 Rank: Pro Groups: New Members, Unapproved
Message was deleted by User.
Joined: 22/02/2017 Posts: 155 Points: 474 Location: Ireland
Good to know, thanks. I am subscribing to this but won't be starting for some time. But it's good to pick up any tips along the way. Graham I was drowning my sorrows. But my sorrows they'd learned to swim.
just had my next parts delivered, issues 12 to 15. stevegbr attached the following image(s):
oooh  got mine too  rolling chassis as we thought Steve  looking forward to your next update  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
will have a go tonight phil. good luck with yours as well.
2 more deliveries before i start mine Steve  looking forward to your progress though  Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
here are the parts for issue 12. stevegbr attached the following image(s):
these parts are secured by two screws. stevegbr attached the following image(s):
needs one screw to put the parts together. stevegbr attached the following image(s):
now going to put this part on the chassis. which is secured by one screw and locating peg. part secure, now the support bracket, and one screw. stevegbr attached the following image(s):
put together the caliper and hub, one screw required. stevegbr attached the following image(s):
mount the hub and strut on the wishbone. stevegbr attached the following image(s):
put the spring on the strut and secured with one screw. stevegbr attached the following image(s):
these are parts for the track rod. one screw . stevegbr attached the following image(s):
this will be kept till its needed.
Looking good Steve Al
Hi Steve great update  looks impressive  question have you had problems fitting the screws ?seems a lot of builders have had problems with screws  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Joined: 27/02/2017 Posts: 410 Points: 1,220 Location: Lancashire
Hi, I've only just found your diary Steve, I've subscribed to this series for my hubby and got the first delivery of issues 1 - 7. He won't be making a start until he's back from tour, but I'll be following your build with interest May.
here are the parts for issue 13.
MFG wrote:Hi,
May. thanks may, we will both learn something.
Guest (26)
