16 Pages «<678910>»
Eaglemoss Delorean Options
spike
#141 Posted : 28 March 2017 14:48:54
Thanks all for looking in and following my build. BigGrin
Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
spike
#142 Posted : 28 March 2017 14:49:24
Issue 12
Parts -
Rear Left Carrier
Rear Left Radius Arm
Boot
Front Left Track Rod
Flange
Rear Shock Assembly
Spring
Link
Bracket
Rear Brake Caliper
Rear Brake Disk
2x BM Screws
2x CM Screws
1x HM Screw
3x EM Screws
2x AP Screws
1x IM Screw
spike attached the following image(s):
Thanks for looking.
Duane
spike
#143 Posted : 28 March 2017 15:06:07
Fit the rear hub carrier into the end of the radius arm. Align the holes of both parts and secure with 2 CM screws. Insert the end of the link into the hole in the bracket and add a EM screw. Secure the bracket to the side of the frame with a BM screw. Place the hole at the end of the arm over the post at the side of the frame. Add a EM screw into the post hole. Place the end of the link between the 2 uprights of the rear hub carrier and pass an HM screw through the holes.
Thanks for looking.
Duane
spike
#144 Posted : 28 March 2017 15:20:09
Place the 2 pins of the caliper into the holes in the brake disk, then add an AP screw. Insert an IM screw through the hole at the bottom of the shock assembly. Place the brake disk into the rear hub carrier and raise the lower link up into the bottom of the brake disk. Pass the IM screw through the hub carrier, brake disk and link. Add the spring onto the shock assembly. Insert the top of the shock assembly into the hole and add an EM screw.
The front left tracking rod i will assemble when its time to be added.
Thanks for looking.
Duane
spike
#145 Posted : 28 March 2017 15:24:45
I got some LED rope lights with 2 flash settings, i have tried them in a wheel and it looks alot better but the light is not that bright.
Thanks for looking.
Duane
spike
#146 Posted : 31 March 2017 10:33:22
Issue 13
Parts -
Tyre
Hubcap
Rim
Hub
Washer
4x BP Screws
2x GM Screws
Thanks for looking.
Duane
spike
#147 Posted : 31 March 2017 10:36:33
The wheel is put together in the same way as the other 2 wheels and then added to the frame with a GM screw.
Thanks for looking.
Duane
spike
#148 Posted : 31 March 2017 10:50:16
I ended up getting the special edition to see what its like, I must admit the graphics in the book are fab and its packed full of pics. Here is a few pics of the book.
Thanks for looking.
Duane
spike
#149 Posted : 19 April 2017 14:00:29
Issue 14
Parts -
Rear Right Hub Carrier
Rear Right Radius Arm
Flange
Front Right Tracking Rod
Boot
Rear Shock Assembly
Spring
Link
Bracket
Rear Brake Disk
Rear Brake Caliper
2x BM Screws
2x CM Screws
1x HM Screw
3x EM Screws
2x AP Screws
1x IM Screw
Thanks for looking.
Duane
spike
#150 Posted : 19 April 2017 14:49:00
Do the same as issue 12 and add the assembly to the fame.
Thanks for looking.
Duane
#151 Posted : 19 April 2017 14:50:09
That looks like a nice full pack of parts to be working with.
Just looked back over your earlier updates and really do like that yellow light cable you are fitting to the wheels.
Its turning into a very solid looking model.
Hope it all continues to go well.
spike
#152 Posted : 19 April 2017 14:53:15
Issue 15
Parts -
Tyre
Hubcap
Rim
Hub
Washer
3x BP Screws
1x GM Screw
Thanks for looking.
Duane
spike
#153 Posted : 19 April 2017 14:56:56
Same as the other 3 wheels are put together. A pic with the wheels up and a pic with the wheels down.
Thanks for looking.
Duane
spike
#154 Posted : 19 April 2017 15:04:03
Hi birdaj2 thanks for looking in, the yellow light tube is a lot better then the LEDs but they don't let off a lot of light like the LEDs do. I will be sticking to the LED strip lights in the wheels. I will also put some pics up when i get all 4 wheels fitted with lights. So far the build is good and had no problems getting issues. I am still waiting for EM to send me issue 3 out Cursing.
Thanks for looking.
Duane
spike
#155 Posted : 19 April 2017 15:18:46
I also got sent the Thunderbird 2 issues. BigGrin
Thanks for looking.
Duane
#156 Posted : 19 April 2017 15:33:41
Looks great SpikeBigGrin looking forward to the gearbox nextBigGrin also the TB2 is that from UK ? regards PhilCool
spike
#157 Posted : 19 April 2017 15:39:58
Hi tigerace, thanks for looking in. I will be adding issue 16 either later or tomorrow. Yes the TB2 is from the UK i think its a test run.
Thanks for looking.
Duane
#158 Posted : 19 April 2017 19:43:57
Nice progress with your Delorean, and how cool does the Thunderbird 2 look Drool
spike
#159 Posted : 19 April 2017 22:31:22
Hi davetwin, thanks for looking in, yes the TB2 looks very nice and the car is a nice size. Its just a shame its a test run.
Thanks for looking.
Duane
spike
#160 Posted : 20 April 2017 12:10:31
Issue 16
Parts -
Left Transmission Case
Right Transmission Case
Oil Pump Housing
Lower Pan
2x Seals
2x Axle Mounts
4x AM Screws
2x DM Screws
2x EP Screws
Thanks for looking.
Duane
16 Pages «<678910>»
This page was generated in 0.567 seconds.
