106 Pages «<1718192021>»
Sticky Wickett
#361 Posted : 21 March 2017 21:19:00
This image shows a closer view. At this stage I had begun to clean up the MDF supports
Sticky Wickett
#362 Posted : 21 March 2017 21:22:31
This photo shows the MDF support being sanded down so that it would run parallel. These part-works supplied supports came with a slight taper so this had to be reduced, especially on this section, as it was wider than the supports for the Control Room and Engine Room and I wanted it to match them.
Sticky Wickett
#363 Posted : 21 March 2017 21:25:30
This image shows the furthermost support being given the same treatment as in the previous photo. For this fiddly work I had to wrap a piece of 100 grit sandpaper around a cut-down sanding stick to get sufficient access.
Sticky Wickett
#364 Posted : 21 March 2017 21:26:49
This photo shows the furthermost support sanded down to the correct height.
Sticky Wickett
#365 Posted : 21 March 2017 21:29:59
For the inner pressure hull to maintain it's curve it had to be supported so that it formed a strong bond.
I used 4.5mm wide by 2.5mm thick plastic strip. The attached photo shows a close up of one of these pieces.
Sticky Wickett
#366 Posted : 21 March 2017 21:31:56
This photo shows how I started to build up extra supports for the inner pressure hull using the plastic strip mentioned previously.
Sticky Wickett
#367 Posted : 21 March 2017 21:33:15
This image shows further plastic strip being fixed to act as inner pressure hull supports.
Sticky Wickett
#368 Posted : 21 March 2017 21:35:54
The support lattice work continues as shown in this photo. Each piece had to be individually measured, cut and filed to suit it's location. I also had to carefully bend some of them to follow the curvature of the hull to create a strong bond when glued.
Sticky Wickett
#369 Posted : 21 March 2017 21:37:47
This photo shows another support fixed in place.
Sticky Wickett
#370 Posted : 21 March 2017 21:41:25
This photo shows the vertical supports fixed in place.
Sticky Wickett
#371 Posted : 21 March 2017 21:42:39
Another image showing the vertical supports.
Sticky Wickett
#372 Posted : 21 March 2017 21:43:47
This image shows the vertical supports looking forward.
Sticky Wickett
#373 Posted : 21 March 2017 21:45:52
To fabricate the inner pressure hull I used 0.5mm thick plastic sheet. It took awhile to cut it and file it so that it would dry fit correctly. This image shows the plastic sheet, cut and ready for fitting.
Sticky Wickett
#374 Posted : 21 March 2017 21:50:07
This photo shows the inner pressure hull glued in it's correct position with it's leading edge lined up with the MDF support I had previously filed.
For fixing it I used liberal amounts of PVA glue to give it a strong but flexible bond and a small line of superglue on it's leading edge to act as a 'tack-weld' to hold it place so that it didn't 'spring-out' overnight due to the curve enforced on it by following the hull.
Sticky Wickett
#375 Posted : 21 March 2017 21:56:15
This photo shows the U-boat now back up the right way with first of many 2mm by 2mm square plastic strips glued in place. By careful cutting I could spring it into place so that it formed it's own natural curve to match the inside of the pressure hull.
I chose 2mm square strip as this matched the dimensions of the t-frames [ribs] on the Engine Room and Control Room supplied with the part-works. You can just make out in this photo the ribs in the Engine Room.
Sticky Wickett
#376 Posted : 21 March 2017 21:57:44
This photo shows the rib attached to the inner pressure hull at the forward end of the compartment.
Sticky Wickett
#377 Posted : 21 March 2017 22:03:51
Using a schematic as a reference guide I could then calculate the spacing between all subsequent ribs based on the distance between the two datum ribs already fixed as shown in the previous two posts.
Once i knew what the gap would be I fabricated two spacers to match the calculated distance. I made two so that each rib could be placed against them so that they would be parallel to the one before it.
The attached photo shows one of the spacers filed to give me the correct width; 9.08mm.
Sticky Wickett
#378 Posted : 21 March 2017 22:04:35
This image shows the two completed spacers.
Sticky Wickett
#379 Posted : 21 March 2017 22:05:57
I worked from each end when fitting the ribs. This photo shows the third rib fixed in place.
Sticky Wickett
#380 Posted : 21 March 2017 22:07:10
The fourth rib fixed in place.
This page was generated in 0.919 seconds.
