 Rank: Pro  Groups: Registered
Joined: 04/07/2016 Posts: 297 Points: 897 Location: UK
Eagle wrote:Great idea to add lightening to the wheels; how does it look with the wheel on, is the lighting uniform through the wheel? A circular light 'tube' like a fluorescent lamp bulb would be ideal for this, i don't think there are any that small though Hi Eagle thanks for looking, I will put a pic on of the wheel in the dark and the front and back of the wheel. I have also found some small rope lights that may look better then the LED strip i will do an update on that soon as i get them. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Like the upgrade with the lights, look forward to see what comes next. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:Like the upgrade with the lights, look forward to see what comes next. Regards delboy271155 (Derek) Thanks delboy271155 Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Update on the wheel in the dark. The last pic is in the loft were its the darkest. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Joined: 22/02/2017 Posts: 155 Points: 474 Location: Ireland
This is looking great. It's nice to have such a detailed build thread as yours. I too have subscribed to this but will probably not be starting it until nearer the end of the subscription. I have enough on for the time being. I have a question regarding the Mr Fusion prop. Is that optional for this or is that the only choice? I was hoping to do the car from the first movie before the Doc went to 2015. Graham I was drowning my sorrows. But my sorrows they'd learned to swim.
The kit comes with the option of both.
You can build it as 'film one', or 'film 2'.
roymattblack wrote:The kit comes with the option of both.
Good to know, thanks. Graham I was drowning my sorrows. But my sorrows they'd learned to swim.
Narayan wrote:This is looking great. It's nice to have such a detailed build thread as yours. I too have subscribed to this but will probably not be starting it until nearer the end of the subscription. I have enough on for the time being.
Graham Hi Narayan thanks for looking, Why you will not be starting your build till near the end make sure you check all your parts as the longer you wait the harder it is to get replacements and ebay prices are expensive. For the Mr Fusion that is optional as roymattblack commented. Good luck with your build soon as you start it. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
I would love to do this kit! Too bad Eaglemoss isn't releasing it in the USA :(
Hi BradM73 you would need to find someone in the UK to send you the issues over or find an other source to get hold of them for you. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
spike wrote:Narayan wrote:This is looking great. It's nice to have such a detailed build thread as yours. I too have subscribed to this but will probably not be starting it until nearer the end of the subscription. I have enough on for the time being.
Graham Hi Narayan thanks for looking, Why you will not be starting your build till near the end make sure you check all your parts as the longer you wait the harder it is to get replacements and ebay prices are expensive. For the Mr Fusion that is optional as roymattblack commented. Good luck with your build soon as you start it. Thanks for the tip Spike, I'll definitely look at that. Graham I was drowning my sorrows. But my sorrows they'd learned to swim.
Really does look afective in the dark  do you have a list of electronic parts i need to do this and the supplier please Spike  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
tigerace wrote:Really does look afective in the dark  do you have a list of electronic parts i need to do this and the supplier please Spike  regards Phil At the min i am still trying to find better ways to make the lights work for the wheels. If you want go with the option of the LED strip lights then they are off ebay, http://www.ebay.co.uk/itm/12197...eName=STRK%3AMEBIDX%3AITI am also going to try these as they may look alot better then the LEDs http://www.ebay.co.uk/itm/38188...eName=STRK%3AMEBIDX%3AITTo make it so i can make the wheels turn round when the cars not in flying mode i will be trying to fits these. http://www.ebay.co.uk/itm/19184...eName=STRK%3AMEBIDX%3AITI hope this helps you out  soon as the other lights come i will put some pics up with them fitted in the wheels to see whats going to be best. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
I am going to try and install LEDs to the clear parts above the number plate. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Thanks for getting back to me Spike  that sounds interesting will look forward to seeing that  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Issue 10 Parts - Frame 4x AP Screws 4x GM Screws 6x DM Screws 4x BM Screws 3x AM Screws Screwdriver spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Fit the assembled wheel hub and suspension (Left) into the underside of the front of the frame aligning the screw holes on both parts. Turn the frame over and add 2 BM screws. Do the same for the right assembled wheel hub and suspension. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Place the top front plate on top of the frame and secure with 3 AM screws. Pass the Pinion and pull rod up through the holes in the top plate, them place the holes on the pinion and pull rod onto the posts on the top plate. Then add 2 GM Screws. Secure the wheel hubs to the steering rack with 2 DM screws. Check that the steering rack and wheel hubs move freely, if you have any problems try flipping the pull rod the other way. Turn the frame over and add the bottom plate. Turn the frame back over and add 4 DM screws. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Place the ends of the anti-roll bar through the holes in the suspension assembly's then secure the two brackets to the right and left anti-roll bar base with 4 AP screws. Take the hub cap and washer out of the wheel and place the wheel on to the drake disk. place the washer back into the hole and add 1 GM screw then push the hub cap back in place. Do the same for the other wheel. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Another great update Spike  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Guest (7)
