106 Pages «<1819202122>»
Sticky Wickett
#381 Posted : 21 March 2017 22:09:09
This photo shows all of the ribs fixed in place and the ends cut flush to the leading edge of the inner pressure hull.
Sticky Wickett
#382 Posted : 21 March 2017 22:10:10
I then filed smooth the ends of all the ribs.
Sticky Wickett
#383 Posted : 21 March 2017 22:11:54
To match the style of the cut-out ribs on the part-works supplied plastic hull pieces I filed a bevelled edge.
Sticky Wickett
#384 Posted : 21 March 2017 22:14:37
To continue that 'cut-away' effect I measured and glued ribs that would be seen on the near edge as shown in this photo. I left them longer than needed so that I could hold and position them correctly.
Sticky Wickett
#385 Posted : 21 March 2017 22:15:45
This photo shows the ribs cut and filed flush.
Sticky Wickett
#386 Posted : 21 March 2017 22:17:22
The attached image is more of an overview photo showing the inner pressure hull and t-frames fixed in place.
Sticky Wickett
#387 Posted : 21 March 2017 22:19:00
Finally, an overhead view showing the smaller t-frames on the cut-edge of the Junior Rates Mess & Galley.
Sticky Wickett
#388 Posted : 21 March 2017 22:22:16
The complete process took two weeks and I think it turned out very well.
In the next post I will be looking at making the profiled 'scalloped' saddle tank ends on this compartment.
I hope you enjoy the read.
Thanks for looking in and happy modelling.
Kind Regards,
Phil W.BigGrin
#389 Posted : 21 March 2017 22:59:43
Phil
Some very skilful building - very well done.
#390 Posted : 21 March 2017 23:42:58
Looks well Phil, doing a really nice job.
Cheers
Chris Cool
#391 Posted : 22 March 2017 08:03:29
More excellent work Phil BigGrin each update brings something else to the table great stuffBigGrin Drool Drool regards PhilCool
Sticky Wickett
#392 Posted : 22 March 2017 10:07:15
birdaj2 wrote:
Phil
Thank you Tony - glad you like the work so far.
Phil.
Sticky Wickett
#393 Posted : 22 March 2017 10:08:00
Cheers
Chris Cool
Thank you Chris. It's starting to take shape!
Phil.
Sticky Wickett
#394 Posted : 22 March 2017 10:12:30
BigGrin Thanks Phil. There will be quite a few modifications along the way. Stay tuned.
Phil.
Sticky Wickett
#395 Posted : 22 March 2017 10:13:37
Thank you for all your kind comments. Another update will follow next week from 'The Dockyard'.
Kind Regards,
Phil W.
#396 Posted : 22 March 2017 13:07:54
Coming along really nicely, very nice work indeed....Cool Cool
Sticky Wickett
#397 Posted : 22 March 2017 13:18:16
Thank you very much Alan. She's starting to take shape!
Phil.
#398 Posted : 22 March 2017 13:22:16
Excellent work, some very nice skilled work gone into that. Love
Sticky Wickett
#399 Posted : 22 March 2017 13:24:55
Thanks Mark!
Phil W.
Sticky Wickett
#400 Posted : 30 March 2017 18:19:51
Good Evening from 'The Dockyard'.
On this part of my U230 U-Boat build I will be fitting profiled and scalloped ends to the saddle tank that span the Junior Rates Mess & Galley as mentioned in my previous thread last week.
The attached image shows the area I will be working on. As before the U-boat is inverted to aid easier working.
Guest (8)
This page was generated in 0.377 seconds.
