106 Pages «<1415161718>»
Sticky Wickett
#301 Posted : 03 March 2017 14:48:55
Hi Chris - I'm glad you like my build diary!
More posts to follow on a weekly basis.ThumpUp
Phil W
#302 Posted : 03 March 2017 16:14:43
Hi Phil.
looking fantastic. very nice update.
Ian Cool BigGrin
Sticky Wickett
#303 Posted : 03 March 2017 16:39:26
Thank you Ian. Glad you like the build so far. More posts to follow soon.
Phil W.ThumpUp
#304 Posted : 03 March 2017 18:59:51
Great update PhilBigGrin these little mods are really making your model stand outDrool Drool Love well doneThumpUp regards PhilCool
Sticky Wickett
#305 Posted : 06 March 2017 13:59:56
Thanks Phil. Much appreciated!ThumpUp
Sticky Wickett
#306 Posted : 09 March 2017 09:00:27
Morning Fellow Modellers,
I thought I would post my weekly update before I shoot off to work this time.
On this part of my build I will be looking at the part-works supplied photo-etched rivet strips that fit around the bow plus some modifications I added.
The attached image shows the anchor-well on the forward starboard side of the bow. I added a 0.5mm plastic strip around the bottom of the anchor-well to resemble the raised lip or edge on the real thing. This was to prevent the anchor from damaging the hull as it was lowered. The raised lip insured the anchor would initially project outwards.
Sticky Wickett
#307 Posted : 09 March 2017 09:04:07
The attached image shows the same raised edge on U995's anchor well.
Sticky Wickett
#308 Posted : 09 March 2017 09:07:10
The next image shows how I drilled and filed out the free flood holes on the starboard forward bow. I also chose to represent the torpedo tube doors [bow flaps] in the shut position. This took a bit of work as I had to grind away a lot of the fittings behind them to allow a flush fit.
Sticky Wickett
#309 Posted : 09 March 2017 09:12:12
This image shows a close up of the part-works supplied rivet detail. I found these strips to be very delicate, especially when trying to file smooth the rough edges left when it was parted from the fret board. I also had to rough the underside with 100 grit sandpaper it give it a better chance of bonding. My method was to apply a thin smear of PVA to the underside and hold it place using tape while the glue dried overnight. Once dry I ran a bead of superglue along all of it's edges to really bond it down firmly so no edges would accidentally lift away while handling.
Sticky Wickett
#310 Posted : 09 March 2017 09:20:24
When fixing the completed bow [supplied plastic from the part-works], I found I had to file a lot of the hull on both the bow and main hull for the parts to align. In this process I had to file away the cluster of small, round mouldings on the underside, port and starboard sides.
In real life, these small, round shapes are actually hydrophones [underwater microphones] that would listen in and were part of the sonar set-up.
To replace the ones I had filed away when fitting the bow I hit upon the idea of using 2mm washers. Once these were glued and the centres filled in they seem to blend in quite well. Once painted and weathered you won't notice the difference.
The attached image shows the lower starboard hydrophone washers!LOL
Sticky Wickett
#311 Posted : 09 March 2017 09:21:53
This image shows the port side of the bow, again with the free flood holes opened up and the bow flaps in the shut position.
Sticky Wickett
#312 Posted : 09 March 2017 09:22:54
Another image showing the port side bow rivet detail.
Sticky Wickett
#313 Posted : 09 March 2017 09:23:55
This image shows the hydrophones on the port underside.
Sticky Wickett
#314 Posted : 09 March 2017 09:25:21
This image shows the bow from underneath. You can the see the rivet detail and the arrangement of the hydrophones.
Sticky Wickett
#315 Posted : 09 March 2017 09:27:12
Another underside shot.
Sticky Wickett
#316 Posted : 09 March 2017 09:29:12
This final photograph shows the part-works supplied copper tube cut and fitted in place. This copper tube represents the forward mooring/ towing hitch.
Sticky Wickett
#317 Posted : 09 March 2017 09:30:54
Well that completes this weeks update from 'The Dockyard'.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
#318 Posted : 09 March 2017 10:33:00
Really looks superb PhilBigGrin lovely work BigGrin Drool Drool have you resolved the issue for the conning tower yet?regards PhilCool
Sticky Wickett
#319 Posted : 09 March 2017 11:53:35
Hi Phil, thanks for your encouraging comments mate. Regarding the conning tower I will have to buy a 1/72 scale donor model to measure up and then convert to 1/48 scale. I won't be starting this part of the build until later in the year. The conning tower is a model in itself really and I need to get more of the main hull and interiors underway first. I also have a lot of expenses coming up soon so financially it isn't viable to purchase the donor just yet anyway.
Kind Regards,
Phil W
#320 Posted : 09 March 2017 14:30:05
Just a pity no one can help you out with it PhilConfused but you could always super detail the 1/72 sub with the resin compartments that are availableBigGrin Regards PhilCool
This page was generated in 0.448 seconds.
