16 Pages «<45678>»
Eaglemoss Delorean Options
spike
#101 Posted : 06 March 2017 16:48:14
Eagle wrote:
Great idea to add lightening to the wheels; how does it look with the wheel on, is the lighting uniform through the wheel?
A circular light 'tube' like a fluorescent lamp bulb would be ideal for this, i don't think there are any that small though Bored
Hi Eagle thanks for looking, I will put a pic on of the wheel in the dark and the front and back of the wheel. I have also found some small rope lights that may look better then the LED strip i will do an update on that soon as i get them.
Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
#102 Posted : 06 March 2017 18:17:56
Like the upgrade with the lights, look forward to see what comes next.
Cool Cool Cool Cool
spike
#103 Posted : 06 March 2017 19:18:02
Cool Cool Cool Cool
Thanks delboy271155 BigGrin
Thanks for looking.
Duane
spike
#104 Posted : 06 March 2017 19:26:22
Update on the wheel in the dark. The last pic is in the loft were its the darkest.
spike attached the following image(s):
Thanks for looking.
Duane
Narayan
#105 Posted : 06 March 2017 20:55:46
This is looking great. It's nice to have such a detailed build thread as yours. I too have subscribed to this but will probably not be starting it until nearer the end of the subscription. I have enough on for the time being.
I have a question regarding the Mr Fusion prop. Is that optional for this or is that the only choice? I was hoping to do the car from the first movie before the Doc went to 2015.
Graham
#106 Posted : 06 March 2017 21:01:30
The kit comes with the option of both.
You can build it as 'film one', or 'film 2'.
Narayan
#107 Posted : 06 March 2017 21:03:11
Good to know, thanks.
Graham
spike
#108 Posted : 06 March 2017 21:35:52
Graham
Hi Narayan thanks for looking, Why you will not be starting your build till near the end make sure you check all your parts as the longer you wait the harder it is to get replacements and ebay prices are expensive. For the Mr Fusion that is optional as roymattblack commented. Good luck with your build soon as you start it. BigGrin
Thanks for looking.
Duane
BradM73
#109 Posted : 06 March 2017 22:48:47
I would love to do this kit! Too bad Eaglemoss isn't releasing it in the USA :(
spike
#110 Posted : 06 March 2017 23:06:09
Hi BradM73 you would need to find someone in the UK to send you the issues over or find an other source to get hold of them for you.
Thanks for looking.
Duane
Narayan
#111 Posted : 06 March 2017 23:17:41
Graham
Thanks for the tip Spike, I'll definitely look at that.
Graham
#112 Posted : 07 March 2017 09:33:08
Really does look afective in the darkBigGrin do you have a list of electronic parts i need to do this and the supplier please SpikeConfused regards PhilCool
spike
#113 Posted : 07 March 2017 11:51:32
At the min i am still trying to find better ways to make the lights work for the wheels. If you want go with the option of the LED strip lights then they are off ebay, http://www.ebay.co.uk/itm/12197...eName=STRK%3AMEBIDX%3AIT
I am also going to try these as they may look alot better then the LEDs http://www.ebay.co.uk/itm/38188...eName=STRK%3AMEBIDX%3AIT
To make it so i can make the wheels turn round when the cars not in flying mode i will be trying to fits these. http://www.ebay.co.uk/itm/19184...eName=STRK%3AMEBIDX%3AIT
I hope this helps you out BigGrin soon as the other lights come i will put some pics up with them fitted in the wheels to see whats going to be best.
Thanks for looking.
Duane
spike
#114 Posted : 07 March 2017 11:55:39
I am going to try and install LEDs to the clear parts above the number plate.
Thanks for looking.
Duane
#115 Posted : 07 March 2017 16:37:07
Thanks for getting back to me Spike BigGrin that sounds interesting will look forward to seeing thatBigGrin regards PhilCool
spike
#116 Posted : 08 March 2017 17:53:01
Issue 10
Parts -
Frame
4x AP Screws
4x GM Screws
6x DM Screws
4x BM Screws
3x AM Screws
Screwdriver
Thanks for looking.
Duane
spike
#117 Posted : 08 March 2017 18:03:32
Fit the assembled wheel hub and suspension (Left) into the underside of the front of the frame aligning the screw holes on both parts. Turn the frame over and add 2 BM screws. Do the same for the right assembled wheel hub and suspension.
Thanks for looking.
Duane
spike
#118 Posted : 08 March 2017 18:21:05
Place the top front plate on top of the frame and secure with 3 AM screws. Pass the Pinion and pull rod up through the holes in the top plate, them place the holes on the pinion and pull rod onto the posts on the top plate. Then add 2 GM Screws. Secure the wheel hubs to the steering rack with 2 DM screws. Check that the steering rack and wheel hubs move freely, if you have any problems try flipping the pull rod the other way. Turn the frame over and add the bottom plate. Turn the frame back over and add 4 DM screws.
Thanks for looking.
Duane
spike
#119 Posted : 08 March 2017 18:37:07
Place the ends of the anti-roll bar through the holes in the suspension assembly's then secure the two brackets to the right and left anti-roll bar base with 4 AP screws. Take the hub cap and washer out of the wheel and place the wheel on to the drake disk. place the washer back into the hole and add 1 GM screw then push the hub cap back in place. Do the same for the other wheel.
Thanks for looking.
Duane
#120 Posted : 08 March 2017 20:20:29
Another great update Spike BigGrin Drool regards PhilCool
Guest (9)
16 Pages «<45678>»
This page was generated in 0.550 seconds.
