Building up ribs and shaping planks Options
Atholm
#1 Posted : 05 March 2011 08:35:38
Hi all you shipbuilders,
A couple of questions which I have which I am sure you can answer for me.
1. Building up ribs, the preference/recommended method seems to be using card and super glue which included soaking the card with super glue. Is there any reason why wooden planks can't be used particularly when I have to build up rib 16 by approx 1 mm?
2. When planking what is the best order of preparing the planks. Bend, taper and then chamfer?
#2 Posted : 05 March 2011 09:03:47
Hi there Atholm, I used spare planking to build up the ribs mate...LOL
daffy09
#3 Posted : 05 March 2011 16:58:16
Hello Atholm,
The method that I use is first to cut the plank to required length, next shaping the plank, that is tapering, after which I then chamfer the edge and finally, work on the bend.
There may be other ways but this is the my personal preference through the experience of this build - this being my first attempt at anything like this.
Through experience I found that bending the plank first made the other 2 operations that much more difficult and chamferring before tapering negated the effort of the chamferring where the tapering had been done.
Hope this helps and happy building
Daffy09
"Good judgement comes from experience. Unfortunately, the experience usually comes from bad judgement"
Tarbrush
#4 Posted : 07 March 2011 21:07:20
Hi all. I absolutely agree with Daffy.BigGrin Wet and bent planks are very difficult to work on. If they should need a little tweak then this can be done when fitting after bending, but doing all the shaping at this stage is not advisable.Cursing
Laury
Atholm
#5 Posted : 08 March 2011 15:49:51
Thanks Maties, must appreciated
Athol
This page was generated in 0.109 seconds.
