah I might have to look at this one for my stash Cool
nightwisher
#5 Posted : 28 February 2017 23:02:26
Looks like a nice kit,not too big and good quality.Very tempted.
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#6 Posted : 28 February 2017 23:09:46
BigGrin Nice start AlanCool
#7 Posted : 28 February 2017 23:11:13
Great start Alan, she looks a nice quality kit.
#8 Posted : 28 February 2017 23:34:14
Thanks everyone for looking in. I'd say this is a kit worth doing, hasn't given me any problems at all as yet.....Cool Cool .. Don't think you'd be disappointed...
eebygum
#9 Posted : 01 March 2017 09:39:21
Hi Alan
Nice and straight tidy work looking forward to watching this build progress
Rgds
Tery
Sticky Wickett
#10 Posted : 01 March 2017 10:19:32
Very nice looking kit. Looking forward to seeing this take shape.
Phil W
#11 Posted : 01 March 2017 12:27:22
Great start Alan. looks a nice kit. look forward to seeing this one come together. Ian Cool BigGrin
#12 Posted : 01 March 2017 23:28:41
Good start Alan.
It is a fantastic kit and so impressed with the way its all laid out and the quality of the parts.
I was particularly impressed with just how smooth the mast dowels are - the best i have ever seen in any kit i have ever purchased.
Have you decided what brand of paint you will use for this one?
Hope the rest of the build goes well.
greyhawk
#13 Posted : 01 March 2017 23:50:56
Oh this one should be good. Having the usual troubles with your photos, but the ones I see look great already. Only 139 stages to go. Flapper
#14 Posted : 02 March 2017 00:40:39
Nice start to the frame work Alan. Look forward to more ...
Chris Cool
#15 Posted : 03 March 2017 23:48:32
Thanks everyone for the great comments, appreciate you looking in....Cool Cool
@Tony, as yet I haven't decided on what paints to use and I'm open to suggestions.....
#16 Posted : 03 March 2017 23:51:37
Stage 2
Removed the two second deck sections from their frets and cleaned up all the edges of ash. Test fitted the decks in place to ensure all fitted well, no problems found. Starting from the edge that runs down the centre of the deck, I started laying veneer strips (0.5 x 4 x 300mm) one after the other until the deck sections were covered. Left everything to dry overnight.
Turned the deck sections over and using a fresh blade in my craft knife I trimmed all the surplus strips from around the decks. I kept the offcuts, they are of a length that will likely come in useful later in the build. Then used a fine sanding block and sanded all the edges smooth. Following the grain of the wood I then sanded the decks smooth, again using a fine sanding block.
Using a ruler and a fine pointed pencil I drew lines where the planks join to simulate the caulking. Followed the measurements outlined in the instructions and drew in the joints for the ends of the planks followed by the treenails. The decks were then given 2 coats of matt varnish and allowed to dry completely.
Finally in this issue I fitted and glued the two decks in place, clamping at key points to ensure they didn’t lift anywhere and left to dry.
This completes stage 2.
#17 Posted : 04 March 2017 01:15:03
Looking great Alan. Lovely planking and those trenails are so uniform.
Great work.
Chris Cool
#18 Posted : 04 March 2017 14:53:53
Great work.
Chris Cool
Thanks Chris, so far she is a lovely kit to put together....Cool Cool
RichieG
#19 Posted : 04 March 2017 15:28:41
Rank: Amateur Level 1
It's a very clean build. Interesting choice to draw in the caulking lines after the planking had been laid. I've usually seen people draw on the edges of the planks before they're glued on. But, it looks really good, I must say.
#20 Posted : 04 March 2017 23:42:14
Thanks Richie, appreciate you looking in and your comments..Cool Cool .. The planking and simulated caulking has been done as laid out in the instructions. It's the first time I've tried it this way and must agree with you, it appears to work really nicely....Cool Cool
Guest (10)
24 Pages 123>»
This page was generated in 0.357 seconds.
