3 Pages <123
davetwin's C57 Build Options
#41 Posted : 13 March 2017 21:20:08
Stage 41
This stage starts by attaching the sand spreader tubes, its a good idea to place these out in order and try fit first so you are sure they are going in the correct place. The tubes are attached to the pipe main cocks fitted earlier, they are then secured underneath the boiler with tube receivers to hold them in place. Masking tape will help hold everything securely while the glue sets.
Stage 42
Start off by gluing together the discharge reservoir, discharge value, and discharge handwheel. Once the glue has tried the assembly is attached to the left firebox bottom and secured with glue. Next a bleed value is glued to the right firebox bottom. These bottoms are now secured to the bottom of the firebox with screws. The stage is finished off by gluing a drainage pipe into the bottom of the discharge value.
Stage 43
Start by laying out all the parts so you know what is going to be glued where. Then take the axes A and glue them into the 6 holes of the valve box. Glue Axes B into the valve box and axes C into the water injector. Once the glue has dried you can now start gluing on the little hand wheels.
Next lay out the parts ready to glue to the backhead as shown in the instructions, then start gluing them on after you have test fitted them to be sure where they are going.
Next we affix the air cylinder to the firebox door, followed by the firebox door handle into the air cylinder. Now the firebox door assembly is added to the backhead with the other parts. We then finish by attaching the backhead to the read of the body.
davetwin attached the following image(s):
#42 Posted : 13 March 2017 21:23:50
birdaj2 wrote:
Must admit i really do like that pre-painted finish - i think that a real plus point with this particular model.
Hope it continues to go well.
I agree, I love the paintwork, you need to be so careful with it though, I use masking tape if the screwdriver is going to go anywhere near the paintwork just in case BigGrin
#43 Posted : 13 March 2017 21:30:14
Stage 44
This stage we just add the front left running board, first by attaching the brackets the running board itself. We then attach 2 handrails. I found with my handrails I scraped the paint off as they went through the brackets, they will be touched up at the end.
Stage 45
More running board parts are fitted, like before this starts with the brackets followed by the running board and its base. Next we attach the sand spreader tube brackets. As is advised in the official build it is easier to shape these while off of the model.
Stage 46
Yet another running board attached, same as before brackets first then the board. An oil pump box is then attached to this running board. We finish this stage with more handrails.
This completes pack 6, it looks really cool already and there is still a ton of detail to come Cool
#44 Posted : 14 March 2017 00:08:16
Looking fab Dave and can see you're taking a great deal of care and attention with it.... Great work.....Drool Drool
#45 Posted : 14 March 2017 02:50:08
BigGrin Nicely done DaveCool
#46 Posted : 14 March 2017 15:20:26
This is coming along a treat Dave Cool nice work.
#47 Posted : 14 March 2017 17:15:40
Looking good Dave.
Cool Cool Cool
#48 Posted : 14 March 2017 19:15:09
Hi dave coming along well, your ahead of me now. Cheers mick. BigGrin
#49 Posted : 14 March 2017 20:35:47
Thanks all for stopping by and your comments BigGrin
I'm really enjoying this Cool
Sticky Wickett
#50 Posted : 15 March 2017 10:08:58
Excellent work Dave! Neat, precise and accurate!Drool
Ally1318
#51 Posted : 15 July 2017 20:24:03
Rank: Newbie
Hi just looked through the build, got up to the 7th pack but not started the build yet. Never done any thing like this before. Looks so good now can not wait to start.
Dumped the first 3 packs on the table and will be starting this week, working
Hope you finish the build and post the rest of the diary, and some great advice, now need to get on with it.
Yours is looking great hope mine turns out half as good.
#52 Posted : 16 July 2017 09:25:23
Nice looking build that makes a lovely looking display model Cool
#53 Posted : 16 July 2017 19:57:23
Thanks Ally and welcome to the forum.
It is a great build, I will get round to finishing it soon Im just getting beasted with work at the moment Crying Crying
Take your time with it and try not to use too much glue on the parts you needs to glue otherwise it will squelch out the sides. Especially take your time and be gentle with the screws, you really dont want to slip off, I know I've done it a few times now Crying Mad
#54 Posted : 16 July 2017 19:57:42
Thanks Tomick Cool
#55 Posted : 17 July 2017 05:40:36
Looks great Dave BigGrin not started mine yet so good to get a heads up of how she goes together by looking at yours.
3 Pages <123
This page was generated in 0.203 seconds.
