37 Pages «<1011121314>»
Eaglemoss Delorean Car build (stevegbr build) Options
stevegbr
#221 Posted : 19 March 2017 18:29:56
tigerace wrote:
Hi Steve great updateBigGrin looks impressiveBigGrin question have you had problems fitting the screws ?seems a lot of builders have had problems with screws Confused regards PhilCool
you must use the right screwdriver phil, the one i use it gets to the bottom of the pozi.
stevegbr
#222 Posted : 19 March 2017 18:31:07
got to insert the rim in to the tyre.
stevegbr attached the following image(s):
stevegbr
#223 Posted : 19 March 2017 18:32:39
now for the wheel cover which is held by three screws.
stevegbr
#224 Posted : 19 March 2017 18:34:34
now you use a screw and the plastic washer, and secure the wheel to the hub, be careful not to over tighten the screw, lastly insert the wheel cap.
stevegbr
#225 Posted : 19 March 2017 20:37:08
here are the parts for issue 14
stevegbr
#226 Posted : 19 March 2017 20:40:14
this two parts are secured by two screws.
stevegbr
#227 Posted : 19 March 2017 20:42:38
this parts are secured by one screw.
stevegbr
#228 Posted : 19 March 2017 20:45:27
fit the bracket to the chassis, there is a locating pin for one hole then secured by one screw.
stevegbr
#229 Posted : 19 March 2017 20:48:57
secure the hub strut to the chassis, held by one screw.
stevegbr
#230 Posted : 19 March 2017 20:50:52
one screw connects the top rod withe hub.
stevegbr
#231 Posted : 19 March 2017 20:52:06
connect the caliper with the disc with one screw.
stevegbr
#232 Posted : 19 March 2017 20:55:40
rear strut and one screw to connect the lower hub together.
stevegbr
#233 Posted : 19 March 2017 20:58:23
spring coil put on strut and secured it to top bracket by one screw.
stevegbr
#234 Posted : 19 March 2017 21:00:10
front driveshaft parts.
stevegbr
#235 Posted : 19 March 2017 21:01:43
secured by one screw, and kept for future fitting.
#236 Posted : 19 March 2017 22:12:08
That is all looking really good.
stevegbr
#237 Posted : 19 March 2017 22:16:10
thanks tony, its a big car now.
stevegbr
#238 Posted : 19 March 2017 22:48:15
here are the parts for issue 15.
stevegbr
#239 Posted : 19 March 2017 22:51:02
now we put the tyre on the rim.
stevegbr
#240 Posted : 19 March 2017 22:53:57
now to put the wheel cover on, held by three screws.
Guest (20)
This page was generated in 0.852 seconds.
