Sovereign Of the Seas Options
Anita_52
#1 Posted : 07 March 2017 12:25:51
Rank: Beginner Level 1
Good day,
I am finished with the Sovereign of the Seas and I am just asking the dimensions of the wooden plank sheet on which the glass case will fit. I know that I can measure it myself tonight but thought that maybe I can get a quick answer here
Anita
#2 Posted : 07 March 2017 14:23:55
Hi Anita, the dimensions of the SOTS is as follows:
Length: 1100mm, Height: 900mm, Beam: 400mm
Every model has its slight differences so to be on the safe side I would physically check the dimensions of your build to ensure it will fit in the glass case with room to spare....
Anita_52
#3 Posted : 08 March 2017 06:40:53
Hi Alan,
Thank you very much.
The dimensions are exactly the same as those you provided. I will leave 5 cm room on each side for the glass case
A
This page was generated in 0.345 seconds.
