10 Pages «<678910>
Occre 1:24 Adler Locomotive Display Options
#141 Posted : 20 March 2017 21:27:43
Dave
Many thanks for the kind comments BigGrin
#142 Posted : 26 March 2017 18:07:55
SUNDAY 26th March 2017 – The Adler Locomotive Build & Tender
A very good afternoon to everyone. I hope that everyone has had a good week whatever you may have been up to.
As in previous weeks I thought I would start this week’s update by way of a little “On this Day” entry.
On This Day 26th March
1484 William Caxton printed his translation of Aesop's Fables. As far as is known, Caxton was the first English person to work as a printer and the first to introduce a printing press into England. He was also the first English retailer of printed books.
This week’s build instalment has seen an age being spent on filling and sanding areas of the tender. So much work for what appears to be little progress but a vital task if any hope of getting a decent finish is to be expected.
PICTURE 1
We have 2 side rails to now fix to the top sides of the tender. These are expected to be glued in 3 dimensions but having been cut in 2 dimensions means the fit is far from perfect and if you want to get the best from this area of the build (it will be very visible in the finished model) a lot of fitting adjustments are required.
In this picture we can see a significant gap which in theory could be filled later but if these parts are glued in place like this the outer sides do not line up correctly with the rear of the tender.
PICTURE 2
Some very careful filing along the already glued in parts (on which the arrow sits in this picture) allows the side rail to fit into place with next to no visible gap which is an improvement over the earlier dry fit.
PICTURE 3
This shows the 2 side rails glued and pinned into place on the tender. You can also see in this picture some of the earlier filling that was required in order to remove the gaps between the part tabs as much as possible.
PICTURE 4
Once happy with the location of the side rails I pinned them into place to ensure they dried exactly how I had set them in place.
PICTURE 5
Once dry I removed the pins and then used a liberal amount of filler in order to try and blend in the tab areas and the edge to edge joint.
“RECOMMENDATION”
While plastering on lots of filler may seem like a good idea its best to try and use as little as possible or (if you can get a good fit) none at all.
The Ronseal filler I have switched too dries like “concrete” and while it can be rubbed back it takes an absolute age. It creates a load of fine dust and you want to ensure you do not start breathing that in for the sake of your health and wellbeing.
PICTURE 6
A very small amount of filler was required along this join simple because you are gluing the side pieces on at an angle so this form a small gap along this edge.
PICTURE 7
This is the view looking into the tender. While it took an age to get to this point I am really pleased that the time to get the side rails adjusted before fitting into place has paid off and it all looks quite neat and tidy.
Once the filler is dry it will be back to the sandpaper and once that is complete the whole thing will be given a couple of coats of Sand n Seal prior to painting.
PICTURES 8 & 9
The final part of this week’s instalment has seen some of the control levers painted up and installed.
And that completes my update for this week. Hope everyone has a good week and I will catch up again with you all very soon.
#143 Posted : 26 March 2017 19:44:01
BigGrin Looking good, I think you needs shares in a filler manufacturerLOL Laugh Cool
#144 Posted : 26 March 2017 20:46:09
I think you are right.
The locating tabs are the worst areas to manage as they are all cut "Short" so you end up with a dip across the join which will stand out under the pain finish.
If anything it would have been better to have them cut oversize so you could rub them back later.
Still it is what it is and I am trying to make the best of it BigGrin
#145 Posted : 26 March 2017 22:31:59
Think you're doing a great job on this, looking great.....Drool Drool
#146 Posted : 26 March 2017 22:58:11
Much appreciated - many thanks BigGrin
#147 Posted : 26 March 2017 23:54:08
Really great work on this Tony.
Geoff44
#148 Posted : 27 March 2017 01:42:35
Again Tony, another great update. I bet you are fed up with all the filling that's needed,but I know it will pay off later in the build. These sort of wooden kits need a lot of patience and time and sometimes it seems as though you are getting nowhere fast. I have in the past built a few wooden ship kits, but I find that there is too much preparation in getting some of the parts to fit right.
I now tend to stick to building models that don't need a lot of time spent filling and sanding, I much prefer doing kits like my Honda and the upcoming Jaguar, where its just a matter of assembly, without having to do lots of filing, filling and painting, as well as not having to use glue. I suppose I have got a bit lazier in my old age, and prefer less mess when building models.
Look forward to your next build session on this model. Cool
BUILDING - HONDA CB750 - HAYNES V8 VISIBLE ENGINE
NEXT BUILD - JAGUAR E-TYPE
GEOFF
#149 Posted : 27 March 2017 16:33:23
Carl/Geoff
#150 Posted : 27 March 2017 19:27:48
Lovely work as usual Tony looks fantasticDrool Drool Love regards PhilCool
#151 Posted : 27 March 2017 19:46:32
This is going to look really good with all the work you have put in to it Tony Cool
#152 Posted : 27 March 2017 20:08:51
Phil/Al
Many thanks for the support.
I thought i had taken on a fairly easy build ie no awkward planks to bend on a ship, but its a bit of a pain in terms of fit and the like.
What is interesting is this is version 2 of the kit and its still not perfect.
I work full time (plus) and have caring responsibilities so my dedicated build time is saturdays and beginning to get a bit down hearted that after 3 months its not progressed quite as far as I wanted.
Still i am determined to produce sonething as an end result rather than than just bin it Crying but its taking just that little longer than i had planned.
#153 Posted : 27 March 2017 20:33:05
Lovely work Tony ThumpUp
#154 Posted : 28 March 2017 10:02:14
Many thanks Dave BigGrin
kpnuts
#155 Posted : 28 March 2017 20:58:19
Looking great so far.
#156 Posted : 29 March 2017 09:07:55
Ken
Many thanks for looking in. BigGrin
#157 Posted : 02 April 2017 17:11:01
SUNDAY 02nd April – The Adler Locomotive Build & Tender
On This Day 02nd April
1873 Almost 14 years after the United States, British trains were fitted with toilets, but only for sleeping cars. Day carriages were fitted in 1881. Third class passengers weren’t able to 'spend a penny' until 1886.Blushing
This week’s build has concentrated on the whole with further additions to the tender
PICTURES 1, 2 & 3
Lots of work and effort here to rub back all of that filler that I applied at the of last week’s build. What would have been good would have been having the interlocking tabs made slightly oversize so that these could be rubbed back rather than having to resort to filler to try and mask the issues of the short tabs leaving gaps.
PICTURE 4
We now have another 8 pre-cast pieces to add to the tender assemble.
These parts are actually rather well cast with very little clean up required. Again an inconsistency in the kit in that some parts are “perfect” and others need quite a bit of attention to tidy up.
PICTURE 5
4 of the precast parts will be glued into the area highlighted with the arrows in this picture. The parts are quite heavy and have to be self-supporting so consideration needs to be given to the type of glue used here.
Super Glue (CA) on its own I do not think suitable. Epoxy (I use Devcon 5 minute) is very good but prior to drying can become very fluid and difficult to control.
So my option is to use Timebond in the slots and Super Glue (CA) on the other touching areas. There is no direct weight applied to these areas on the finished tender so I think this combination of 2 adhesives should prove ok.
PICTURE 6
And once these 8 cast parts are in place this is how the lower half of the tender looks.
PICTURE 7
The next stage is the addition of 8 etch brass parts that represent the corner bracing. In this picture we can see the 4 parts that require some shaping before being applied.
PICTURE 8
Most modellers that use photo etch will at some point invest in a folding tool. I have had mine for some time now and it’s a model that was produced by Mission Models. It does for my needs very well.
PICTURE 9
And once all of the parts are shaped this is what they look like.
PICTURE 10
These corner pieces are then affixed to the lower tender corners. IN this case I have used Super Glue (CA) as I am gluing onto sealed wood that having been rubbed back is a nice shiny non porous finish ideal for CA
PICTURE 11
Here we can see what the upper part of the tender looks like now that it has received its very first coat of final colour.
The Humbrol Rail Match green is a nightmare to use as its almost transparent and needs around 5 coats at least to get the depth of colour required
PICTURE 12
I am gearing up for a major painting session in the next week or so. Having tried A Vallejo Brass paint, it just does not give the finish of “real metal” so as much as I was trying to avoid it I am going to have to be the Alclad polished Brass I use.
This means an Alclad white primer and micro filler on some of the wood parts, an alclad gloss black base coat followed by the Alclad polished brass colour itself.
So in preparation for that I am about to make the Large wheel covers for the Loco. One each side and these are made up of 2 brass and 1 wood section as can be seen in this picture.
PICTURE 13
“PROCEED WITH CARE”
Something I think well worth a mention is that if you are working with Brass etch or cast parts that require clean-up make sure you work “Clean and Tidy”.
As you can see in this picture some of the tabs that hold the etch parts into their fret are very fine and extremely sharp.
If you have pets or youngsters at home (or even if you walk around barefoot) the last thing you want is for one of these fine brass parts sticking into you or the paw of a pet. Or worse ending up in something edible and being digested by mistake.
They can cause some really serious issues so I always work on a paper kitchen towel and when done this is all folded up, taped up and binned.
#158 Posted : 02 April 2017 18:50:00
BigGrin More progress and looking goodCool
#159 Posted : 02 April 2017 19:01:43
Many thanks. Its getting there slowly BigGrin
#160 Posted : 02 April 2017 22:20:31
Looking good Tony, WTG.
Cool Cool Cool
Guest (12)
10 Pages «<678910>
This page was generated in 0.312 seconds.
