106 Pages «<1516171819>»
#321 Posted : 09 March 2017 14:41:11
Just saw this on ebay thinking i might get one then i`ll have both versions whatch this space PhilBigGrin i thought they were more expensive than thisConfused regards Phil
http://www.ebay.co.uk/it...43?hash=item48998b990b:g
Sticky Wickett
#322 Posted : 09 March 2017 14:45:03
Hi Phil, would make a nice addition to your collection. It seems about the right price, but check Amazon or Antics as I'm sure I've seen one of these for £58 + £10 postage and packing.
The guy on ebay has probably added another tenner on.
Phil W
Sticky Wickett
#323 Posted : 09 March 2017 14:48:43
Try this link Phil.
1/72 scale Type VIIC/41 Atlantic
Phil W.
#324 Posted : 09 March 2017 14:53:26
Yep your right both of those websites £71.00 including p&p BigGrin its getting more tempting and my birthdays coming up swmbo as asked what i would likeConfused Confused Confused Blink regards PhilCool
#325 Posted : 09 March 2017 15:19:08
Well had a word with swmboBigGrin i can order it at the end of next monthBigGrin happy chap now BigGrin BigGrin regards PhilCool
Sticky Wickett
#326 Posted : 09 March 2017 15:49:17
Hahaha - you're a happy chap then!
#327 Posted : 09 March 2017 18:29:30
LOL Laugh Laugh LOL you will cause i`ll lend you them bits you needBlink Blink OhMyGod OhMyGod ThumpUp ThumpUp Woot Woot regards PhilCool
#328 Posted : 09 March 2017 19:18:50
BigGrin Have you seen the CMK interiors for the Revel U-boats:-
http://www.ebay.co.uk/it...Dlo%26sd%3D311813708043
Might be better to go to CMK though and order direct
http://www.cmkkits.com/en/ships/index.php?from=20
Sticky Wickett
#329 Posted : 09 March 2017 19:42:07
Wow Phil, you're a legend!!!ThumpUp Thank you!!
Sticky Wickett
#330 Posted : 09 March 2017 19:43:56
Hi Andy, unfortunately CMK don't produce 1/48 scale parts only the 1/72 scale. Believe you me I trawled all over their site looking for the elusive 1/48 scale.
Thank you for the link though mate. Much appreciated.
Phil.
#331 Posted : 10 March 2017 00:19:18
Great piece of work Phil, this is really coming along beautifully.....Drool Drool
Sticky Wickett
#332 Posted : 10 March 2017 09:10:43
Thanks very much Alan. Your comments are much appreciated.
#333 Posted : 10 March 2017 20:32:54
BigGrin My sources tell me that CMK will be doing 1/48 scale parts in the near future for the Revel subsCool
#334 Posted : 11 March 2017 00:11:19
Usual excellent update. Coming along great.......
Chris Cool
#335 Posted : 11 March 2017 07:52:07
really starting to look the part
Jason
Sticky Wickett
#336 Posted : 11 March 2017 11:47:34
Chris Cool
Thank you Chris!
Phil.
Sticky Wickett
#337 Posted : 11 March 2017 11:48:40
Jason
Thank you Jason!
Phil W.
Sticky Wickett
#338 Posted : 16 March 2017 19:37:26
Good evening fellow modellers,
I hope you're all well and enjoying the lighter evenings now spring is here?
On this part of my U-boat build I will be looking at the part-works supplied rivet strips that were fitted to the stern.
I used the same method for fixing them in place as I did for the bow; carefully file away burrs left when the strips were separated from the fret, sanding the underside with 100 grit sandpaper to provide a key for the adhesive, applying PVA glue to the underside which gave me time to adjust them on the hull as per the part-works instructions before it started to go off, taping them to ensure they didn't move while the adhesive dried overnight and finally, removing the tape and running a bead of superglue around all edges to provide a robust bond so that they wouldn't move whilst handling.
The attached image shows the port side of the stern.
Sticky Wickett
#339 Posted : 16 March 2017 19:39:03
This image shows the same rivets but moving aft.
Sticky Wickett
#340 Posted : 16 March 2017 19:39:55
This image continues with the port stern rivet strips.
Guest (14)
This page was generated in 0.644 seconds.
